Received my new PIWIS III
#991
If you have the ELV module, which is located in the steering column, not the steering rack, then yes, this is a security module that maintains the key encryption and can only be programmed by someone connected to Porsche network. In the US, this is only dealers. Now, most cars do not have the ELV module, it is optional and rarely ordered. If your car has one, then you won't be able to program it. Remember, it locks the column not the steering gear. It is also removable. It may be possible to remove it, then alter the car's details to eliminate this option but the modules that would need reprogramming are also the ones that require online programming. The DME, FBC, RBC and the ELV all maintain the immobilizer information and for that reason, must be programmed by a dealer connected to Porsche.
"The electromechanical steering lock serves to block the steering by mechanical means, in order to prevent unauthorized use of the vehicle. The electro-mechanical steering lock is installed in the steering system and can only be removed after dismantling the steering system. As a component of the electronic immobilizer, the electro-mechanical steering lock must be authenticated for release of the ignition by the immobilizer master. Both the Front and Rear BCM’s authorize the release of the ELV. Each controller is individually wired to the ELV"
#992
Thanks for that info. How or where would you specifically order the ELV (just making sure I never accidentally order it)? Do you have a code for that option or is it part of some exotic suite?
siberian
siberian
#993
I believe they discontinued this option, I don't see it on a build list. There is a video on youtube on how to remove it.
#995
#997
I think they solved the problems with paypal
https://mhhauto.com/Thread-Piwis-3-v...clone-and-PT3G
#998
#999
#1001
It shows out of stock...
siberian
siberian
#1003
Sorry it shows out of stock as it took the Wallyworld store in Fairbanks. My bad
siberian
siberian
#1004
"Under the current circumstances, we are suspending PayPal services in Russia," President and Chief Executive Dan Schulman said in a statement. He added that the company "stands with the international community in condemning Russia's violent military aggression in Ukraine."
Source / full text klick
