928 Forum 1978-1995
Sponsored by: 928 Specialists
So what did you do to your 928 Today......
Old 06-28-2017, 11:48 PM
  #7156
Bertrand Daoust
Bertrand Daoust's Avatar
Received 1,320 Likes on 500 Posts
Installed the pump and belt today
Got some nice help from my daughter.
Thanks Britanie.
Also checked the timing. Thanks Luc for the 32V'r.
Everything's perfect.
0 degree driver side.
-2 degrees (retard) passenger side.
Old 06-29-2017, 11:01 PM
  #7157
MaxPower2000
7th Gear
MaxPower2000's Avatar
Put in a new head unit, wanted a bluetooth connection to play music off my phone. The mic works surprisingly well for handsfree calls or yelling at Siri.
PO had spliced into the hatch release parking circuit (1A fuse) for the constant 24V power for his aftermarket install .... naturally that fuse was blown and the stereo reverted to factory settings every time I shut the car off. The rest of the stereo install is pretty nice so I was a little surprised at that splice selection. Relocated that connection and the new unit works great.
Old 06-30-2017, 04:39 PM
  #7158
hlee96
hlee96's Avatar
Costco run!
Old 07-02-2017, 08:25 PM
  #7159
Bertrand Daoust
Put everything back together after the water pump change.
Everything looks good. Not leaking and engine coolant temperature is normal. Now I need to drive the car to make 100% sure all is good.
New pump installed.
Old 07-02-2017, 09:05 PM
  #7160
MainePorsche
MainePorsche's Avatar
Diagnosed issue with passenger side washer system, and formulated a mitigation plan.
Checked ATF level. Not a stitch of a loss since putting in the new GB unit.
Old 07-03-2017, 12:05 AM
  #7161
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,761 Likes on 1,341 Posts
Rebuilt some axles. Rebuilding axles sucks.
Old 07-03-2017, 10:43 PM
  #7162
syoo8
syoo8's Avatar
My goodness, Bertrand-- you could serve dinner on the top of your oil pan it is so clean!
Old 07-03-2017, 10:46 PM
  #7163
Lauris50
2nd Gear
Lauris50's Avatar
I'm thinking of getting a 991.2 Cayman or a 911,any advice given would be very much appreciated. Cheers!
Lauris
Old 07-03-2017, 10:49 PM
  #7164
Bertrand Daoust
Thanks Scott.
But the pic makes it look cleaner though...
Old 07-03-2017, 11:23 PM
  #7165
flipstah
flipstah's Avatar
Door cylinder repair was a challenge, but we made it work!
Old 07-04-2017, 12:01 PM
  #7166
Wisconsin Joe
Wisconsin Joe's Avatar
Lauris
Well, my first advice would be to post that question in the Cayman forum or one of the 911 forums (there are several).
This is the 928 forum.
And on topic:
I drove mine.
125 miles each way on a weekend round trip.
All my gear fit nicely, and the drive down on Friday and back on Sunday was just fun.
Old 07-06-2017, 08:49 PM
  #7167
PorKen
Inventor
PorKen's Avatar
New 550 CFM, 145 MPH, 58v electric blower!
Took out the center dash vent, closed the side vents, turned on the engine and A/C and reverse blew out the evaporator. Then blew out a whole lot of stuff out of the 'leaf collection zone'. Amazing what comes out of the nooks and crannies with hurricane force winds!
Can't wait to use the blower for drying after washing the car. Certainly cleans out the interior in a jiffy.
Old 07-06-2017, 09:46 PM
  #7168
OTR18WHEELER
You can call me Otis
OTR18WHEELER's Avatar
I feel so bad, no pics of working on mine, 'cause I drive it all the time.
but I did scare off the tailgaters today when I went a little slideways when the shark came up for air while hitting 2nd.
...yeah the road was wet, ok.
Old 07-07-2017, 09:24 AM
  #7169
Adk46
Adk46's Avatar
Today, I'm putting together a bag to take to Tass's. It will include a cordless drill and a small screw. The long story:
I'm at the best Indy shop around, in Albany, for a cars and coffee sort of thing. I have the owner look at my car under false pretenses. I actually want his advice on how to keep my radiator hose from slipping off the engine nipple, right side. He tightens it up, says I hadn't done it right. "You can do all that work on your intake, but you don't know how to tighten a clamp?" Ouch. It's true, I only know the proverbial "do not over-tighten", where there is an implied "do not under-tighten", altogether useless advice that should be expunged from the literature.
But it nearly slips off again on the way home.
I finally realize I never installed the wire thing that fits in the groove. It should be in a bag in a box on a shelf - maybe the powder coater lost it. The smaller hose nipple for the heater just has a nub on it, so that's where the drill and a small round-headed screw come in: I crudely created one nub already. So far, so good. But I'll be prepared to install another.
We'll see if the anti-corrosion additives in my coolant can handle this galvanic horror.
Naturally, I will accept the donation of a proper wire thing from your box of odds and ends.
Old 07-07-2017, 09:36 AM
  #7170
Petza914
Petza914's Avatar
Received 6,603 Likes on 4,198 Posts
How about creating a clamp using a Clamp-Tite tool and some stainless wire.
Quick Reply: So what did you do to your 928 Today......
