928 Forum 1978-1995
Sponsored by: 928 Specialists
So what did you do to your 928 Today......
Old 02-04-2012, 03:20 AM
  #2221
928mac
928mac's Avatar
I replaced the little hatch release symbol that looks like a K car
Old 02-04-2012, 10:06 AM
  #2222
sudandp
5th Gear
sudandp's Avatar
Finally have all the current fluid leaks taken care of. Last one was the oil pressure sending unit; had it replaced and all is well....except now the oil pressure guage on the dash is pegged all the way above "5" and doesn't come down to mid-guage at idle??? Could the shope have replace it with the wrong unit??
Old 02-04-2012, 04:22 PM
  #2223
hb253
hb253's Avatar
I cleaned the ground point under the hatch and vacuumed up many bits of decrepit foam backing while I was in there.
Then I tested voltages. Battery seems a bit low at 11.8 volts (45 degrees outside). With engine at idle speed, I get around 14.2 volts. The belt for alternator may need some tightening, I can easily deflect it with my thumb.
Finally, found out that the low profile ramps that work with my 911 won't work as is due to the spoiler. Looks like I'll have to cut some 2x12's.
Hugo
1984 928S
1979 911SC targa
Old 02-04-2012, 04:32 PM
  #2224
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,806 Likes on 1,369 Posts
i replaced the (broken) dome light in the GT in 2006, right after buying the car. I have maybe used it 3 times in the ensuing 5 years. Went to turn it on the other night, broke the thing, which shorted against the roof and blew the fuse for the gauge cluster. Sigh. Tried to superglue it back together today, we'll see.
"No, officer, actually I don't know how fast I was going..."
Old 02-04-2012, 06:36 PM
  #2225
John Speake
John Speake's Avatar
Drove my 928 today as the roads were dry, although lots of salt on them. Thought I might just as well give it a run as snow was forecast tonight. It came right on time 4" and still snowing.....
25 miles to go to 120k miles.
Old 02-04-2012, 06:53 PM
  #2226
rgs944
rgs944's Avatar
I started to sew my leather pod cover together today using Jerry Feather's patterns. I still do not know how it is going to turn out but I am optimistic. Its gotta be better than a cracked original anyway and smell a lot better.
Old 02-04-2012, 07:14 PM
  #2227
pacovinoly
pacovinoly's Avatar
Thanks to Greg Brown and Travis at Precision Motorwerks. They're the best!
1. Rebuilt Torque Tube.
2. Installed Constantine flex plate clamp.
3. New Transmission Lines
4. New Heater Hose and Control Valve
5. Fixed A/C leaks and refilled with R134
6. Installed RMB
The PO had a rat living inside the car and it had eaten most anything that wasn't metal, so I spent half of today cleaning out the mess it left behind.
The car is much better now but I have a feeling I'm starting to get underwater on it.
I have to believe that's a common feeling around these parts?
Old 02-05-2012, 01:43 AM
  #2228
IrishLegend
IrishLegend's Avatar
PKlutch installed.
Old 02-05-2012, 02:31 AM
  #2229
Jadz928
Jadz928's Avatar
Interesting point of reference. When considering alternate parts to GP, I often convince myself to use GP by saying "if it lasted 20 years the first time around, I 'd be happy to get 20 years out of it's replacement."
Not always the case as the part may have failed 15 years sooner than I thought.
Another ref. Point: GP hood liner, replaced in '04 already show signs of failing the outer skin.
Old 02-05-2012, 09:52 AM
  #2230
steve322s
steve322s's Avatar
got an alignment on a hunter alignment machine!
Old 02-05-2012, 10:29 AM
  #2231
Landseer
Landseer's Avatar
Drove the 84 Euro to Jadz 928's, where he adjusted the idle for me.
Saw the no-sunroof silver 78 Euro -- nice car!
Took another look at white 928 No.1, patiently waiting for its turn in the repair bay.
Old 02-05-2012, 08:20 PM
  #2232
Ducman82
Ducman82's Avatar
Installed the LSD unit in my trans today. just need to get some gear oil tomorrow, and get that pig back in the car.
Old 02-05-2012, 08:33 PM
  #2233
Alan
Electron Wrangler
Alan's Avatar
With what?
Alan
Old 02-05-2012, 08:36 PM
  #2234
jej3
jej3's Avatar
Fuel flow test and measured 1.1L after 30 seconds... FAIL?
Old 02-05-2012, 10:03 PM
  #2235
thelaurie
thelaurie's Avatar
Drove it to O'Reilly's after charging the battery all night. Ordered a new alternator, should arrive on Monday. Learned how to install the 53B relay, and learned how to install a new fuel level sensor.
Then I smacked her on the *** and promised her she'd be back on the road soon.
Wrench, drive, smile, repeat.
Laurie
1988 S4 Granite Green Metallic
Quick Reply: So what did you do to your 928 Today......
