What did you do to your 997 today?
Only had my 09 M6 for 4 days, so there's a list!
1- Got title and plates paid for, have temp papers for now.
2. Figured out how to eject a CD, thought those buttons had to do with the telephone!
3. Called local Indy about PPI I had done in the state where I bought it. He will be looking over "critical" items like flushing the possibly original and now dirty brake fluid and acidic coolant. Emailed him the PPI which included pics of fluid samples and test strips. Doesn't have an opening until November!
4. Tried linking telephone but didn't get past "Telephone not Available" and no Bluetooth menu found. I have the CDR-30, 619 Bluetooth telephone option, and hopefully unrelated 870 Universal Audio Interface (MP3 works via plug) along with 680 Bose HE pkg. Searched the internet but they had head ends that didn't match the CDR-30. Will slog on tomorrow.
5. Confirmed that radio gets basically no FM stations. Other cars get dozens here. Maybe the antenna became disconnected? Removing the radio to check is a low priority.
6. Looked into tire repair kits.
7. And got in around 50 miles of sometimes spirited driving, occasional light rain notwithstanding. That's what it's all about!!
Ohio Performance (09-14-2021)
Bumper cover respray
Picked up the car from the body shop after a bumper cover respray which included filling the plate holes. The road rash wasn’t too bad, but the rest of the car is perfect and it always bothered me. I put ppf on the car when I bought it but the damage was already done because the previous owner hadn’t bothered with ppf. An absolutely perfect paint job. Looks like a new car.
Need to get the Xpel replaced now.
The following 8 users liked this post by Jaws1:
cvtuttle (09-20-2021),
david (09-18-2021),
EMC2 (09-17-2021),
Full Boost (09-17-2021),
PCARNTHZST (09-17-2021),
and 3 others liked this post.
The following 6 users liked this post by Skube:
bamaboy473 (09-16-2021),
Busta Rib (09-17-2021),
CAVU (09-17-2021),
EMC2 (09-17-2021),
Ironman88 (09-17-2021),
and 1 others liked this post.
New shoes...
Brake bleed day today. Easy stuff. 2.0 bar of pressure. refilled 5 times. Used a Motive power bleeder for the first time. Think I will add a valve contraption part way down the pressure line to close it off, release air pressure on the master cylinder side so that each time I need to refill the master cylinder I am not pumping the bleeder 100-150 cycles, 5-6 times for a proper brake fluid change. All in all, successful day.
Man, we'll see. I drove her home in the rain and parked it to finish the work day and get better weather for a proper test run. (Felt nice and planted on wet roads, but I didn't push miuch.) I didn't check the pressures before the second drive, but while running a cloverleaf on-ramp at , say Level 6 intensity, it definitely felt.... MOOSHY, to quote @Bruce In Philly and pass a nod in his Atlanta direction. It wasn't just sidewall flex, it was like sidewall wobble on the rears. Not how my PSSs ever felt under any circumstances at any pressure. (And my time with them was from 50% --> 0% tread.)
I'll check and adjust cold pressures when I can get a nice, dry run in, but I am a little concerned right now.
Yes... butt..... when I put on my new PS2 N4s, the stiffer performance was immediate (and they are 18" !). No need to wear off the release. Yes, I am sure there was release, but the tire is just structured very differently from the 4S that the difference was obvious even with the slippery release. My experience is the 4S is mooshy... always. Sorry to be a downer, butt... that darn big butt again.
I do remember what I didn't like about the PS2.... they wear way faster than the 4S ... the PSSs wore like iron. I had all the Michelin iterations. Now with mounting miles on my PS2 N4s, I can honestly say my sports car is back! I sincerly can say I will not be going back to the 4S tires even as they continue to win all the YouTube comparisons for traction. The 4S just took out some of the fun; and that is why I own the car in the first place.
Peace
Bruce in Philly (now in Atlanta)
Peace
^ I have about 700 km on a new set of PS4S on my 993. They do feel soft on the road, not sure if I like that yet.
Car had 5 yr old Pirellis on there before.
Peace
Peace
Ironman88 (09-18-2021)
What did the shop charge you?
Also need one of the horns replaced.
Doing that while the bumper is already off should be a snap. (The quote I got from an indie shop in Los Angeles area was almost $700 to replace a $145 OEM part.)
Would you guys recommend letting a body shop do that while repainting the front clip?
