718 GTS 4.0/GT4/GT4RS/Spyder/25th Anniversary Discussions about the 718 version of the GT4RS, GTS 4.0, GT4, Spyder and 25th Anniversary Boxster
Sponsored By:
Sponsored By: Cobb
OEM Navigation Retrofit DIY
Old 08-12-2023, 08:13 PM
  #766
718socal
718socal's Avatar
I support all the vendors in this forum but some make some unbelievable claims to get business. Like the other vendor who discovered the Matrix Coding 😂
Old 08-12-2023, 08:58 PM
  #767
Westcoast
Westcoast's Avatar
Received 4,670 Likes on 2,717 Posts
Originally Posted by rubber_ducky
Seems hard to believe that enabling a factory option will eventually result in a PCM failure. Why eventually? Does running NAV (when enabled outside of the factory) somehow slowly deteriorate the PCM?
It doesn't, that is simply FUD, the MIB process simply enabled factory options already existing in the firmware and that includes NAV, heck a lot of those who did this discovered that the NAV Map database was preloaded from the factory.
Firmware enablement of features in a computer-controlled system has been around for many years, this is no different.
The following 2 users liked this post by Westcoast:
Mike981S (02-26-2024), Z06jerry (08-13-2023)
Old 09-30-2023, 08:34 PM
  #768
BlackCobra
BlackCobra's Avatar
Just took delivery of my 24 CGTS 4.0. I had 1100 miles to drive home so using my samsung phone with Android Auto after successfully flashing via M.I.B AIO sd card (and following the steps correcting) - worked like a charm! Thank you all for putting this thread and instructions together
$ Short (11-13-2023)
Old 11-03-2023, 06:22 PM
  #769
TubaFreak
TubaFreak's Avatar
Quick Question: I know you have to be careful when installing this on a system with Bose, but what about Burmester? I haven't seen anything mentioned so I imagine it's fine but just wanted to make sure. Thanks!
isthar (11-11-2023)
Old 11-03-2023, 06:43 PM
  #770
Westcoast
Westcoast's Avatar
Should be fine with either sound system, and regarding Bose, there is no extra care needed, simply do not enable that option, besides it is greyed out by default.
718socal (11-04-2023), TubaFreak (11-03-2023)
Old 11-03-2023, 06:49 PM
  #771
TubaFreak
TubaFreak's Avatar
Perfect, that's what I figured. Thanks!
Old 11-09-2023, 06:56 PM
  #772
Paul S.
Paul S.'s Avatar
I've got my SD card ready to roll to run the AIO to enable NAV on my 2022 BGTS.
Quick question: what's the file name and the location of the latest map update?
When I go to the MIB Solution github directory under maps, I didn't find P87_N60S5MIBH3-NAR_NT_3.21_2022-23.7z anywhere, which I read above is the latest map update. Can someone point me to where it's or the more current maps are?
Thank you.
Old 11-09-2023, 07:01 PM
  #773
Westcoast
Westcoast's Avatar
Thank you.
So which version of AIO are you using?
That is not the latest map, I will be right back with a link.
This is the latest map: P336_N60S5MIBH3-NAR-2023-2024
MHIG - MHI2(Q) - MIB Solution
Old 11-09-2023, 07:34 PM
  #774
Paul S.
Paul S.'s Avatar
I downloaded MHI2_US_POG11_K5186_1_MU1476_AIO_20220723.7z. Haven't used it yet but it is copied to an SD card ready to go.
Old 11-09-2023, 07:37 PM
  #775
Westcoast
Westcoast's Avatar
Awesome, that is the one I have used since it came out, you should be golden! Remember to have a charger on the battery, if you haven't reviewed the how to video it is worth it.
Any questions let me know.
Old 11-09-2023, 07:45 PM
  #776
Paul S.
Paul S.'s Avatar
Thanks for the assistance (CTEK MUS 4.3 is connected to the BGTS as we speak )
Westcoast (11-09-2023)
Old 11-10-2023, 05:33 PM
  #777
Paul S.
Paul S.'s Avatar
I have Burmeister in my 2022 BGTS, and there were no issues doing the AIO (just completed it today).
The following 4 users liked this post by Paul S.:
718socal (11-10-2023), isthar (11-11-2023), TubaFreak (11-10-2023), Westcoast (11-10-2023)
Old 11-22-2023, 10:24 PM
  #778
lilbza
lilbza's Avatar
Delete: figured it out
Old 11-22-2023, 10:43 PM
  #779
incursion
incursion's Avatar
Originally Posted by MaddMike
Finally aligned with Sima and I'm back on AA. Now I just need to install that antenna.
Let me know which antenna you use please. I tried two of one that was listed in this thread to no avail.
Old 11-25-2023, 08:05 AM
  #780
isthar
isthar's Avatar
I asked in another general thread but no answer yet...
is the SD card intended to then remain in the slot forever ; are the maps read from there or did they get copied in? do people leave the SD card in their car inserted?
Quick Reply: OEM Navigation Retrofit DIY
