Transfer case
#871
Thanks Todd! I mentioned to the service manager that many people were having luck with the Ravenol and he said that makes sense and didn't know why Porsche hasn't considered that. He also told me that they have had several 2017 models starting to come in with TC failures. So seems like the majority of the problems started in 2011 and now are confirmed up to 2017. That's a strong 7 years of failures. This is approaching IMS scenarios lol. I wonder if I ask to keep the failing TC if they will give it to me?
#872
Fivefathomapple, good idea asking to keep the old TC but I would bet they're required by Porsche to keep it. I bought mine just out of warranty, one year and 2500 miles too late. I wasn't even aware of the TC issue when I purchased it, thought the bumpy acceleration I felt was either the new tires they had installed or the road in front of the dealer LOL😆.
#873
Received 1,160 Likes
I'm sorry to hear that! To me, yours is a good argument against using Porsche fluid in the TC. There is obviously a big problem with the TC itself or the fluid compatibility. I know Porsches line about moisture intrusion but don't buy it completely. I purchased my 2015 Cayenne S two months ago at 52k miles with noticeable TC shudder. Just changed fluid with Ravenol TF-0870 two weeks ago and there was an immediate improvement. I will change it once again w Ravenol this summer at 6 months/ 6000 miles and will continue every 6 mos/6-7k thereafter with each oil change. My old fluid doesn't show noticable signs of moisture contamination so I don't know what's up with that... I'm sure there's some truth to it but I don't accept that that's the sole problem with 958 TC's, so many are failing far too quickly!
Todd
Annapolis MD
Todd
Annapolis MD
I don't think you can compare used stock TC oil and new TC oil from a different manufacturer and make a valid comparison that one is better than the other. It would have to be a comparison between equally used oil (difficult to accurately repeat all driving on 2 cars) or between two fillups with new fluid, I suspect your change interval is perhaps a bit excessive, I've gone to every other oil change (about 10,000 miles) or annually. Except for the expense of replacement plugs for the case - it's not a hard or expensive job. I can do it on my '11 Turbo by putting the suspension in the highest mode, and wiggling like a fat worm under the car. Piece of cake basically.
I'm on my original TC at 103,000 miles now - and it seems to be working just fine. If I ever get around to it, I'll add some sort of high-vent to the case, right now I avoid driving in deep water.
#874
Hey Don, great info! My dealer said Porsche has not informed them to add a service interval to the TC, but he thought it was a great idea. My second TC had the new vent system and failed after 27k though without ever changing the fluid. Before I take it to the dealer for its 3rd TC, I am going to try the oil change just to see what happens. If I notice good results, I will get the new TC and then change the fluid at least every 10k and hope for the best. May I ask what fluid you are using in there? How long have you been doing the service yourself, every 10k since new?? Thank you!
#875
My previous 2016 base had the TC replaced around 30k and I never bothered to change the fluid since I traded it in a year later for my current 2016 CS. My CS also had the TC replaced under warranty around 25k miles and I’ve since been doing the TC oil changes myself every 10k miles. It really is very simply, I don’t even use a jack or anything. I can reach the plugs by just crawling under from the side.
#878
For DIY people, I see no reason why not to change the TC oil every time you do an oil change. I'm averaging about 7,500 miles a year, so I'll do my annual oil and tc change at the same time.
#879
I will repeat something I've said before - for everyone enthusiastically heading under their Cayenne..
DO NOT OVERTIGHTEN the drain/fill plugs. YOU WILL CRACK THE COVER if you do. I do not use a torque wrench, since most of them aren't that accurate at low torque values like these plugs have and unless you use one regularly - it's way easy for muscle memory to overcome thinking.. and you over-torque it.. I use a 6" allen wrench, and tighten it with one educated finger. I shoot for snug not tight. It hasn't come out yet so I think that's working.
jayi836 (02-25-2020)
#880
Just changed the transfer case fluid tonight for the second time after about 9k miles (just hit 40k miles on odo). Very black. Anyone with a cayenne, highly recommend you take a brave pill and start doing the fluid changes yourself every 10k miles. Agree with what has been said above, I do not use a torque wrench on the bolts, just muscle memory. Snug, but not tight. The fill/drain bolts should NOT sit flush with opening, maybe 1mm hanging out.
The following 2 users liked this post by driftmotion:
deilenberger (02-28-2020),
jayi836 (03-05-2020)
#882
Well nothing lasts forever. This includes my TC fluid change with friction mod. It's not as bad as it was originally but unmistakable.
I'm figuring I got from about 61K to 77K out of it. I may go with ravenol this time around for half the price of the Porsche fluid. I'll leave out the modifier initially and see what happens.
At some point I'd be an idiot to not get out my box of new parts and get this right. Especially since I'm sure my chain in stretched. Just not wanting to be down my daily for any length of time.
#883
Rebuild process looks very satisfying - click on CC and do translate to English -
#884
I’m also in NVA, my 2008 Cbase is having transfer case thumping signs. I’m looking a ebay for used case. But don’t know if the parts are interchangeable with other years and engine size.
any input?
any input?
I mentioned I'd report back when I got my CTT back from service regarding the 2nd transfer case replacement.
As mentioned before, the 1st replacement was at around 31k miles when in possession of the first/original owner. It has now been replaced a 2nd time at 61k. Covered by warranty in both instances.
So comparing the two service tickets, the part #s seem to confirm what the SA told me regarding updated hardware. The part #s for the transfer case is different from what it was when replaced the first time (June 2013). There's also a number of other misc. parts listed this time that were not on the 2013 invoice, including the new transfer case vent kit.
The first transfer case was part # 958-341-010-FX. This new one is 958-341-011-EX. The tech noted on the invoice "Recommend: transfer case and update parts". The other parts listed are as follows:
1 N-103-284-01 Line Bracket
1 958-301-047-10 Vent Line Transfer
1 N-107-873-01 Spacer Ring
1 02H-409-275-A Sleeve
1 958-341-375-01 Protective Ring Tran
1 WHT-005-158 O-Ring
1 958-349-491-10 Circlip Transfer Box
With the first replacement in 2013, the only other part listed on the invoice in addition to the transfer case itself was ten WHT-003-211 12-point screws 10x50.
Hope this info might help others. Vehicle is running great now, SMOOTH on accel.
#885
I'd say order parts from awd.tech (will take some time to get) than either pay shop to do it all. Or pay shop to remove TC and hang on to your car while you run home and rebuild it.
Rebuild process looks very satisfying - click on CC and do translate to English - https://www.youtube.com/watch?v=miLkJddL4fM&t=1s
