Could be the ribbons that connect to the vertical front panel...maybe got pulled.during install.
Did you remove the Front panel as part of your process ? I try not so.......
Check/re do those. Pretty sure you only have a ribbon connection problem here...... also, make sure the Quad lock is in correctly...all the way.
I did not remove the front panel, so I will try and do that now and check those ribbons. I did check the quad lock a number of times to make sure it was seated correctly. It was working great for a hour or so, freeway miles so nothing bumpy, just all of a sudden went blank screen.
Yeah, I believe all your connections are correct......maybe one of the display cables " is on the edge" also, check the ribbon fingers....if they bust......no good.
At this point I am just hoping to get my PCM back, I have un-installed the Isudar board and components. The ribbon looks correctly seated in the front and main panel. Not sure what else to check.
I think you have Cayenne…….are you getting PCM data in your cluster, like radio information, NAV etc ?
If so, it’s working……..just somehow you lost the display.
