PIWIS 3 Coding Retrofit and Feature Request
#961
#962
...havent tried it yet, but found this: https://rennlist.com/forums/panamera...ctivation.html
![](https://cimg3.ibsrv.net/gimg/rennlist.com-vbulletin/1835x976/drl_4b42fb6247fab9eb1bb27fbe61a933312f60d0e0.png)
Z06jerry (01-29-2024)
718socal (01-29-2024)
#964
Any idea how to activate the left turn signal button that activates Siri?
#965
Does anyone know how to stop the AC from turning on every time I start the car? As well as how to activate the Siri button?
MrFunk (02-03-2024)
#966
I tried enabling this on my 981 and it unfortunately didn't work. The coding was successful, but the needles still aren't illuminated unless the headlights are on. Is this only for 718?
#967
Try the setting in the picture: (Schlusslicht) Tail light has to be on. If I'm not mistaken, this is the typical setting in northern Europe/Scandinavia (daytime running lights and tail lights on during the day). Somewhere on the previous pages this has already been described...
#968
![](https://cimg0.ibsrv.net/gimg/rennlist.com-vbulletin/815x66/image_2af21e16e030ec2cad9750b799e5150affad05e1.png)
Is there something else that also needs to be enabled?
#969
I retrofitted a oem back up camera and piwis sees the camera and when I put it in reverse. I am getting a communication error. I think it's looking for a module but I do not know which one and how to code that it does not have it. Anyone know how to check which module it is looking for? Is it looking of parking aid? how do I disable all parking aids?
#970
#971
no I just added the camera and used M.I.B to update pcm. How do you add using f7? This is a 981 that I installed a PCM 4.0 into. Will I still be able to do the F7? also on a different note I did a 718 multifunction GT wheel on my 981 with a 718 clockspring would I have had to do the F7 also? and once again would this work being that the car is a 981 using 718 parts?
#972
I don't know if PIWIS will see the PCM 4 or 718 steering wheel on your car. I saw someone in the 981 forum who retrofitted PCM 4 maybe ask there.
