So what did you do to your 928 Today......
#6676
I finished off my dash refresh, as I'd left it in a bit of a state: no horn, some mis-oriented LEDs, and a blown fuse. Now very pleased with the results, good thing too because it was a bit of a trial.
#6677
Chronic Tool Dropper
Buttoned up all but the very last of the MM/OPG refresh project tasks. Just need to drop it on the ground and torque the rear carriers for the front LCA, drive it a bit to fill/purge the rest of the steering system. Get it to full temp with the new oil. Then roll it into its winter hibernation spot.
Still on my sometime-this-winter-before-spring list:
-- replace transmission mounts
-- door panel reinforcement plates
-- brake fluid replacement
-- annual electrical maintenance
The county decided to start putting mag chloride liquid de-icer in some of the roads already. It must be winter!
#6682
Removed the RMS on the M28/11 donor motor.
Cleaned all the AC line ends.
Started the new insulation on the firewall
Painted various brackets and the shock tower support.
#6686
Time for sleep.
That time of year again...salt has been applied to roadways and car will not be exposed.
Leather treated and Saran wrapped, steel wool to exhaust and air intakes, etc...
