OEM Navigation Retrofit DIY
718socal (11-27-2023)
#782
#783
Hi All -
I'm having trouble with this install on 2021 CGTS, hoping someone can help. I downloaded this file and unzipped contents to SD card: MHI2_US_POG11_K5186_1_MU1476_AIO_20220723
I followed the instructions in the video from post #56 and everything seemed to work fine thru the step of loading the final script and reboot. (see first pic) When the home screen came up after reboot, I didn't have all of the icons that I expected, and holding the Car + Tuner physical buttons did not bring up the GEM screen. After about 30 seconds, the PCM rebooted on its own and started the process over from the beginning. I looped thru this process 5-6 times and was not able to get to the GEM screen. Now it seems my PCM is stuck in limbo. All I can do is keep running thru the loop, and when I pull out the SD card, I get errors on the PCM. Any suggestion on how to proceed? Thanks.
Here is the "final script" screen. It stayed on 0% the whole time but it did reboot after about 4-5 min.
Here is the home screen after reboot. I thought I would see more icons, and I can't get Car + Tuner to work.
#784
Update: I reformatted my SD card, reloaded the files, tried to load the car again, and everything worked! I suspect that my first attempt at unzipping may not have actually unzipped all files thru the hierarchy of folders. I could tell things were different on the second attempt because the black screens lasted a lot longer and the PCM did not loop back to the beginning of the process.
This method of prepping the SD card worked: I downloaded the original 7z file to the downloads folder on my PC, then unzipped to the SD card using the 7-zip program. The unzip process resulted in a single folder with the same name as the original file in the SD card root directory. I moved all files/subfolders out of the parent folder and into the root directory of the SD card.
Thanks to the creators for your efforts in making this available to the community.
#785
#787
PCM3.1 CDR3.1 carplay upgrade
Provide the best price of $259 in December.Use discount code "DEC100" to get a discount of $100Provides two-year warranty. link:Wireless CarPlay Android Auto for Porsche 911 Boxster Cayman Macan Cayenne Panamera
https://carlinklife.com/products/wir...deo-module-box
#788
After I had the feeling that the last model years were always equipped with a GPS antenna: My 2023 718 ROW does not have a GPS antenna installed.
#789
I haven't had time to physically check it yet. MIB states: Antenna open (which according to tis thread means there is none installed; or not connected). If it matters: I have absolutely no satellite reception in my workshop.
#791
I see, but I would still do the check outdoors or do a physical check.
#792
Hi guys, can anyone confirm, that this is the right cable (on aliexpress) which is working for our 718 as provided at github
As I saw reading the hole thread there was one guy who oidered at ali but it didn't wok for him so he ordered OEM.
I have a MY 2019 and I'm not sure if there is the connector installed in my cockpit (like mentioned here). As I installed GPS antenna I already saw that I don't have the LVDS cable in PCM. If it costs only 6-7 USD I would buy it and if I have the connector install it. I'm willing to build a PIWIS in the rest of the winter for final coding If anyone have a working solution or hints plz pm
#793
#794
From what I have seen so far, on the few NA MY 2018-2019 using MIB, the cluster did not have the FAKRA connector. I don't know if this could be added to your cluster. For the Ali cable, I will let others chime in. I think @Z06jerry ordered one from Ali and the connector was angled differently but that could be modified. Good luck.
Like @718socal says your '19 is almost certainly missing the Fakra connector on the cluster circuit board so there's nothing for you to connect to..
#795
For GPS antenna, it is more important where you put the antenna then which GPS antenna you use. Something like this will work: https://www.amazon.com/gp/aw/d/B07R6...b_b_asin_title
