Kline 718 GT4/Spyder exhaust
#1111
You’re in trouble lol…… those resonator link pipes are the key I think. As far as I can tell, there are two chambers of perforated pipe, partially connected to each other. Valves open the air goes straight through / past the lower chamber, valves closed the gasses come from the upper chamber and are forced into the lower chamber then into the muffler then the x-pipe. I’m sure valves open everything is working together as well. IMO it seems they tuned those side cans to kill *just* enough of that boomy resonance so it doesn’t bother you. I’m sure it is a balance of that, volume and tone. Like I said, I’m in the sensitive to resonance camp and I’m very happy.
The following 4 users liked this post by RoadrunnerGTS:
#1112
Basic Sponsor
Thank you for your order! In stock coming right up!! Have a great weekend
SupremePOWER Inc
1562 Kimberly Ave - Fullerton CA 92831
Contact: sales@supremepower.com - Shop# (714)632-1951
World's Largest Retailer/Distributor of BBS Motorsport & Street Wheels from 2015-2023
Huge Inventory: BBS, Kline, Brembo, Soul, Recaro, KW, Akrapovic & 200+ brands. Installation available
** Retail & Wholesale ** Global Delivery ** We match/beat any authorized dealer's price **
SupremePower.com // SupremeForged.com // Follow SupremePower on IG
SupremePOWER Inc
UncleDude (12-16-2022)
#1113
Eric, though I'm sure you've probably done this a thousand times, but if possible, can you post a side by side pic of the OEM tips next to the Kline Metal/Inconel tips next to the Weissach tips from the straight on viewing angle as you'd see them on the car and from the bottom view. Still debating which tips to go with on my Kline. No rush. Thanks!
#1115
Does the Kline OAP ship with gaskets on both sides? Looks like only on the cat side.
#1116
it ships with gaskets to the header and gaskets between the two Kline modules - so all gaskets. I re-used the Porsche gaskets on the header and used the Kline supplied gasket between their modules.
RoadrunnerGTS (12-19-2022)
#1117
IIRC, the Kline and stock tips are roughly the same size / diameter....
#1118
I have the Softronic tune so that it stays open in the open position and definitely lots of pups and bangs. Cold startup is especially loud if I have the valves open. I do have the full inconel setup including catted headers.
#1119
Basic Sponsor
Our High Temp 1800 deg Ceramic Coating on Kline
Kline and GT4RS Weissach
Kline Carbon
#1120
Thanks Supreme Power. Quality is impressive.
The following 6 users liked this post by RoadrunnerGTS:
dmboone25 (12-30-2022),
Growler48 (12-28-2022),
JPMD (12-29-2022),
SupremePower (12-29-2022),
TRSCobra (01-13-2023),
and 1 others liked this post.
#1121
Looking forward to your review.
#1122
Basic Sponsor
