OEM Navigation Retrofit DIY
#107
Managed to get everything sorted per the thread and now I’m up and running. Installed a GPS antenna today just behind the sport chrono clock and updated the maps. Thanks again for all the work put into this!
#108
That's great news, so did you update to the 2021/22 NAR maps as well?
#109
bighoward503 (07-12-2022)
#110
Originally Posted by Westcoast;[url=tel:18245303
18245303[/url]]That's great news, so did you update to the 2021/22 NAR maps as well?
#111
Did you buy the OEM GPS antenna? If you can provide a link for it, that would be great info for others. I will be helping another member with this and need to confirm if the cluster coding is already there.
#112
Originally Posted by 718socal;[url=tel:18245342
18245342[/url]]Did you buy the OEM GPS antenna? If you can provide a link for it, that would be great info for others. I will be helping another member with this and need to confirm if the cluster coding is already there.
Eightwood Waterproof Active Navigation GPS Antenna Fakra Blue C Female Right Angle Magnetic Base Compatible with Ford VW Audi MFD2 RNS2 RNS-E Car Stereo Head Unit https://a.co/d/2aUzVLQ
#113
Anyone in the DFW tried this yet? It would be cool to see the differences in person....
#114
CaneTLOTW (07-13-2022)
#115
@West Coast is right. There should not be any differences
I'm not a tech / coding person either, so trying to determine if the juice is worth the squeeze.
#118
It's really easy. Just pop a 3rd party antenna (Fakra Blue C Female Right Angle) behind the sport chrono cover. If you have a center speaker there should still be enough space. https://rennlist.com/forums/718-foru...l#post17704536
#119
Originally Posted by Bill Mitchell;[url=tel:18252483
18252483[/url]]I've loaded all the files with the SD cards, only to find I don't have a GPS antenna, I thought carplay meant the antenna was present. I've ordered one, can you give me any tips on removing the clock panel ? I just don't want to break anything in getting it out. Thanks.
#120
