Has anyone come across the coding section in Launch for the mph setting that the suspension automatically lowers from High Level 1 to Normal mode? Default seems to be at 50 mph, and I don’t like to increase it to 60 mph.
Camera I'm trying to see if I have it or look for it to enable it
siberian
execuse me for delay…. My Kafas camera is 7pp980653 and is suitable for 9Q1 and 9Q6.
So in both cases the camera on the glass for the Cayenne restyling is always the same
Pic below shows: left side Temps the gauge will show, right side actual coolant Temps.
To correct this I copied the X2 - X8 values over to the corresponding Y2 - Y8 fields
Also, most importantly to me, I can now run the factory hybrid clutch bleed and adaptation routines to keep the seperating clutch happy:
I really love this thing so far and can't wait to play with it more. I have access to a few GT cars and a 718 S and will see what else is possible for other p-cars.
How did you get on running the factory bleed and adaptation of the hybrid clutch with the X431 V+? Ive seen other diy's but they used PIWIS so curious if you were successful with the Launch. About to pull the trigger on one of these but I want to make sure it can definitely bleed the hybrid clutch and help me work on the air suspension (seems it can based on other comments)
Anyone know a functioning website to purchase some enabling codes? I mistakenly erased mine for multifunction and cruise control and of course I didn’t back them up. Trying to fix it myself and learn in the process.
Maybe someone can backup their configuration and send to you?
Thanks. I sent an email a few days ago. I’m still waiting for a reply. Checking for other options too.
They may not be able to do it anyway, because the mothership is in Germany and RU is also cutoff from DE. However, they all use VPN in RU, so maybe it still works.
18202386[/url]]Maybe someone can backup their configuration and send to you?
What did you do? Disable production mode?
I didn’t know that was an option.
No, in the process of coding a retrofitted heated multifunction wheel, I chose cruise control and entered 16 zeros. So now cruise control is disabled until I enter a correct enabling HEX.
