project: turbocharging 944 N/A the proper way
#271
Thats better
#272
Removed block studs from 2.7 block today.. P I T A!
Luckily threads look like they survived.
#273
http://prema.com.pl/assets/Katalogi/...plorer_ENG.pdf
Some good info on SKF bearings.
http://www.henkelna.com/us/content_d...032010_Web.pdf
And on Loctite application, types and strenghts.
#274
![Talking](https://rennlist.com/forums/images/icons/icon10.gif)
Crankshaft came from polishing
#275
Interesting comparison of 2.7 block vs 2.5 turboS block.
Looks like Turbo S (M44/52) came prepared for stroker kit from factory..
Griddle numbers are matching.
#277
This one had cast rods too. I think they just slapped together what was on the shelf at any given moment..
#278
Bought another essential tool today. ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Ceccato Beltair dual piston 400 volt 100L 3hp air compressor.
10L I used until now is fun for pumping tires and painting small things, but it just cant cope with air impact wrench or similar tools.
![](http://cdn.clubafaceri.ro/clients/37/84473/54/compresor-ceccato-cu-piston-100l-2462030_big.jpg)
#279
Pistons are here
#280
Finally everything is here so it is officially 3019ccm turbo project from now on
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
#281
Some (bad) pictures of 944 related broschure I found today. Will have it scanned in high resolution.
#282
#284
I bought new turbine since K27#6 has too small turbine wheel & hot side for 3.0 and since I flirt with twin scroll idea for a long time, I thought BW K29 with T4 1.0 A/R divided turbine housing will be a good idea. Turns out this thing is way bigger than I thought, it is huge. I wonder if (with custom intake plenum) it can be shoehorned to the stock turbine spot somehow.. I know there is at least one rennlister that used K29 at one time.
The most important step I must make and I am very hesitant about it is alusil re bore and finish. I have the feeling I will end up with cross hatch pattern too. Unbelievable that I do not find one shop in this f****ng country that would do this job and guarantee for it.
