Old Aug 27, 2017 | 11:32 PM
  #8431
944 Lachlan's Avatar
944 Lachlan
New rubber ready to go on! Continental ExtremeContact Sport.
Old Aug 28, 2017 | 03:29 AM
  #8432
morghen's Avatar
morghen
Amazing tires, I'm using Conti Sport Contact5s and they are absolutely fantastic for sporty driving. These should be even better.
Old Aug 28, 2017 | 09:44 AM
  #8433
Tiger03447's Avatar
Tiger03447
Odonnell..you should put the Porsche on a raft! I think that you're going to need it! Have you ordered a Porsche ark yet? I think that Amazon might have one..LOL!!!
Old Aug 29, 2017 | 12:08 AM
  #8434
ried's Avatar
ried
Default Oh boy...
Bridgestone Potenza RE-11s. 968 M030 brake rotors, pads, lines & sensors. New Porsche M030 front struts and rear shocks. Jumper fuel line, lots of mounting hardware here and there... the list goes on! This one's almost what I would consider "done."
Old Aug 29, 2017 | 11:02 AM
  #8435
ddombrowski's Avatar
ddombrowski
Rear hatch re-inforcement to keep it from deflecting at high speeds. Fairly simple job with some 1" L-angle aluminum from Home Depot.
Tweaked the ride height adjustment a bit more to try to even out the corner weight. We are close to what we want but maxed out on adjustment. I probably need to re-index the torsion bars (again) but don't think we'll have time before sebring so we're just going to run it as is. Using our homemade scale setup we show we are close to even corner weights so we should be in good shape.
Sebring is less than a month away and we have a fairly short prep list this time. I still need to drill a vent relief for the bearing caps, change out the spark plug wires, secure the wiring harness from vibrations and find my gopro.
Old Aug 29, 2017 | 12:14 PM
  #8436
dreygata's Avatar
dreygata
Installed the crankshaft girdle, attached the connecting rods, installed the lower balance shaft, water pump, oil pump, and started on the oil cooler
Old Aug 29, 2017 | 09:05 PM
  #8437
shortyboy's Avatar
shortyboy
Fitted reworked vented nose panel, install gts headlights and cut bumper for intercooler. Lots more fitting before paint. Might get a new header panel, does not want to line up on the top for hardware. Then choose a color.
Old Aug 29, 2017 | 09:46 PM
  #8438
Otto Mechanic's Avatar
Otto Mechanic
I want those headlights! Did you make 'em or buy 'em? That's going to be a nice looking car...
PS: Very nice work on the intercooler grill!
Old Aug 30, 2017 | 12:45 PM
  #8439
shortyboy's Avatar
shortyboy
Thanks for the kinda words, alot work left to be done. I got the headlights from here http://gtpheadlights.com/ Theyre based in Poland. Took a while to get here and a bit pricey, but well worth the build quality.
Old Aug 30, 2017 | 01:54 PM
  #8440
Chalt's Avatar
Chalt
Originally Posted by ried
That engine is so CLEAN! Beautiful!
Old Aug 31, 2017 | 01:25 AM
  #8441
ried's Avatar
ried
Thanks! Still a work-in-progress, as these cars inevitably are
Old Sep 2, 2017 | 04:00 PM
  #8442
V2Rocket's Avatar
V2Rocket
Hadnt driven it in over a month due to modifications in progress (moved oil cooler in front of PS wheel), got the itch, car needed gas and got impatient...
car has about 6 inches of dust all around..lol
File Type: jpg
File Type: jpg
Old Sep 2, 2017 | 04:52 PM
  #8443
SloMo228's Avatar
SloMo228
Looks a lot like mine right now:
Just getting started fitting a 924GTS style front bumper. Probably going to be a good learning experience.
Old Sep 2, 2017 | 05:38 PM
  #8444
V2Rocket's Avatar
V2Rocket
is that what yelling lots of four letter words is called?
Old Sep 2, 2017 | 06:08 PM
  #8445
KoB's Avatar
KoB
Cursing is like any other skill ... without constant practice, you lose your edge. Since I bought the 944, the neighbors tell me I've really upped my game.
