Panamera 2010-Current
Received my new PIWIS III
Old 12-11-2022, 03:34 AM
  #1246
rnlst_log
rnlst_log's Avatar
Originally Posted by porschemic
I'll try I don't have zfas, ATM is a gearbox control unit?
zFas=Front Camera
ATM=DDA or Aerial Bluetooth Antenna
Old 12-18-2022, 06:32 PM
  #1247
runbuh
runbuh's Avatar
Originally Posted by orca15
If anyone gets this to work, and would produce a step by step instruction for those of us who are amateurs, it would be hugely appreciated! I'm not sure if there is a reluctance to post a DIY on this effort but I bet there is more than a few of us with crippled PDLS+ who would love to unlock it.
This is what I did on my 2019 Cayenne with the matrix headlights (US Spec). Read the thread from this point forward and you can see some videos of the lights in action.
https://rennlist.com/forums/cayenne-...l#post18510008
orca15 (12-19-2022)
Old 12-26-2022, 12:58 PM
  #1248
Tom Sch
7th Gear
Tom Sch's Avatar
Hello,
A few months ago I bought a PIWIS 3 complete system from VXDAS.
https://www.vxdas.com/products/oem-p...vo-yoga-laptop
The whole story initially worked without any problems, I read out numerous Porsche vehicles, analyzed errors and sometimes also changed/programmed options.
After about 6 weeks, the dual boot partition with version 41.400 could no longer be started. When booting, the error messages "...Netwbw02.sys" or "...NDIS_Driver" always came up, which I know from Windows 8 systems in the past and which can actually be fixed relatively easily.
Emphasis is on "actually" because thanks to the blocking of all access rights, non-admin users cannot do anything on the fully configured computer...
Then a long odyssey with the VXDAS support by mail, then Whatsapp. Although they could always be reached, they were very limited in terms of intellect and the will to eliminate the error.
Long story short - in the end I sent everything back and received part of the money back barely 5 weeks later.
What remains is a loss of 200€ as well as the experience of such a system that doesn't give you any possibility of correction yourself, no longer to be considered!
Ultimately, I am quite disappointed with the company VXDAS because the error could have been easily fixed from a distance with a little good will, even the fact that the costs are not 100% covered stinks because I can't help it if their system doesn't work properly!
Now, as in the beginning, I'm looking for a problem-free and reliable PIWIS 3 solution!
Regards
Old 12-27-2022, 01:08 PM
  #1249
JB911
JB911's Avatar
Contact rnlst_log
JB
The following 5 users liked this post by JB911:
amphicar770 (12-28-2022), rnlst_log (12-27-2022), siberian (12-27-2022), Stephen Shi (01-01-2023), Z06jerry (12-27-2022)
Old 12-27-2022, 01:56 PM
  #1250
siberian
siberian's Avatar
Received 2,301 Likes on 1,368 Posts
No question. Contact @rnlst_log
siberian
The following 2 users liked this post by siberian:
rnlst_log (12-27-2022), Stephen Shi (01-01-2023)
Old 12-29-2022, 04:21 AM
  #1251
Tom Sch
7th Gear
Tom Sch's Avatar
Somehow I'm apparently blind at the moment, but I can't find any way to write a PM to rnlst_log?
Old 12-29-2022, 04:28 AM
  #1252
rnlst_log
rnlst_log's Avatar
You cannot send PM unless you enable it on your Profile setting. Go To : https://rennlist.com/forums/profile.php?do=editoptions
and enable your private message setting.
Old 01-03-2023, 10:54 AM
  #1253
Willy07
Willy07's Avatar
Most are using 6154 as clone VCI for piwis. It is inherently slow...and clunky, but it does work.
Recently, there have been a few more clone VCI pop up, like the VCX SE, that features DOIP with added license....and even a 6154...that has DOIP. Would these be a better option ? and maybe complete a VAL for all cars ?
Work faster like oem 6154 ?
VCX SE
https://www.vxdiagshop.com/wholesale...3-license.html
6154
https://www.aliexpress.com/item/1005...d=dqNuAupkoTG4
Old 01-03-2023, 12:01 PM
  #1254
siberian
siberian's Avatar
DOIP is definitely the way to go as it's portable, faster, a cheaper alternative to CANBus and since it's built on an ISO stack model easier to implement. Our CAN based 6154 even with WiFi is inherently slow leading to timeouts especially trying to generate a VAL. Though I did manage to get a VAL in both Service and RT mode it took many tries and hours wasted. Definitely interesting, thanks for pointing this out. For further explanation of DOIT, please check this link:
https://www.autopi.io/blog/diagnosti...col-explained/
siberian
Old 01-03-2023, 12:11 PM
  #1255
Willy07
Willy07's Avatar
No problem......hopefully we can gain more insight here. I don't believe DOIP is implemented on POR prior to 2017.
Old 01-03-2023, 01:57 PM
  #1256
Lucifer
Lucifer's Avatar
New to the Porsche world but have been working as a malware reverse engineer for the past 10 years, so can usually manage when talking about hacked software.
Looking for a TL;DR of 84 pages - is it possible to install Piwis III for free on a new machine \ VM and get the other equipment myself? Not a huge fan of the idea of getting hacked piece of software from some Chinese seller
specter981 (01-10-2023)
Old 01-03-2023, 02:02 PM
  #1257
siberian
siberian's Avatar
You get what you pay for. However, if you want to pay a reasonable amount with above and beyond support contact @rnlst_log
siberian
Old 01-03-2023, 02:26 PM
  #1258
Lucifer
Lucifer's Avatar
siberian
I don't mind paying for someone to save me hours of research and troubleshooting and just getting a finished working product, I am just not a huge fan of the idea of paying Chinese hackers for stolen property
@rnlst_log doesn't let me PM you - could you please contact me with some more information (718 Spyder if it matters)
Old 01-03-2023, 02:34 PM
  #1259
siberian
siberian's Avatar
See post #1252.
So according to your first post you want free software/hardware and then you don't deal with "hackers" (I assume Chinese, Russian or Bolivian) who in this case are reverse engineers... GL
siberian
Old 01-03-2023, 03:00 PM
  #1260
Lucifer
Lucifer's Avatar
See post #1252.
siberian
Yes.
There is a difference between pirating a movie to watch in your living room alone (which is also wrong) to pirating a movie to monetize it by screening it in your backyard and selling tickets to the entire neighborhood. Not saying I won't eventually buy a ticket if it is the only place around to see the movie and I don't have any other option - but I don't think it is hard to understand why I would prefer to avoid this if possible.
Quick Reply: Received my new PIWIS III
