928 Forum 1978-1995
Sponsored by: 928 Specialists
DEVEK - SUPERMODEL Tech Session and Gathering, March 26-27
Old 03-30-2005, 01:49 PM
  #196
mspiegle
mspiegle's Avatar
Originally Posted by CMW
Mike,
I am confused whose car walked away from your car... was that my car?
I'm just lost in the proverbal sauce.
Speaking of which has anyone seen a Silver GTS supercharged... missing since last Tuesday.
Last seen somewhere in California...
Reward if found.
Ok, I did a few runs against Jonathan in my car. My car is quicker in 2nd gear, but the gap starts to close in 3rd gear. By 4th gear, your car pulls away from my car VERY hard. This thing is definately a monster.
Old 03-30-2005, 01:50 PM
  #197
PorKen
Inventor
PorKen's Avatar
Originally Posted by mspiegle
I know one reason is that its a little safer to spin the dyno slower (instead of at 150mph+).
The Dynojet can overheat it's brakes(?) too, if run at Porsche speeds too long.
Old 03-30-2005, 03:01 PM
  #198
Th Dude
Th Dude's Avatar
Whoah...what a weekend...
I am home, thank you for asking, Jim.
My car...FAST...CRAZY FAST! How much HP/torque exactly, will be determined later, once I get to a dyno.
The effort and comraderie I witnessed this weekend was inspiring. Although having been posting on the Rennlist for over two years (and lurking even earlier), this was my first opportunity to meet many of the people face to face. An amazing and diverse group indeed.
I would especially like to thank...
Andy, for his relentless determination and tireless efforts to transform my one and only pride and joy 86.5.
Mike, for sacrificing personal obligations and helping me from the very beginning to the VERY end. The same can be said for Jonathon.
Marc and Susan and the entire Devek team (Bob, Ross, Brian, and ALL of the others), for opening their "house" and making everyone feel very welcomed to be there. Their professionalism, hospitality, knowledge, friendliness and patience are truly second to none.
Jim, Loren, Bill, Seth, Louie, Steve, Anders, Tom, each helped me in individual and unique ways....advice, support, selflessness, humour, and hope. Thank you.
Old 03-30-2005, 03:19 PM
  #199
Bill Ball
Under the Lift
Bill Ball's Avatar
Derek:
It was a pleasure to meet you and see your SC take shape. Be careful - you've got a fully loaded gun with a hair trigger there.
Old 03-30-2005, 03:30 PM
  #200
Seth W
Seth W's Avatar
Derek:
Same here, great to meet you in person and put a face to a name to an avatar. The community we have is about as unique as the cars themselves, and perhaps makes the car secondary at times in the context of the community. ENJOY the car, be safe, get to a dyno, get to a track and find out what it can do.
Best,
Seth
Old 03-30-2005, 04:06 PM
  #201
Fastest928
Fastest928's Avatar
The DynaPak is about 3-5% lower in hp readings, and when you consider the general tolerance window of these machines, it is really insignificant.
2 years ago, with stock manifold, I dyno'd the Whtie CAr at 500 rwhp on a dynojet, on Toms dyno over the weekend, made 486 rwhp at two AF ratios 14.1 and around 13.4-13.7 ... the former was very sensitive to changes in fuel and spart, the later was very insensitive.
Old 03-30-2005, 04:20 PM
  #202
drnick
drnick's Avatar
cool thread, you guys are having toooo much fun with these twinscrews. keep it up!
Old 03-30-2005, 05:26 PM
  #203
mspiegle
mspiegle's Avatar
Well, I didn't get supermodeled @ DEVEK, but I did make a bunch of runs on the dynopak. I have advanced ignition and a couple other mods which will remain nameless to make a little more power than i'm supposed to. I suppose I should be making 350rwhp on a dynojet.
I'd also like to make note that I have the devek radiator and twin-fan setup and after 10 runs without much of a cool-off period, the temp gauge was reading right at the first line. I could grab the radiator hose with my hand (that's how cool it was).
Old 03-30-2005, 05:40 PM
  #204
Bill Ball
Under the Lift
Bill Ball's Avatar
Mike:
How do you explain why our cars differ so much? You have higher peak HP while I have more down low. My torque, especially down in the lower RPMs, is far higher. I know mine is S4, but we are sharing the same intake now.
Old 03-30-2005, 05:45 PM
  #205
Chris
Chris's Avatar
Bill you sure you arn't getting some belt slippage ?, everyone esle's graphs keep climbing, yours levels off somewhat.
Chris
Old 03-30-2005, 05:51 PM
  #206
mspiegle
mspiegle's Avatar
i'm retarding my ignition down low for hard-launching, and advancing it up top for some extra juice. Your supercharger is also in MUCH better shape than mine. I've already got close to 20K miles on my setup, and the SC was very used before then.
Notice how your car makes more boost down low?
Old 03-30-2005, 05:52 PM
  #207
mspiegle
mspiegle's Avatar
Also, lets not forget the difference in cams. I think I heard somewhere that the 85/86 cams are a little more peaky than the S4 cams. Can anyone verify that?
Old 03-30-2005, 06:19 PM
  #208
Bill Ball
Under the Lift
Bill Ball's Avatar
Ok, that's good. I like the low end torque for impressive burnouts.
Chris: I was getting almost exactly 5 lbs all the way up, but the belt maybe could use some tightening.
Mike: I see yours climbing slowly from 3 lbs. boost, while mine starts at 4 and gets to 5 sooner. You do have a substantial torque peak whereas mine starts down very low in the RPM range and falls slowly off from there.
Old 03-30-2005, 06:57 PM
  #209
Jim_H
Jim_H's Avatar
It looks like Bill's holds around 5lbs throughout while Mikes tapers down after 5k RPM's.
My psi graph was a bit of a rollercoaster hitting almost 7lbs once
but pulsating around 6 1/4 to 6 1/2lbs so we knew we had slippage.
Hey Mike, what kind of lube did you use in my SC? And how long is the dipstick supposed to be?
Old 03-31-2005, 01:27 PM
  #210
Fastest928
Fastest928's Avatar
Hey guys, anyone find a Stahwille 1/4" drive short socket and a 11mm snap on 3/8" deep in their gear bag?
Thanks!
Quick Reply: DEVEK - SUPERMODEL Tech Session and Gathering, March 26-27
