Panamera 2010-Current
Received my new PIWIS III
Old 01-25-2024, 08:33 PM
  #1741
siberian
siberian's Avatar
Received 2,302 Likes on 1,369 Posts
If it works for you, you shouldn't.
siberian
Old 01-25-2024, 08:40 PM
  #1742
JB911
JB911's Avatar
VAS works fine on my 997 and other newer cars. Latest cars not the same
JB
Old 01-27-2024, 09:42 AM
  #1743
FerdinandAG
FerdinandAG's Avatar
Originally Posted by jayson
Here is the specific error / issue I am observing 'Control Unit variant Headlight (Central) in MCR data not found'
The 'Teach Headlight' function will initiate, but then error out after the first step (coding VIN). Any other coding request displays that error.
Have tried this with two different sets of lights as well as 2 different PIWIS versions and same result.
MCR data not found - this means that the data set (parametry) required for this block is missing, this usually happens on SD versions of software, this is any software with the end of 000, for example 41.500.000, they simply do not have an online database of files from the Porsche server, even if these files are copied from another version of the full version, it will not work because there are no files that describe configurations for automatic programming and coding
jayson (02-01-2024)
Old 01-28-2024, 12:30 PM
  #1744
preme123
preme123's Avatar
Would anyone be kind enough to help guide me? I am stuck at mounting the tib file with arconis and can't seem to know how to boot my computer from the unpacked .tib partitions.
Or would I need an external SSD and unpack the .tib file onto that then go into bios mode to force boot from the external SSD?
By the way how do I permanently unpack the .tib files to make a bootable external SSD?
Originally Posted by Lucifer
So today I completed my "piwis journey" after successfully coding a fellow rennlister 718 Spyder
Total cost: around $50 for the VCI from AliExpress
  1. I got a 4-5 year old Lenovo T470 from a friend of mine, it had a large enough SSD, 1080p display (many people have unused old laptops with 1080p display just sitting somewhere. If not, the one I has can easily be found on eBay for less than $100)
  2. Got one of the Windows 8 PIWIS that is floating around the internet. I used google - anyone can do that. I didn't pay a penny for any of the forums that force you to get a paid subscription to get the download link (search for "40.400 Win 8.1_64 Pbk_full_b1_s1_v1.tib")
  3. Load the image you downloaded to the SSD using either Acronis or EaseUS - the free versions of both of those software will work
  4. You probably need to make sure your laptop is set to BIOS and not UEFI
  5. Follow the popular tutorial on how to use the keygen. For me, it is the first result when searching "piwis keygen" - very simple, explained step by step
  6. Use your AliExpress VCI ( https://www.aliexpress.us/item/32568...andl_shipto=US )
  7. That's it, basically
My take is that someone that feels comfortable enough programming their (potentially) several hundred thousand dollars car should feel comfortable enough doing the above steps and using Google
I would also like to thank @Treurentner, who shared great information both in this thread and on other forums.
Old 02-03-2024, 01:59 PM
  #1745
Lucifer
Lucifer's Avatar
Hey all, does know how to use my own car files in simulation mode? what I mean is that I want to be able to browse the coding options of my very own car that I programmed before, and not the generic one that is available (not 982 Boxster but specifically a 982 Spyder, in that case)
Old 02-06-2024, 08:07 PM
  #1746
jayson
jayson's Avatar
OK - A couple of updates for you guys.
Firstly, the TabScan T6PT3G is worth its weight in gold, stop fudging with the cheap VAS clones and go pick up one of these. It is 100x quicker than the clones, and if you are running PIWIS native (not in VMWARE) everything happens super quickly. I pulled the entire VAL in less than 4 minutes. Massive upgrade from a usability POV.
Secondly, I picked up a 600w 13.8v power supply to meet the power requirements for coding. Much greater peace of mind vs. using a CTEK trickle charger. Power cord and alligator clamps (and a handy LED meter) can be sourced on Amazon as needed. Yes, the power supply is cheap, but power is power. Add an inline fuse if you are nervous about it. You can also monitor current voltage in the OBC.
I connected everything to my garage computer via the handy USB connector. Installed the software/drivers (online download) and everything was good to go. I also use a 10-foot OBDII extension cable on the end of the T6PT3G to make direct wiring easy (the WiFi works too, but I trust wires more).
The aggregate result of all of this effort is that my headlights are now successfully coded and commissioned, something that the VAS was simply unable to do! So net/net, I was able to buy the T6PT3G for what I likely would have paid Porsche to do it for me, and now I get to keep it too. Win/win.
rainer (02-12-2024)
Old 02-12-2024, 11:43 AM
  #1747
sac02
sac02's Avatar
Those 12V leads are woefully undersized, I would strongly encourage you to use thicker copper wire
(you can also connect the same wire to multiple terminals to reduce contact resistance in the scenario where you have fat wire / small connector)
The following 3 users liked this post by sac02:
jayson (04-05-2024), Lizard King (05-02-2024), steveo17 (02-14-2024)
Old 02-12-2024, 11:47 AM
  #1748
Willy07
Willy07's Avatar
Nice, But a laptop is safer....during a power outtage.....if you were critical coding.
Old 02-12-2024, 12:01 PM
  #1749
sac02
sac02's Avatar
Could maybe add a UPS as an option.
Willy07 (02-12-2024)
Old 02-12-2024, 12:05 PM
  #1750
siberian
siberian's Avatar
The CTEK is a trickle charger and should NEVER be used when coding as it can't supply the potential current required. OTOH you should never use your PowerMax or other to replace a trickle charger.
As my father in law used to say "the right tool for the right job".
siberian
The following 3 users liked this post by siberian:
Old 02-12-2024, 12:33 PM
  #1751
Westcoast
Westcoast's Avatar
Received 4,647 Likes on 2,708 Posts
siberian
That is why I have both...
Old 02-12-2024, 12:43 PM
  #1752
siberian
siberian's Avatar
I was referring to OP's comment that he got a power charger for peace of mind when coding rather than use the CTEK.
siberian
Old 02-15-2024, 05:18 PM
  #1753
Aztectt
3rd Gear
Aztectt's Avatar
Hi all, can someone please share a copy or a valid link to download the piwis 3 keygen? All the links that I find on Google have been dead/ kinda expensive... TIA!
Old 02-15-2024, 05:32 PM
  #1754
edsonreds
edsonreds's Avatar
Some people charge for that file, not my case. Having it will only take you half way. Without knowledge of how to crack the software (check connection, etc) it would be useless. My advice is to contact a well known installer such as Mars (look for him in this forum) and hire him for support. Nonetheless.. good luck.
siberian (02-15-2024)
Old 02-15-2024, 05:56 PM
  #1755
Aztectt
3rd Gear
Aztectt's Avatar
I was able to find instructions on how to use the keygen, just that links for downloading are no long there. I already downloaded and installed the actual Piwis 3 on my laptop and got a cloned VCI.
Quick Reply: Received my new PIWIS III
