928 Forum 1978-1995
Sponsored by: 928 Specialists
So what did you do to your 928 Today......
Old 04-15-2011, 10:05 PM
  #751
jbrob007
jbrob007's Avatar
Turned over 5K miles in just 2.5 months... Celebrated by having the drivers side seat bolster repaired adn applying a second coat of "Liquid Glass" car polish... Seat looks great and the car shines like new!! Very happy camper
Old 04-15-2011, 11:58 PM
  #752
Ducman82
Ducman82's Avatar
today i installed my new rear quarters from R.Budd. dont mind the dirt on them, thats my bad. they will get a good cleaning tomorrow.
Old 04-15-2011, 11:59 PM
  #753
Catfood
Catfood's Avatar
Originally Posted by Murray
Took my car for dyno testing to get a baseline and see if it really was running well...
Max power = 260.2
Max torque = 272.2
23 years later and stills pulls like the day it left the factory. I like that!
Murray
The S4s are supposed to make 290 tq at the flywheel correct? So 270 seems about right at the tires.
Old 04-16-2011, 02:02 AM
  #754
Landseer
Landseer's Avatar
Drove 500 miles to get home on Friday ( took the long way )
Old 04-16-2011, 03:25 PM
  #755
dogleg
dogleg's Avatar
fitted new rear pads and stripped out my passenger side electric window reg all wiring checks out and motor is dead so im going to give it to an auto elec friend of mine to recon the motor
Old 04-16-2011, 05:59 PM
  #756
finally!
finally!'s Avatar
Finished install of xpipe and hi flow cats. Easy job once I got the correct clamps (they shipped to Roger four 2 1/2" clamps instead of two of them and two of 2 1/4. Roger hooked me up and all is good! Short run to best buy and enjoying the extra oomph !!
Old 04-16-2011, 08:46 PM
  #757
Bertrand Daoust
Bertrand Daoust's Avatar
Received 1,207 Likes on 467 Posts
I was able to finaly get the rear shock pins out today.
Time to do some cleaning before the new parts get in.
Old 04-17-2011, 12:57 PM
  #758
jbrob007
jbrob007's Avatar
Removed the old Thermostat along with a (pain in the butt to remove) inner seal and external O-ring... cleaned up all the surfaces / corrosion and replaced with all new. Jury-rigged the heater core vaccum / plunger valve thingy in the closed position for summer (so the interior isnt a sweat shop) and we are set for SUMMER!!!!
Old 04-17-2011, 01:31 PM
  #759
finally!
finally!'s Avatar
Now that the work for now is done (finished install of x-pipe and hi flow cats yesterday WOOT!).. time for a wash and wax! Cannot say enough about the before and after of having it color sanded a couple weeks ago! Too bad my photo skills (taken using my iPhone4) are severly lacking!
Old 04-17-2011, 02:19 PM
  #760
Landseer
Landseer's Avatar
Can you explain what color sanding entails? Is it very, very fine compounding of the original gaurds red, then wash and wax?
Old 04-17-2011, 02:38 PM
  #761
dimi5928
dimi5928's Avatar
Default Carrera III Wheels
Just bought a set 997 carrera III wheels/tires
TT twist have offset problems...SOLD....
I am gonna use my old tires 225/35/18,s and 295/30/18,s pirelli,s asymetrico...
Old 04-17-2011, 03:16 PM
  #762
JHowell37
JHowell37's Avatar
Technically, it's very heavy compounding, that can be preceded by the use of very fine grit sand paper.
I'm going to head out in a few minutes to finish replacing the factory thread inserts(heli-coils) in the rear hub carriers/uprights where the brake calipers mount. About a year ago, mine started pulling out. It's an issue I don't recall ever being mentioned on any of the discussion boards. It seems that the aluminum that the insert goes into, corrodes and then removal and install the brake caliper a few times, and it starts coming out. Aside from looking like a straightened slinky when I pull them out the rest of the way steel inserts appear to be intact. The aluminum OTOH, is very powdery.
I'm using a "Big-Sert" kit from time-sert. Big-serts are used in applications where an insert has previously been used and failed. I bought the kit from toolskwik.com for about $100. It includes a drill bit for drilling out the hole. A countersink bit, a tap, the driver for installing the insert, and five inserts. The 16.2mm inserts are a perfect length for this job. The only tools you need are a tap handle and a drill. I'll take my phone outside with me when I install the remaining two and post a few pics.
Old 04-17-2011, 03:41 PM
  #763
dr bob
Chronic Tool Dropper
dr bob's Avatar
Starting day two of the intake replacement. yesterday was mostly disassemble and clean. Rob Edwards is helping with the technical stuff like getting the electrical connectors from the injectors and the like. A couple of the correct vapor vent hoses should be here later from GB to allow final assembly. So far, all everything in the V has been in ood to excellent condition. Nothing stiff or crispy. Valley contamination is mostly road dirt. No slime or evidence of any leakage. The knock sensor wiring is all of the damage we've found so far.
I need to get the CPS out and replaced. I may have an hour before Rob gets back. Wish me luck!
Old 04-17-2011, 05:11 PM
  #764
careful1
careful1's Avatar
I've been cutting, polishing, waxing . I don't think the P0 ever buffed the car after a respray. It is a black S4 and was very "swirly".Starting to look very nice....
Old 04-17-2011, 06:28 PM
  #765
martinss
martinss's Avatar
Made new consoles sides. Carpet being washed now before installation.
Quick Reply: So what did you do to your 928 Today......
