Cayenne Coding - The Ultimate Guide & Discussion
#1411
What tool you using, Launch? Also which module was it in? I just backed up my steering module settings, can send you backup. PM.
#1412
Originally Posted by F SANE IL;[url=tel:18203813
18203813[/url]]What tool you using, Launch? Also which module was it in? I just backed up my steering module settings, can send you backup. PM.
#1415
X431 help
Can I ask a favor of one of you who has an X431. Can you check if it can turn off hill assist in a 981 GT4. I believe the setting is under PSM.
If it can then I will buy an X431. If not then I will buy a cloned PIWIS.
Apologies for spamming a Cayenne thread with a 981 question but I couldn't find an active 981 thread on X431 coding.
Thank you
Thank you
#1417
Thank you
Thank you
Post #55.
Check it out.
#1420
On rereading that thread, it appears to say that PIWIS can disable hill assist, but doesn't say whether X431 can do it.
Do you know if X431 can also disable hill assist?
I prefer to buy a legitimate product (X431) over a bootleg PIWIS, but will purchase the latter if I need to.
Thank you.
Thank you.
#1421
Thank you.
Thank you.
PM for more.
#1422
Assuming this is/was done on the Enthusiast version? Or are most people running the 2-3x more expensive Professional version? I can't figure out which to buy.
Can you adjust suspension/ride height with either version of Durametric? I can't figure out if the extra cost of the Professional is justified for me. I want it mainly for data logging. Is there no difference in the amount or limit of parameters you can read and log with either version? I mean, does having the Professional version unlock more parameters to view or log over the standard Enthusiast kit? Or are these cables/kits basically 100% the same with the main difference being able to use the Professional version on way more than just 3 VINs/vehicles? I have no need for anything other than just my 1 VIN Cayenne lol but I don't want to be missing out on anything the Professional version might offer. Like, it would be just my luck if the Enthusiast version couldn't data-log let's say, Wideband AFR O2 sensor data or something that's fairly critical when working with a remote tuner and having to send data-logs back and forth remotely.
Yes, I know I'm posting in an older thread lol
The following 2 users liked this post by twodollardoug:
Blownvette (08-02-2022),
ElSpoon958 (07-28-2022)
#1424
A) I'm interested. I'll slide into your DMs lol. I'd still have to purchase the software program too, no?
B) Can you tell me/us more about why Durametric sucks? I don't disbelieve you, but I want to know the specifics of why. And if there are any better options for us. lol
FWIW I'm getting my HPTuners MPVI2+ unit in the mail. I was told by Todd @ Promotive it's a potentially great data-logging solution for the Cayenne. At least my 958.1 version. Beyond viewing and logging lots of parameters you'd want to capture for back and forth emailing files working with a remote tuner, I am not sure what else it'll be good for. It'd be great if I could also use it for flashing the ECU instead of having to buy the MyGenius handheld unit. I doubt I can adjust suspension/ride settings with it lol and allegedly you can do that with the Durametric. Just don't know which one (The Enthusiast or the Professional version). It would be amazing if HPTuners could tune the Porsche Cayenne ECU. I mean, if there's any way I can help that pipe dream, I'm game. I posted over on the HPTuners forums about it. It might be as easy as getting the hard ECU data loaded into some file format so the HPTuner wizards can work their computer magic on it. I don't know.
#1425
Hill assist resolved
Thank you
Thank you
-> Launch X431 cannot turn off hill assist (confirmed by Launch)
-> rnlst_log helped me turn off hill assist, and was super patient/helpful
Thank you rnlst_log!
