Engine Ticking Noise
#226
I'm not concerned how cold engine sounds.
This is kind of funny. I don't get ticking unless I turn on the AC or open a door. Looks like the engine load is causing this.
But not talking about the ticking most of users are hearing. What I didn't hear anywhere else is a random click noise coming from the left side. Happens only when the engine is warm.
First I thought of the heat pings. But all this is gone when the engine is turned off.
Anyone else is hearing this?
#227
#228
This is a nice example of a non-ticking 982 - 4.0. It proves that oftenly complained idle speed ticking (about 3000 Hz) is NOT NORMAL and NOT part of the package.
#229
There's no ticking at all. What you hear is the normal sound of gas exchange, combustion and exhaust. When slowed down to 20 % you can hear an additional periodical sound of about 15.000 Hz, which is near to audible recognition limit at normal speed. It probably is produced by the piezoinjectors of the cylinder bank near to the microphone.
I'm wondering what are the random chirps that sound like heat pings.
The periodic and rhythmic sound similar to sewing machine is kind of normal or at least more commong among the owners.
These chirps are not.
#230
Can you post the time position(s) within these 11 seconds, where you believe to hear uncommon random chirps ?
#231
There are 8 chirps altogether.
#232
Hi 9-X-I,
compliment on your good ears !
After your time specifications I could identify the "chirps" in your soundfile.
For me the chirps are much better to hear, when the sound is slowed down to 1/4 (25 %) .
Attached you find a modified soundfile and a video with the speed slowed down to 1/4 and an additional bandpassfilter
2100 Hz - 2400 Hz.
Soundtrack pictures show the 8 chirps and parts of the soundtrack with stretched times.
Chirps are random (as you wrote), have a frequency of about 9200 Hz and a duration of about 17 ms each.
Loudness differs significantly (if the microphone was not moved).
What is the reason of this noises ?
I actually really don't know. I have to think about it. Will check the soundfiles regarding my GTS 4.0, if there are similar chirps, I didn't identify up to now.
2100 Hz - 2400 Hz.
9-X-I (09-09-2022)
#233
#234
Hi 9-X-I,
2100 Hz - 2400 Hz.
2100 Hz - 2400 Hz.
The recording isn't the best, it was made quickly with a telephone.
Thanks for the modified file and additional files!
We'll see once I get more miles!
#235
Man, you guys are in the weeds on this topic. I don’t want to be the “get out and drive” guy but I’m getting close lol.
The following 3 users liked this post by UncleDude:
#236
If a line looks straight, it is straight. And if an engine makes a noise, the engine is making a noise. No amount of hand-wringing and hypothesizing is going to make the noise go away.
P-car-Vancouver (09-18-2022)
#240
I've had ticking from the injectors and also a leaf that got sucked into the side intake and was being clipped by the fan. I was able to carefully remove the leaf with a vacuum attachment.
Anything beyond that is probably needs a visit to a shop/dealer.
