718 GTS 4.0/GT4/GT4RS/Spyder/25th Anniversary Discussions about the 718 version of the GT4RS, GTS 4.0, GT4, Spyder and 25th Anniversary Boxster
Sponsored By:
Sponsored By: Cobb
PIWIS 3 Coding Retrofit and Feature Request
Old 12-18-2023, 10:16 PM
  #871
718socal
718socal's Avatar
Here you go. Someone should try Inching mode (top setting in Red). It might allow you to adjust the windows up/down instead of closed or opened. No idea on X431.
Old 12-18-2023, 11:52 PM
  #872
Ken718B
Ken718B's Avatar
Thank you. Now I know what to look for. Is the PIWIS separated by system? If so, what system is this code in?
Do I change the code directly above it if I want the windows to remain closed after opening the top using the interior switch?
Old 12-19-2023, 12:05 AM
  #873
718socal
718socal's Avatar
Originally Posted by Ken718B
Thank you. Now I know what to look for. Do I change the code directly above it if I want the windows to remain closed after opening the top using the interior switch?
Use Google Translate and look for that setting. Use the Camera option. Good luck.
Old 12-19-2023, 12:47 AM
  #874
Ken718B
Ken718B's Avatar
I think I found it. There are three settings. One for the control switch (which is set to yes), one for the remote control (which is set to no) and one for the touch control (which is set to no). I assume the proper setting for these codes are no if I want the windows to remain open after opening the top. Correct? I assume the control switch is the switch in the car and the remote control is the key fob. Is touch control entry and drive?
Old 12-19-2023, 01:00 AM
  #875
718socal
718socal's Avatar
Correct on those three. 👍.
Old 12-19-2023, 01:03 AM
  #876
Ken718B
Ken718B's Avatar
Thank you for your help.
718socal (12-19-2023)
Old 12-19-2023, 05:02 PM
  #877
MrFunk
MrFunk's Avatar
Does this work with a Spyder to close windows after the top is closed with the fob? I have coded for the top to close with fob - but it does not shut the windows after which I find annoying.
So would this be where I change the setting to allow for that to happen?
Larry Cable (12-19-2023)
Old 12-19-2023, 05:20 PM
  #878
718socal
718socal's Avatar
Yes it works the same for both Boxter and Spyder. Same setting above.
MrFunk (12-19-2023)
Old 12-19-2023, 05:27 PM
  #879
MrFunk
MrFunk's Avatar
So to make sure I'm looking at this correctly. The bottom yellow circled "ja" is what you have to have set in order for the windows to auto close after the top is closed with the fob?
Old 12-19-2023, 05:37 PM
  #880
718socal
718socal's Avatar
First one circled in yellow is open top with keyfob. Second one is close top with keyfob.
TIP
Use Google Translate with your camera to translate German to English
Old 12-19-2023, 06:25 PM
  #881
MrFunk
MrFunk's Avatar
^^ Ok so I probably already have those selected since I can already open and close the top with the fob. I just now want the windows to close as well when the top closes with the fob. Is there a separate code for that? Is that what post #880 is?
Old 12-19-2023, 06:30 PM
  #882
718socal
718socal's Avatar
If you select Yes (Ja) to both they will close the windows. By default it is set to No (Nein)
Old 12-19-2023, 06:32 PM
  #883
MrFunk
MrFunk's Avatar
Ok I'll double check. But if I want only for the windows to close after the top is closed, then I only select "ja" to the second yellow circled one correct?
Old 12-19-2023, 07:00 PM
  #884
718socal
718socal's Avatar
Correct 👍
MrFunk (12-19-2023)
Old 12-19-2023, 08:41 PM
  #885
Ken718B
Ken718B's Avatar
Correction to my post above. The code that should be changed is Close Power Window after Open Soft Top with Control Switch (see picture below). This code should be changed to no.
The code I posted above is Close Power Window after Close Soft Top With Control Switch. This should stay as yes if you want the windows to close when you close the top. In Porsche's infinite wisdom, Close Power Window after Close Soft Top With Remote Control and Close Power Window after Close Soft Top With Touch Control (which I assume is entry and drive) are set to no. I am going to change these to yes so the windows close when I close the top regardless of whether I am using the control switch, remote control or touch control.
Note that I have read that touch control can be used to close the top but touch control can't be used to open the top. That doesn't make sense given the above-described setting to close the windows after closing the top with touch control. If correct, there must be additional coding that can be done to close the top using touch control. Let me know if anyone can confirm that touch control can't be used to open the top and if anyone has found a solution.
Quick Reply: PIWIS 3 Coding Retrofit and Feature Request
