What did you do to your 997 today?
Old 12-27-2020, 02:18 AM
  #11236
sandwedge
sandwedge's Avatar
Received 1,031 Likes on 732 Posts
Originally Posted by Bruce In Philly
2009 C2S 167K miles
My rear shocks leaked ... don't know exact mileage they started, but car was bouncy at high speeds and I discovered the leaks at 94K miles. Bouncy is not quite correct... depending on the highway undulations, the car was swaying so I would put it in Sport mode to stabilize. I figured something was wrong as I didn't like Sport mode much for typical highway cruising. I still have my original springs... I don't know how to diagnose a bad spring.
Peace
Bruce in Philly
Well that's a good reference. At 167K miles I can't think of another poster here with higher mileage. Any costly repairs so far other than wear and tear items like clutch (I think yours is a manual) brakes and such? Btw....I don't know how to diagnose a bad spring either. Best guess would be that they soften up and bottom out in a way they didn't used to.
sandwedge is offline
Old 12-27-2020, 02:35 AM
  #11237
sandwedge
sandwedge's Avatar
Originally Posted by Wayne Smith
Bruce off roads his 997 in order to get some good bird pictures, while carrying two passenger weights of Doritos ... So I would expect his shocks would wear out sooner.
My 2010 C4S PDK with 136K miles is still showing no signs of leakage on the OEM units. The rears did feel soft to me but it took some time for me to adjust from mid engine to rear engine dynamics. In other words, I suspect they were always soft and it simply required some time for me to accept it. That being said, a quick adjustment in the DSC rear shock calibration table brought them to my liking. Better than new and I'm still waiting to see how long they last.
Originally Posted by Iceter
Most shocks don’t ever leak, even when they are completely worn out. Leaking shocks are always bad, but bad shocks rarely leak.
Most shocks are also done by 100k miles. They go bad so gradually that most people don’t realize it until the ride gets horrible or they drive a car with new shocks and remember how things used to be. So I would bet you would feel a noticeable improvement in your ride and handling at 136k miles if you replaced your original shocks.
Wayne and Iceter......any of you have thoughts or opinions on how lowering springs like H&R, Eibach or Techart affect the lifetime of struts and shocks? I've heard different opinions on this. Some say they put more stress on both the struts and shocks without explaining why. Others think just the opposite. That the stiffer lowering springs put less stress on both struts and shocks.
Old 12-27-2020, 02:50 AM
  #11238
Wayne Smith
Wayne Smith's Avatar
Received 1,199 Likes on 766 Posts
I suspect (know) you're right. When I turned wrenches to put food on the table shocks were replaced every 40K miles. With or without leaking they lost their stiffness. It's not like things have changed that much.
But the DSC recalibration brought things back pretty sweetly. In fact between motor mounts and the revised DSC settings mine is tighter and it is handling better than it has since my acquisition 100K miles ago. I can't compare to when it was new. However, I'm pleased.
That being said, skepticism is why I did my first DSC table changes for max firmness throughout ... Just to verify I could get the suspension to too stiff. I'll admit I was surprised when the test proved the shocks were still viable. Then it was simply a matter of dialing back the stiffness. And declaring that there was more life within.
YMMV of course.
I'm not driving much in 2020 so not feeling like spending for B16s (yet). But at this point I also don't feel the need. All things in time. Heftier sway bars are first.
Wayne Smith is offline
VT Blue (12-27-2020)
Old 12-27-2020, 02:59 AM
  #11239
Wayne Smith
I'll confess, that's beyond my pay grade!!!!
But if you view the shock as needing to absorb a specific amount of energy across the travel of the suspension, and you shorten that path then the shock would need to be stiffer to absorb that energy in a shorter distance (and time) in order to avoid hitting the bump stops.
But that's assuming no spring rate change. Stiffer springs would compensate. But that's during compression. Stiffer springs would put more stress on the shocks during the rebound.
But beyond valve and fluid wear (viscosity break down) you have seals. Reducing travel reduces the distance the shaft travels across the seal and I would expect that to decrease wear and extend life.
Old 12-27-2020, 10:13 AM
  #11240
Sporty
Sporty's Avatar
You are assuming the lowering springs actually have a stiffer rate, which I do not think is true at least with the Eibachs I installed. I do not feel a stiffer ride from stock, so they must compensate with the rate given the spring is actually shorter. Just my hypothesis, but then again its only about 3/4-1 inch shorter (I think) so may not really be noticeable (?). I replaced the bump stops and strut mounts when I did the changeover to Eibachs, btw, as well.
Sporty is offline
Old 12-27-2020, 11:10 AM
  #11241
Iceter
Iceter's Avatar
Yeah, my opinion on shock wear with lowering springs would be complete conjecture. I could probably make a guess but it wouldn’t be worth anything.
Iceter is offline
Old 12-31-2020, 06:13 PM
  #11242
Jaws1
Jaws1's Avatar
Bought a multifunction Alcantara steering wheel from a fellow RLer (thanks again Bruno) and got it installed and coded. I have a steering angle calibration fault and PSM fault after the install but I’ll deal with that when the car comes out of hibernation. Really like using the wheel controls as opposed to the PCM touchscreen.
Before
After
Jaws1 is offline
The following 5 users liked this post by Jaws1:
Hootsama (12-31-2020), irnnr (12-31-2020), Ironman88 (12-31-2020), myw (01-01-2021), VT Blue (01-02-2021)
Old 12-31-2020, 06:41 PM
  #11243
PacNW3
PacNW3's Avatar
Oil change - the 997.2 is way better than my old 996.2! Love the oil filter location.
Clear side markers
Radiator grills
15mm rear & 7mm front Rennline spacers.
Driver side still stock in this pic
Passenger side with the spacers installed
PacNW3 is offline
Old 12-31-2020, 06:51 PM
  #11244
Riptide
Riptide's Avatar
Not much......went to lunch yesterday with a friend that got a 992 for Christmas....Sorry.....burn me.....but the car from the inside
is just simply out of touch with it’s roots. The ride was quiet and uninspired. So, I came home, bathed mine, gave it a hug and just
felt blessed. Happy New Year to all.
Riptide is offline
Old 12-31-2020, 10:23 PM
  #11245
brocski
brocski's Avatar
Turned over 145000 miles and gave it a year end wash.
brocski is offline
The following 8 users liked this post by brocski:
Dartmouth (01-24-2021), Gene_GaTech (01-04-2021), Hootsama (01-01-2021), NevilleNobody (12-31-2020), Ohio Performance (12-31-2020), Orangecurrent (01-18-2021), ParkslopeDope (01-07-2021), VT Blue (01-02-2021) and 3 others liked this post. (Show less...)
Old 01-01-2021, 02:54 AM
  #11246
sandwedge
sandwedge's Avatar
Above my pay grade too with all the variables. All you say makes sense but I'm not sure I can draw a definite conclusion from it.
I agree. I've had H&R springs on the three 997's I've owned and I never felt that the ride was any stiffer than OEM. But reading posts about lowering springs here it's rare to find one that doesn't complain about the "stiff", "harsh" or even "horrible" ride they produce. Seems to be the consensus but like I said, I disagree with it.
Sums it up. Some good reasoning and reasonable speculation by several but no hard and fast conclusion. Maybe there isn't one. OEM or after market springs may have no meaningful affect on shock and/or strut life.
Old 01-01-2021, 11:50 AM
  #11247
ky13
ky13's Avatar
@Jaws1 love the new wheel! That's my next mod (non mf though).
Boost gauge to replace the sport chrono and carbon fiber/alcantara ****/boot to replace the broken factory ****.
Tossing these on this coming week
ky13 is offline
Old 01-01-2021, 12:15 PM
  #11248
Recruiter_Bruno
Recruiter_Bruno's Avatar
Before
After
She looks great! Glad it found a new home to a fellow Rennlister!
Recruiter_Bruno is offline
Old 01-01-2021, 11:11 PM
  #11249
myw
myw's Avatar
did you code it with fox well nt530?
the psm fault should clear itself after driving 10 meters of so.
as for the steering angle calibration - u can likely clear this via the fox well nt530 (you will need this to enable the MF anyways).
myw is offline
Old 01-02-2021, 12:45 AM
  #11250
Jaws1
Jaws1's Avatar
Used a Foxwell to code the MF. Start the car and turn the wheel 20 degree to the left and right and then drive straight is what I found someone else did to clear the calibration fault. 3 more months until I start the car though. .
Jaws1 is offline
Quick Reply: What did you do to your 997 today?
