Cayenne Coding - The Ultimate Guide & Discussion
#721
- Coding to allow switching on of surround view at a higher speed?
- might be possible - would need to look into speed limit settings but don't have a car around with this option to test
- Enable sports gauge as per picture above
- need to scroll thru the codings in cluster. done that on my previous car, did not take notes which values exactly
- Close trunk with remote (does not look possible due to security access error)
- will not work as described
- Increase the seat heating (not sure if possible but I find they do not get very hot at all just warm)
- not possible
- Keep Headlight DRL and LED DRL on when lights are on sidelight option
- no clue- sidelight not a topic in central Europe
- Proper method to lower car (air suspension)
- done several times with 958 and 95B. See manual attached, it's available for 958 as well.
- Hook up PSU, open window, hook up Piwis
- go to maintenance/repair / Air Suspension calibration
- what/how to measure actual values: see attached manual (basically distance from wheel center to fender line)
- just guided a friend thru the process remotely. We figured again that while it's ok to lower a Macan around -30mm, I would not recommend more than -20mm for a Cayenne (as it gets to stiff)
SO to add:
- I am after help to do the following:
c17r15 (11-25-2022)
#723
#724
Diesel. Fortuitous that the main guy here is in spring lake. Im in Red Bank. I almost messaged you about the rims and winter tires but have a Jeep as well and really cant justify it even though price was right.
User 9000 rpm here in the ultimate coding thread is in Princeton. I want to message him but my account is too new so I don't think I can yet. ...but you can. I’m cool with a run across 195 to Princeton.
#725
- not possible
Hi I couldn't find the coding for the sports gauge as per photo.
Enabled gforce and already have boost but no power gauges or option to add to screen.
#726
Received 1,153 Likes
I’m new to Porsche with my ‘13
#730
Managed to enable the performance display but apart from an orange dot moving left to right it does not look like the rest is working. The I would expect the graph to change with acceleration but it does not.
Also if anyone can be as kind to give me step by step on how to lower the macan using piwis? I checked out the pdf but it mentions something about adding 30+mm to the measured value? No where else mentions this?
#732
#733
- not possible
#734
Does the launch give the option to enter security code? For example boot/trunk module?
If so, can someone try and code boot closing with remote control.
Security code: 12345
Tried with vcds just to see and security code is accepted but obviously vcds doesn't have correct files for porsche so could go any further
#735
