718 GTS 4.0/GT4/GT4RS/Spyder/25th Anniversary Discussions about the 718 version of the GT4RS, GTS 4.0, GT4, Spyder and 25th Anniversary Boxster
Sponsored By:
Sponsored By: Cobb
Cargraphic valve control unit
Old 04-30-2021 | 08:59 PM
  #181
jacksot's Avatar
jacksot
Originally Posted by GT4_trip
I did mine and works perfectly. Pairing process iirc was the same as for any other remote being paired.
Ditto. Works great.
Old 04-30-2021 | 11:06 PM
  #182
H8 Rain's Avatar
H8 Rain
Programming done. thanks all
Old 05-01-2021 | 05:15 AM
  #183
n4v4nod's Avatar
n4v4nod
Ditto!
Old 05-15-2021 | 08:37 PM
  #184
2ndgear's Avatar
2ndgear
Default Installation
Just completed this. Quite tricky but all the tips on the thread helped a bunch. Transformational change in exhaust sound - very deep and throaty without being too loud. Will try this for a while before changing any exhaust components...
Old 05-15-2021 | 09:09 PM
  #185
joejenie's Avatar
joejenie
I had a mechanic friend come install mine and it took him an hour. Easy mod and works great!
Old 05-31-2021 | 01:18 AM
  #186
GT4SHO's Avatar
GT4SHO
Has everyone installed the box unit outside of the engine bay, and with the wiring coming out of the engine bay visible, as opposed to installing the unit inside the engine bat? Thanks
Old 05-31-2021 | 11:28 AM
  #187
Westcoast's Avatar
Westcoast
Curious as to the question about the wires which in the end are all hidden? Also with the module outside of the engine bay the signal from the remote will (hopefully) be less affected, stronger.
Old 05-31-2021 | 05:04 PM
  #188
GT4SHO's Avatar
GT4SHO
Yes, in the end, it’s hidden in the sense that it’s covered by the carpet. But I was wondering about a solution such that when the carpet is popped out, you don’t see duct tape (or whatever is being used to cover the wires) coming from the engine bay. I have approached installers and one has suggested installing the box in the bay, and another has said to do it outside. And the car graphics instructions are silent on the specific issue. Thanks
Old 05-31-2021 | 06:16 PM
  #189
Westcoast's Avatar
Westcoast
FWIW, coming from an career in electronics, if the controller was not designed for the heat that it could be subject to in the engine compartment you could be shortening its service life and as I mentioned in the engine compartment it may be effectively shielded from receiving a good signal from the remote.
Old 05-31-2021 | 07:51 PM
  #190
JohnC4S's Avatar
JohnC4S
I tucked the module around the left rear strut area behind the carpet and the antenna is placed inside the cabin. I wouldn't want the heat to cook the module in the bay resulting the need to re install a new unit. I hate to bleed twice for the same project....
John
The following 2 users liked this post by JohnC4S:
UncleDude (05-31-2021), Westcoast (05-31-2021)
Old 06-02-2021 | 05:33 AM
  #191
RoadrunnerGTS's Avatar
RoadrunnerGTS
I asked Cargraphic. They sent this response (within engine bay)
slilley (06-02-2021)
Old 06-02-2021 | 08:29 AM
  #192
vcp13's Avatar
vcp13
Where do you place the antenna?
And what about that housing it's sitting in ? Not included in the parts
Old 06-02-2021 | 09:39 AM
  #193
Westcoast's Avatar
Westcoast
The antenna wire is visible in front of the unit itself, as for the bracket it looks homemade, I guess they didn't trust the adhesive on the box to hold in the heat of the engine bay so they threw on a couple of zip-ties as back up...
It looks like Cargraphic shared a picture of what someone else had done.
Old 06-02-2021 | 09:41 AM
  #194
RoadrunnerGTS
I believe that the point from Cargraphic support was that it their recommendation to place in the engine bay using the doublesided tape/cableties and that heat isn't an issue. There are a few locations to place it. Furthermore, if the antenna located in the boot under carpeting has no reception issue, I doubt the engine bay location would pose any issue.
I haven't even installed my unit yet, however would rather have it in the engine bay inconspicuous than wired with fugly ductape to trunk with the wires being squashed/crimped by the engine cover. Also, I'd rather a stealth install for dealerships for service visits in case of warranty issue. Just my 2c worth...either method I'm sure is fine.
Old 06-02-2021 | 09:50 AM
  #195
Westcoast's Avatar
Westcoast
Originally Posted by RoadrunnerGTS
I believe that the point from Cargraphic support was that it their recommendation to place in the engine bay using the doublesided tape/cableties and that heat isn't an issue. There are a few locations to place it. Furthermore, if the antenna located in the boot under carpeting has reception issue, I doubt the engine bay location would pose any issue.
The wires are not squashed or crimped by the engine cover and no duct tape was required and as for stealth it is under the carpet and completely out of sight...
Either location will be visible if the service department needs to open the engine access cover.
Quick Reply: Cargraphic valve control unit
