So what did you do to your 928 Today......
#2491
With spring on the way, fired her up for the first time this year :-)
![](https://lh4.googleusercontent.com/-Wi0GVjduPzE/T25HxjH7-MI/AAAAAAAABhQ/2gmWgFCLssE/s800/IMG_1421.JPG)
Then finally fitted the '044' pump that's been sitting on a shelf for almost 2 years with a little help from a 'Murf' fitting kit....
#2492
First, got her pulled over for speeding. Second, took her in to a specialist for the intake. Third, ordered an ignition wire set, new distributor cap and rotors for when I get her back. Fourth, planning other in-the-garage repairs (new plugs, fuse panel clean and ground clean) before taking her in again for the timing belt and water pump next month.
Oh, and also looking for 928 windshield glass with the antenna inside for an '86 928S 32V.
Just a thought,
Michael
#2493
Yea, I have a later window installed and without the antenna I get quite a bit of static. I don't want to add an antenna on the roof (aesthetic reasons, I like the sleekness of the 928 so I'd prefer her to be fin-less) so I'm on the hunt for original glass. It's not a high priority but I ask around in case I can find one for a good price.
#2494
Rest in Peace
Finally opened my box of new Aero mirrors, and discovered it is a KIT!
Has anyone assembled these monsters before and is there a special sleeve to hold the collars in when putting the base and body together?
#2495
Drove 750 miles in our 86. Very smooth ride.
Put my USA 84 5 speed into the hands of good friends who will decide if they will prepare it for a new life on the track. They miight occasionally need advice from many of you to do this efficiently. d
#2497
Worked on air intake designing adapters.
Messed with tow hook plug same thing seized.
Might try left handed 3/8" or 7/16" tap and left handed bolt
before drilling it completely out yet.Rather try the bolt incase
if does come out as if bolt breaks can just drill out again
where an extracter would be too hard to drill.
#2498
Rest in Peace
http://www.928intl.com/repair/gtsmir...eromirrors.pdf
Here is the instructions I used, shows how to make the "tool" to assemble Base to mirror head. Worked pretty well.
Bob
Bob
#2500
Electron Wrangler
I'd have thought an extractor would just chew up the aluminum plug before it would ever just break off... anyway another option for you - many (5 so far) have used it already successfully.
Drill & Dremmel (carbide tip) then chase the threads out with the tap...
Alan
#2501
been waiting to post until I got a decent pic to share.
in final stage of completing:
MM
delrin rack bushings
OPG and GTS baffle
tie rod ends and steering rack boots
lower ball joints
shocks
headers w/ dual 2.5" in and single 3" out magnaflow.
final fitting of the fab'ed piping from the headers to the dual in muffler. then just run 3" the rest of the way back.
MM
OPG and GTS baffle
lower ball joints
shocks
![jumper](https://rennlist.com/forums/graemlins/jumper.gif)
#2502
Pulling out the nasty interior.
Figured out why the passenger seat wouldn't move. There was a set of keys under it.
What do I do with them?
My head hurts.
My head hurts.
![Mad](https://rennlist.com/forums/images/smilies/mad.gif)
#2503
Found three severed wires in driver door wire harness, Repaired and now keyed entry/closure locks/opens all as it should. While there, did 'cheap fix' with a nylon tie for the window rattle in early phase of opening - works like a charm. Also readjusted tension on inner door handle - now no play and remains flush
#2504
Chronic Tool Dropper
#2505
Cleaned the aluminijm rear uprights/hubs with a clener basedcon D-limonene. This works remarkably well and smells good too! Now how can I prevent these aluminium parts from oxidizing when they get wet? Any ideas not involving painting in any wy?
