Isudar Carplay for PCM 3.1
#61
I installed the Isudar CarPlay board today. Everything works except for my reverse camera. I can pull the camera up in the PCM settings, but when I shift to reverse, I get a blank screen. Any ideas? Thanks!
#64
I ordered this unit a few days back and am exited to modernize the car - and avoid a two-box solution. This seems to tick all of the boxes! Thanks to everyone for all of the useful information shared in this post.
#66
Thank you. If you don't mind, is it possible to play music from Jukebox and use Carplay for navigation? My guess is that it won't give me voice guidance as it goes through AUX if I play music from Jukebox.
#67
#68
So after using it for a couple of weeks, somethings I have noticed.
The volume and sound isn't always the same when it hooks up. Sometimes it comes on strong and sounds great but sometimes the volume is really low and doesn't sound too good.
Another glitch I noticed when using maps, when the music is lowered to give directions, after the directions the music blast for a second then comes down.
I still think its worth it just for the maps.
Bud
Bud
#69
Bud
Bud
#70
That's the old one, new one from iSudar (thanks to @konkab is pasted here: https://www.dropbox.com/s/r049jbpily...2021-09-02.zip
#72
Bud
#73
One tip - disable the BT Aux in PCM so your phone doesn't try to stream through it instead of Carplay. On iPhones you can't set device prioirity for that unfortunatelly.
BW369 (10-04-2021)
#74
