ASK THE COACH
#2191
That session was apparently not amongst the ones I left in the TraqMate when you took delivery of the car. I had already downloaded it and two other sessions of mid to high 1:55's.
Best CCW with the Hankooks was 1:53.200
![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
#2198
#2199
Actually my best going CCW on NT01's was 1:54.904
Best CCW with the Hankooks was 1:53.200![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
Typo I presume ?
#2200
One is on NT01s the other on Z214s. The Z214s are good for about 1.5 seconds at TWS with the same driver on that car. My bests have a similar spread. 2:00.7 TWS CCW on the Z214s and 2:02.3 TWS CCW (IIRC).
The Z214s on that car are like freaking magic until they heat cycle out.
-Mike
-Mike
#2202
-Mike
-Mike
So that will be my goal with you, just a tenth of a second, per corner.
#2203
-Mike
-Mike
Right. And the fact is, I set up the suspension with the Hankooks, and the car has too much spring for the NT01's, so its handling is less than ideal with them.
#2204
I know they are slightly softer, and obviously have slightly less tread. I'm more often on Hoosiers, various slicks, or spec Toyo tires, I guess I'm going to have to pay more attention the next time I drive a car with Kooks.
#2205
Yes. it surprised me. The Hankooks have very stiff sidewalls and the suspension I had on the car was perfectly matched for them. I suspect it would also work really well with R7's. The stiffness of the car tends to overwhelm the NT01's, especially in the rear, even when the dampers were softened dramatically.
