991 GT3, GT3RS, GT2RS and 911R 2012-2019
Consolidated 991RS thread
Old 02-20-2015, 07:15 PM
  #4651
Petevb
Petevb's Avatar
Originally Posted by Drifting
Thanks Pete. Didn't realize this.
BTW, does the 991 RS have a 8,800 or a 9,000 redline?
8,800 per the doc at the top of the last page.
Originally Posted by Nizer
Yup, thanks. Meant change from 991 GT3 base in terms of redline. Same reason 500hp figure shouldn't have been a surprise/disappointment to so many. Fact is, RS 4.0 was pretty tweaked out as many knew.
Yea I got that. Just thought I'd do some math for everyone...
Old 02-20-2015, 07:17 PM
  #4652
usctrojanGT3
usctrojanGT3's Avatar
Received 4,070 Likes on 2,326 Posts
Sweet, the car has cupholders....I'm in. Why only 2 exterior colors?
Old 02-20-2015, 07:19 PM
  #4653
Drifting's Avatar
Received 1,321 Likes on 693 Posts
Originally Posted by Petevb
Mean piston speed at redline:
991 GT3 @ 9,000: 23.3 meters per second
997 RS 4.0 @8,800: 23.6 meters per second
991 GT3 RS @ 8,800: 23.9 meters per second
Ah, got it, thanks.
Pete, do you have any idea why the upcoming 991 RS engine will "only" produce 500 hp, the same as the 997 RS 4.0, even though the 991 RS engine is DFI?
Old 02-20-2015, 07:29 PM
  #4654
Bill_C4S
Bill_C4S's Avatar
Polycarb side and rear windows for the lucky ROW b*st*rds.
assuming this lucky ROW bastage can get one....i'll post pics
Old 02-20-2015, 07:30 PM
  #4655
Nizer
Nizer's Avatar
Received 1,886 Likes on 972 Posts
Logical conclusion is the presumed Lava Orange release color (plus the mystery purple if it appears) will be an upcharge just as the Grey Black release color on the 997 3.8 RS was.
  #4656
WSH
WSH's Avatar
Wasn't the 997 RS 4.0 redline at 8500 ?
Bill
Old 02-20-2015, 07:44 PM
  #4657
-eztrader-
-eztrader-'s Avatar
Originally Posted by markow
interesting....over at ferrarichat there is a lot of whining on the LACK OF new design of the 488GTB, the performance plus is taken for granted. here it is the performance of the RS that is in doubt....nobody worries about its design::))
peter
fixed it for u
Old 02-20-2015, 07:50 PM
  #4658
Petevb
Petevb's Avatar
Ah, got it, thanks.
Well...
Technically it's a little harder to make power as the bore to stroke ratio gets worse. The 997 RS 4.0 has a 1.28:1 bore to stroke, the 991 RS has 1.25, so it's gone slightly in the wrong direction, and all else being equal would be expected to cut into power output slightly.
I don't believe that's the real reason, however, because I don't believe 500 hp is a technical limitation as such. If a higher power output was a priority they would have found a way.
Every one of Porsche's cars needs to fit into a "box" defined by market positioning, etc. These cars need to leave room for their successors to outperform them, they need to outperform the cars below them in terms of price but not embarrass cars above them, etc. The dimensions of this engine were defined around eight years ago- the 9A1 appeared in 2008 with this exact bore (102 mm, in the 3.8S) and stroke (81.5 mm, in the 3.6L)... but they've never put this bore and stroke together before. This combination sat on the shelf until now, waiting for this particular model which required this power output. If the product roadmap said they needed it sooner, say that the 991 GT3 needed more power to compete with its rivals, we would have seen it sooner.
Now it's quite possible that it would have been quite expensive to improve on 500 hp in this application, due to the bore/ stroke limitations and the fixed parts dimensions I mentioned. I also suspect that they took the opportunity to reduces stresses and improve reliability somewhat over the 997 RS 4.0- those lifters for example were highly stressed in the old engine and didn't last long if the car was used flat out, and I'll bet the new rocker lifters improved that issue without losing power. Thus overall I'd again say I'd take this new, presumably lighter and more reliable 4.0 over the Mezger all else being equal. But I'd bet a lot of money that they could have made more power and they chose not to. And I'd bet similar money that it's really making more than the 500 hp that it says on the tin- not sure if that's more or less than the old 4.0 though.
Long answer to a short question...
Old 02-20-2015, 07:52 PM
  #4659
ATXGT3
ATXGT3's Avatar
. delete
Old 02-20-2015, 08:01 PM
  #4660
Petevb
Petevb's Avatar
Doh, you're right- I was pulling specs from the SharkWerks car with the same stroke.
997 RS 4.0 @8,500: 22.8 meters per second
Old 02-20-2015, 08:15 PM
  #4661
Macca
Macca's Avatar
Pete the alloy wings are the struts holding the rear spoiler not "fenders". Its a bit confusing...
Old 02-20-2015, 08:21 PM
  #4662
Petevb
Petevb's Avatar
Could well be, probably is reading it again...
They say it has carbon front "wings" too, not sure what those would be other than fenders. In German "fenders" are Kotflügel, often shortened to flügel... which translates to wing, hence I've often seen fenders called wings.
Old 02-20-2015, 09:31 PM
  #4663
Macca
Macca's Avatar
Hi Pete. I think the paragraph you are taking this from is all talking about the rear wing. The alloy wings are in black.
The differences between 991 GT3RS and GT3 have been highlighted in black through out the presentation. Many of the differences are trim, finishing, specification and materials changes.
The key differences appear to be Aero, Track, TYRE, Capacity and Output.
To be honest I was a bit disappointed to hear the engine does not rev to 9000 rpm. I know it is only a small thing but the 9000 rpm was a headliner for the 991 GT3 and it still wears this over the RS even if the later makes more power and is quicker. The thing that IM disappointed in is that the 458 Speciale can manage 9000 rpm with a larger capacity engine so I was expecting the 9000 rpm to be a NOT NEGOTIABLE part of the remit for the engine. I suspect the GT3 engine issue had a knock on effect to the max rpm for the RS. I have it on good information the fasteners form the RS were used in the replacement GT3 engines, so perhaps they were running to the edge of development here without total re design.
Otherwise the engine and gearbox seem to have no material details changes according to this slide over the 991 GT3.
Interestingly there is no mention of any mythical ram inducing 40 bhp Kawasaki vortex system operating in the rear fenders....
Standard colour choices are a little limiting. I can see many will have to pay extra for the Lava Orange with colour keyed rear cage (no doubt an exorbitant extra cost item!). Porsche are a bit cheeky.
In ROW trim the car will have cage, harness and plastic rear windows. It appears this spec was used to get the weight down to 1390/1400 kg. Hopefully a lower US price will reflect the missing parts.
Still an immensely exciting car and in the flesh it will look fantastic. Interestingly rear light apparently "tinted" along with front LED DRL if what I read is right so those will make a nice upgrade for 991 GT3 owners in time Im sure. The car sure is going to look great with all that extra detailing but hopefully not too busy....
Old 02-20-2015, 09:51 PM
  #4664
Petevb
Petevb's Avatar
Fair enough. Wishful thinking...
But the Ferrari has a slightly shorter stoke and smaller pistons. If we go by corrected piston speed (mean piston speed x (bore /stroke)^.5) we find the 991 RS's 8,800 rpm is the harder technical problem vs the 458 SP's 9,000 rpm (26.7 vs 26.2). Interestingly the 991 GT3 has an identical corrected piston speed to the RS (also 26.7). Perhaps Porsche felt it best not to push its luck after the GT3's engine problems.
Old 02-20-2015, 10:11 PM
  #4665
Drifting's Avatar
Pete, thanks for your thoughts on the RS hp output with the 4.0 DFI engine.
I agree that the simplest explanation is that Porsche is leaving room to be able make modest changes to the 991 4.0 engine, and then generate 525hp for the 991.2 RS.
Still it's disappointing that this brand new 991 RS will "officially" produce the exact same torque and hp as the old RS 4.0. Heck, even a small bump to 505-510hp would have been nice.
I'm not that tempted by the 991 RS, it's not that much of an improvement over the 991 GT3 for the relatively large price increase. Maybe I'll look at the 991.2 RS, if I feel that Porsche is really maximizing all their engineering in the engine, etc, of the 991.2 RS
Quick Reply: Consolidated 991RS thread
