928 Forum 1978-1995
Sponsored by: 928 Specialists
So what did you do to your 928 Today......
Old 04-11-2013, 08:00 PM
  #3751
Livio928
Livio928's Avatar
Those wheels look great!
Old 04-11-2013, 08:01 PM
  #3752
Texbuckeye
Texbuckeye's Avatar
I love those wheels!
Old 04-11-2013, 08:05 PM
  #3753
sharkbate
sharkbate's Avatar
Very Cool looking wheel.
Old 04-12-2013, 09:26 PM
  #3754
dr bob
Chronic Tool Dropper
dr bob's Avatar
Hey, those are MY wheels!!
Had them on the car for over 10 years now, still look great on the black car.
You'll want to trim the wheel bearing caps maybe 5mm's so the center caps will go on.
Old 04-12-2013, 10:41 PM
  #3755
UncleMaz
UncleMaz's Avatar
Springtime for gearbox and Germany....
Old 04-12-2013, 11:43 PM
  #3756
frankle951
frankle951's Avatar
Had a free day, but the temps was around 48 today, tomorrow temps in the 60s, will get my shark out !!!!!
Old 04-14-2013, 12:08 AM
  #3757
928porschemangreg
928porschemangreg's Avatar
New Air filter. Needed it but old one from PO was upside down. New oil and filter-15w50 and ZDDP additive from STP. Runs butter smooth and quiet now. Oil drain had no washer, got one now. Next, Spacer for AC compressor clutch so it stops dragging.
Old 04-14-2013, 01:56 AM
  #3758
JohnInTexas
JohnInTexas's Avatar
It's spring in Texas...I washed off the garage dust and took a few photos
Old 04-14-2013, 11:02 AM
  #3759
NickT
NickT's Avatar
Put new hood struts on..
One was completely shot..
Old 04-14-2013, 06:41 PM
  #3760
SeanR
SeanR's Avatar
Might be easier to say what I'm not doing to my car this week, but I thought I'd share my trans mounts with you.
And how bad my TT was.
Old 04-14-2013, 09:23 PM
  #3761
ammonman
ammonman's Avatar
Think of it this way Sean, at least it is a snap to get the shaft and bearings out. When I did mine they were STUCK in there.
WIDTM928T content: Finished my A/C refresh with all new o-rings, four rebuilt hoses (didn't do the engine bay suction hose. That will have to wait for the engine to be out.) new expansion valves, compressor re-seal with fresh PAG oil, and a complete system flush. The amount of dye and sealant snot that came out was frightening. Re-charged with 36 oz of 134a and she is now frosty and running the right discharge pressure since all the excess oil is out.
Mike
Old 04-14-2013, 10:06 PM
  #3762
VegasGnome
VegasGnome's Avatar
I installed the Lizard short shift kit. The bushing on the drivers side of the shift coupler was completely gone. So I figured as long as I have to change the bushings, I might as well improve the shifting too. Impressive improvement to the way it shifts now. This is the way it should have come from the factory.
Old 04-14-2013, 10:08 PM
  #3763
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,506 Likes on 1,412 Posts
Sean dont throw away those old trans mounts,
someone may be able to replace the rubber on them for less than the cost of new mounts.
Thats a really nasty TT surprised it lasted this long,
I would clean it and then look carefully for cracks where the turned area is to the splines since it has all of that rust
Old 04-14-2013, 10:52 PM
  #3764
mickster
mickster's Avatar
Changed lower front ball joints on my car. Changed exhaust to Borla on another car.
Old 04-14-2013, 11:00 PM
  #3765
Kevin in Atlanta
Kevin in Atlanta's Avatar
Aside from replacing the crumbling brake/abs barrel connectors I rerouted the PO's stainless steel brake lines. Got rid of the plastic zip ties, routed the hoses through the stock location and fabricated a locking clip to hold them in place.
Before and after:
Quick Reply: So what did you do to your 928 Today......
