Orthojoe's track build journal
#886
From: Mid-Atlantic (on land, not in the middle of the ocean)
^ Thanks for the info, I don't mind some squealing of the pads ... fits the character of the car.
BTW, on the TPM question, I've found my TPM pressures to usually be within ~1 psi of both of my analog mechanical gauges. I routinely keep an eye on tire pressures when on track, to see the relationship between pressures and car behavior, to know when pressures are high enough that I can start to really lean on the car, and for early detection of tire leaks (rare, but it does happen).
#887
#888
And some have been known to be off by much more than 2.5 psi. Always good to routinely cross-check your guage(s) against other gauges.
#890
You can keep the brake lines. The hard brake lines just need to be released by removing 2 bolts on the brackets that are holding the hard lines down. There is enough slack once you release the brackets.
#891
I've had a bunch of the expensive oil-filled analog gauges and they tend to be horribly inaccurate. I find that the cheap digital gauges are much better (kinda the way my expensive mechanical IWC never ran as well as a $5 Timex).
#892
Lots of GT3s and Thunderhill 5 mile today.
My brakes look to have odd wear. Thoughts?
Fronts have glazed looking lines. Weird wear on the outside.
rears are shiny looking. After 5 track days, pads have almost no wear.
#894
#897
The blue one. Despite what Tom (super nice guy) reported to Joe , I was running 3:33 on totally shot tires (6 days, no tread left on the inside fronts). Last session was consistent 3:36s with a passenger and sliding all over the place. Braking was still pretty strong to the end - I just don't like the feel. I'll probably leave the pads and rotors on, but order the setup Joe has and bring it with me, in case I need to do a "quick" change. (Maybe Tom will be able TH on 6/6-7)? I know I'm losing time on turn in speed. Still getting used to how fast I can enter a turn.
#898
Tom is the man, though.
Once the tires are heat cycled out, all bets are off. Lap times for the car have been sub-par the last 2 times it's been out there. The K spec tires still have tread on them with 6 track days/657 track miles/27 heat cycles. Grip was never as good as N spec (1.2 vs 1.3G) and dropped 1.0G after 18 heat cycles. I would advise against getting K spec MPSC2 if you can. Stick with N spec. Having tread left does me no good when grip is worse than plain street tires. The tires are coming off and getting swapped to Trofeo Rs!
#899
Hey man, 3:26 is totally believable for any of us!
p.s. The Able chevy guys were easily putting down low 3:20s. They were smokin' fast.
