Project V8- VT951's Bitchin' Camaro
Old 02-20-2010 | 01:06 PM
  #151
gt1scca's Avatar
gt1scca
Originally Posted by vt951
The upright tube is .090" wall. I was looking for .125", but this was the closest they had at the time and seemed thick enough.
Try here Alan...
http://www.metalsdepot.com/products/hrsteel2.phtml?page=rndtube&LimAcc=%20&aident=
"T2112120 / 1-1/2 OD x .120 wall x 1.260 ID / 1020 DOM Structural Round Steel Tube / 2.0 Ft. / In Stock / $15.92"
Easy to deal with, and not that far away.
Firewall Plate shipped this AM, USPS Priority. The instruction sheet may be overkill, but it is detailed. I included a drill template just in case, but welding is your best bet.
I'll add tracking info through PayPal shortly.
What are your plans for VSS? I put together a nice VSS Kit...
I can get you one early next week if you'd rather not mod a cam gear.
Thanks Alan.
Old 02-20-2010 | 01:12 PM
  #152
vt951's Avatar
vt951
Originally Posted by gt1scca
Try here Alan...
Thanks Alan.
I'm planning on using one of the stock abs speed sensors that came on my 968 spindles. I think Tom had the ECU programmed to use the pulse rate on the porsche speed sensor, so I just have to connect the 2 wires on the chevy harness to the two wires on the porsche sensor.
Old 02-20-2010 | 01:15 PM
  #153
V2Rocket's Avatar
V2Rocket
Rainman
Try here Alan...
Thanks Alan.
can you clarify something for me...is the "basic kit" absolutely everything necessary to do the swap, minus an engine, pan and headers?
Old 02-20-2010 | 03:13 PM
  #154
gt1scca's Avatar
gt1scca
I am not pushing this here, merely answering your question V2...
Simply put, not completely.
There is a decent sized list of other parts needed to complete the Conversion, included in a "shopping list" (with part numbers) in the Manual. Other necessary parts resale and markup doesn't make financial sense for the customer, and some of the other parts (i.e. suspension and brake upgrades) are based on your individual desire. There are a solid 30+ "small parts" also needed, from clutch, headers, brake master cylinder, temp. and oil pressure senders, bellhousing, throttle cable, intake accessories, coolant hoses, and so on.
The Basic Kit includes:
C5 BELLHOUSING ADAPTER
THE PORSCHE® 944 V8 CONVERSION MANUAL
ENGINE UPRIGHTS
ENGINE SET-BACK PLATES
C5 CLUTCH CONCENTRIC SLAVE HOSES & FITTINGS
C5 CLUTCH CONCENTRIC SLAVE ASSEMBLY
REMOTE OIL FILTER RELOCATION KIT
WILWOOD 260-7563 MANUAL MASTER CYL. CONVERSION PLATE & PUSHROD
MODIFIED MOROSO #20140 LS1 / LS6 OIL PAN
The Basic Kit consists of the hard-parts required to install the V8, a manual brake conversion (for clearance), etc. Some of the options can be purchased elsewhere for less if you know what you need, and all machined parts technical drawings are included in the Manual for the individual willing to machine or have machined the custom parts. The "Kit" just puts the custom machine work and related items in one place, for those who wish to "click-a-Kit".
Suspension mods, wiring details (including pinouts), brake options, and other end-user options are also included in the Manual. I put as much as I could into 128 pages to make the info available, and to give the Conversion world another option. I still say "Save money and do it yourself", but at least with the Kit, yet another option exists.
You can email or call me from the Contact page if you wish, to keep Alan's thread open to his progress.
Tom (968ls1) has been my greatest resource so far, and he knows the 944 V8 like his own kid.
Tom,
I sent you a "freebie" for review with your FW plate. Some things have already changed, BTW. Let me know what ya think...
Alan,
Just checking. ABS sensor is easily set-up in HPTuners.
Back to the show...
Old 02-20-2010 | 11:41 PM
  #155
arthropraxis's Avatar
arthropraxis
If it isn't too much trouble, when you mod the headers could you snap some pictures and write down some measurements? More options are always better as I have not made a decision on headers yet.
Old 02-21-2010 | 08:35 AM
  #156
vt951's Avatar
vt951
Sure, I'll try to do that. Here's a pic of what someone else did to get S&P headers to fit.
Old 02-21-2010 | 10:59 AM
  #157
arthropraxis
Cool, I know who has that set. I thougth they were a complete custom fabrication.
Old 02-21-2010 | 11:01 AM
  #158
vt951's Avatar
vt951
For comparison, here are the unmodified headers in the same orientation as the modified ones shown above. Looks like some major mods...
Old 02-21-2010 | 11:31 AM
  #159
DVC's Avatar
DVC
Just a BTDT, but those Street & Performance headers are fine for the small motor, if you keep it mild, but were very restrictive on my LS2. JPR (LS1 with TEA heads and Lunati cam) only put down 370 through them. They are an inexpensive way to get started and with V-bands they never leaked on me.
People talk **** about Renegade but their LS headers fit well, are inexpensive, and make good power. Custom exhaust is not cheap and not all good exhaust fabricators want to deal with these cars.
Old 02-21-2010 | 01:14 PM
  #160
vt951's Avatar
vt951
I'm probably "only" going to be around 350 rwhp, so I think they'll be just fine for me.
Old 02-21-2010 | 01:18 PM
  #161
xsboost90's Avatar
xsboost90
you coming over today- keep calling but no answer?
Old 02-22-2010 | 01:20 PM
  #162
vt951's Avatar
vt951
Props to Dan as well as Andy Kihm for some awesome fab work last night. We had to cut all 4 tubes off on the driver side header, and they pieced together #3 and #4 to clear the steering shaft. Looking really great. Ordered some U pieces from Jegs and hopefully will get #1 and #2 pieced in tonight.
Old 02-22-2010 | 02:03 PM
  #163
V2Rocket's Avatar
V2Rocket
Rainman
just run it with open exhaust ports. that should sound interesting
Old 02-22-2010 | 03:51 PM
  #164
vt951's Avatar
vt951
When we first saw how many tubes interfered with the steering shaft, that was looking like a very good option.
Old 02-22-2010 | 03:52 PM
  #165
originalmotorhead's Avatar
originalmotorhead
Side Pipes !!! In old Stingray Fashion. sounds like you guys are on top of it. awsome !!
Tom
Quick Reply: Project V8- VT951's Bitchin' Camaro
