Building a 3.0L Turbo motor.
#46
How will this affect the shape of the cylinder when things start to heat up? I discussed this idea with my engineering guy who not only has a machine shop, but also a MSc in mechanical engineering, and he refused to do it on the basis that the pin will expand and press on a points of the cylinder walls.
#47
#48
Yes, should have done that to start with. It's at:
http://www.ebay.com/itm/Porsche-944-...-/301040717931
Regards,
Regards,
GTS lights were from Deutsch 9.
#49
Sure is fun though! (a line adapted from "Mooseturd Pie" by Utah Phillips).
I'd thought they might be. Thanks for the confirmation. They're also in the lightening plan for the body, along with A/C and the other usual suspects...
#51
https://rennlist.com/forums/944-turb...ferrerid=55118 ??
Hey Sid -
Got that one. I thought you mentioned Shawn had a detailed DIY version of the build he cloned from yours? I haven't found that one yet.
Hey Sid -
#52
Hey Tom & Raj:
I sort of have a clue about what Raj did with his car from the Panorama article, but you (Tom) mention somewhere in the 3.0 Turbo Registry thread that you also have a build thread, which I haven't been able to locate. I started digging through all of your posts to find it, but with thousands of them it may take me awhile; clues gratefully accepted.
Same for you Raj. The article was great, so were the pictures, but if you have a build thread out there I'd love to read it.
Regards,
Regards,
#53
#54
Is this the method BMW used back in the 90's in some of their hi performance designs? I'd heard there might be a problem long term with the cylinders going "oval" over time?
#55
#57
I think there's at least one more out there I've heard of but haven't found yet by Tom M'Guinn.
#58
#59
After several days of great posts on the subject of 3.0L turbo build threads I thought I'd send out a list of where I m so far. This only includes known Rennlist sources, there is one other site "Clarke's Garage" that has some information on the subject as well.
Here's what I have:
3.0L Turbo/951 Build Threads from Rennlist (in no particular order) found to date -
"Pauly's go quicker project. (Data Logs!) ", Paulyy:
https://rennlist.com/forums/944-turb...data-logs.html
"Patrick's build thread. (IT RUNS!)", 333pg333:
https://rennlist.com/forums/944-turb...d-it-runs.html
"My unorthodox 3.0L 16valve build using native 2.5 engine", Blown 944:
https://rennlist.com/forums/944-turb...-5-engine.html
"project: turbocharging 944 N/A the proper way ", Voith:
https://rennlist.com/forums/924-931-...l#post11243276
"Hybrid stroker project", Blown 944:
"Refresh951's Hybrid Stroker - A Blown944 Design", Refresh951:
https://rennlist.com/forums/944-turb...44-design.html
"Refresh951's Hybrid Ultra Stroker Build", Refresh951:
https://rennlist.com/forums/944-turb...ker-build.html
"Blown 944 Hybrid Stroker DIY Guide", Refresh951:
https://rennlist.com/forums/944-turb...diy-guide.html
"3.0L build documentary", ModdedEverything951S:
https://rennlist.com/forums/944-turb...cumentary.html
"3.1l 16v turbo 91 mm stroker dry sump build", Duke
https://rennlist.com/forums/944-turb...ump-build.html
"Engine Building Blog", Tom M'Guinn:
https://rennlist.com/forums/944-turb...ding-blog.html
"My Porsche 944 S2 16 Valve Turbo Project", TurboTim3
https://rennlist.com/forums/944-turb...project-6.html
"3ltr twincam engine, coming together", JET951
https://rennlist.com/forums/944-turb...ml#post6855064
I think some of these might be threads that were started in one place then restarted in another but I can't be sure, perhaps their respective authors can comment?
In addition to actual build threads I've also included the following threads on the subject of building 3.0L Turbo engines for the 951 that (in my opinion) contain valuable advice given by author's of the build threads mentioned above to potential builders.
"951 3.0 l 8V engine building questions", ajrlredondo
https://rennlist.com/forums/944-turb...estions-3.html
I'm also including a very good thread on building a 2.5L 16V turbo that started as a 3.0L build but changed direction mid-course. There are some very good comments in it that I think apply to 3.0L builds:
"Christopher's 16v 2.5L 951 project", Refpotsirk
https://rennlist.com/forums/944-turb...l#post11960098
Thanks to all who've participated in this documentation project so far. I hope to add to it over time (most especially with my own) as new threads are started and discovered.
Regards,
Here's what I have:
Regards,
