Garmin Automated Coaching
#841
Trying to prepare for my first track day with the Aim Solo2 DL, but can't find straight forward videos on simply how to operate the aim/smarty while at the track. I want to be sure the dl and the cam are going to work when I head out on the track. I've done the configs in Race Studio and transmitted them to the dl and cam.
Don't really want to spend my track day making sure Aim stuff works and how to see data and video afterwards...any tips are appreciated! Sorry to detract from the subject, but it's kind of on topic too if there is an ease of use factor![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Yes, one advantage of the Catalyst, is that it's perfect for "idiots", like myself, who just want to arrive and drive, and record some video and some data while at the track. The Catalyst is plug and play, ready to go, with no hard-wiring necessary.
#842
I'm sure Peter will reply shortly regarding the Aim package.
#844
#845
Basic Site Sponsor
Basic Site Sponsor
Received 3,229 Likes
After the configuration is loaded, you’ll need to sort it and scale the information, as well as insure all is well. Also, you should spend time making the camera settings record automatically, loading the tracks to the camera as well.
Then, when you get your system up and running, you’ll need to get the video and data downloads from separate devices to fully leverage the power of the beta Analysis program, be sure to download that too.
Then, you’ll need to devise a workflow that allows you to glean and prioritize the lowest hanging fruit for
the next session, basically to find and focus on areas of exceptional performance, so you can do more of that.
When you do arrange and scale the information you want to look at, make sure you save it in a profile you can save so it appears the same way anytime you download information from your logger.
It’s not easy. I spent ninety minutes with a 718 GT4 CS owner today getting his configs, firmware updates and a basic analysis window profile built on his computer remotely. I sold him a Solo 2 DL and my premade PnP cables for the ClubSport and had to get his camera straight after he bought it mail order as a blank slate.
Once it’s done, it usually works. Although today I looked at quite a few AiM systems that lost expansions, lost lap timing and others that wouldn’t record video, even though all was well. Between me and the AiM support team, who do a great job, we’re still working on most of them.
A better place than this thread to talk about AiM is the AiM Users Group on FB. Matt usually pipes up but over 2800 members share good information and even the factory guys, as well as the importer/distributor support staff are all on it. Good stuff.
Even as a top three US dealer for a decade, I do see why quite a few AiM users have picked up a Catalyst.
#846
Rennlist Hoonigan
which cost no drachmas
The learning curve is steep.
![jumper](https://rennlist.com/forums/graemlins/jumper.gif)
CT_Peter (04-04-2021)
#847
Rennlist Hoonigan
You can then pull the SD card and have the video with the data on it. If you are just learning analysis, I would suggest using RS3 Analysis beta and starting with importing the video. I have shared a very simply profile with a huge portion of the AiM userbase that makes basic analysis fast and easy. You can do that off just the video and will have the video linked. I think I have shared that here, FB, and a few other forums. Not in the AiM FB group referenced above as my posts are often not approved
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
AiM has 120+ YT videos on how to configure devices, use the software, and do analysis. Guys like myself, James Colburn, and others have some great videos on all of it too.
Post back if you need more help.
#848
Basic Site Sponsor
Basic Site Sponsor
Of course, we can always count on you to take the thread off topic and turn it into a sales pitch for the single line you carry.
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
#849
can you start the Cat with the system turn off set at a longer 10 mins so you can start it not move belt in on grid at the 5 min board then drive off?
#850
Basic Site Sponsor
Basic Site Sponsor
the Cat is big to sit up there on the dash. The window mount is quite large too. Does the Cat have to sit centered on the dash because it is best place for the gps engine and because it can’t get a signal through a metal roof? It would be nice to install in dash on racecar but then it won’t have clear line of site out the window.
Ive seen people use a V-mount from RAM (I stock them) to hang it from the halo bar in a caged car, have seen people put it on downtubes, too. It comes with a flat AMPS plate to bolt it to metal.
You ccan lengthen the auto off so you can start it up, select the track and buckle in.
Most folks are having good luck with just the top of the unit above the top of the dash. As long as it’s under the vertical profile of the glass, it seems to be working well, about the same as the Solo.
#851
Rennlist Hoonigan
Someone asked about help for their S2DL, that I didn't sell, and I offered help. Sorry for taking up your valuable reading time. You have my phone number when you want to stop being passive aggressive or attacking me online.
#852
Basic Site Sponsor
Basic Site Sponsor
Wah.
Not worth the time.
Not worth the time.
#853
Back to more important questions, so when is this update that'll allow the data/video feed download going to happen? Well it just render the best lap? Or the entire session? Or can we choose the lap we want to see? Besides the obvious uses of the Catalyst (lap timer, coaching, etc) the data/video dump so I can share it is the feature I want to have the most.
#854
GtEE4 (07-25-2021)
#855
Still waiting on this as well. Used the Cat for the first time last weekend. It's an amazing tool, and I definitely made some improvements using it, but I really want the download / overlay functionality. I think I saw a post somewhere on a Corvette forum where someone had figured it out. Will hunt for that.
