Orthojoe's track build journal
#421
Received 1,259 Likes
Also, this car is just scary! It's not even the speed but rate of change of speed (braking and acceleration) - makes it hard to achieve consistency and makes driver second-guess committing to throttle or to brake release. For example, my issue is overbraking - know about it, see it on videos and data, but it's so hard to fix in practice.
#422
I love all the data analysis- came late to the party here and you guys all had fun disecting it already, so I'll leave my comments more to sharing some of my experience.
My 911 learning curve had me doing a lot of autocrossing that I think translates directly to confidence on the track- in some cases too much confidence! You will get a feel for that lump out in back and really learn how to use it in braking and cornering. Just a suggestion- won't help with turn 1 though, that's just experience and confidence that the car won't bite you at 100mph!
#423
Will trade for right seat time :-)
#424
Enjoyed following along, lots of valuable information. Quick question regarding the rennline toe hook you have. I recently purchased it and been having some fun with the gopro mounted. How many of the nylon washers did you leave on the toe hook when screwing it in?
#425
I used 3 nylon washers
#427
Interesting note on the MPSC2 that I noticed after reviewing the data:
The tires hold peak 1.3Gs when they are new, but drop down to 1.1Gs after 12 heat cycles. I was surprised to see the difference after reviewing, but unless my calibration of the accelerometer is wrong, I only had good grip for 2 out of 4 track days that the tires lasted me.
#430
#431
My favorite session that I can recall was a couple of months ago when I ran a 2:01.35 with the original street PS2's that had trackdays and backroads and street driving on them. Not only were they hardened but also had a 200lb+ friend in the car.
#432
yup.
Youre right. It is what it is. I may have to try trofeo Rs one of these days to see if they last more heat cycles. I care more about consistent performance after many heat cycles than ultimate grip...
At the pace you're going now, getting more than 2 good/fast days will be tough. You can still do more days but know what you'll have to work much harder for possibly slower times. Still fun to learn that way though.
#434
Pics of my tires after 4 track days and 560 track miles. 21 heat cycles. Judging by the wear pattern, the car could use a bit more negative camber up front than -2.7, and a more negative camber in the rear than -2.4.
Front:
Rear still looks usable. Needs more camber.
Front:
#435
Flip fronts and add camber.
I want to see how much more they go before cords.
Looks like a great tire.
More front wear than rear, so weird.
Maybe the better RS balance will even out the wear..
