What did you do to your 997 today?
Old 03-08-2017, 07:55 PM
  #5326
The Beast
The Beast's Avatar
Well I completed a few things over the last two days.
Change oil, spark plugs, coils, brake fluid, added rear bumper and PSE exhaust also washed the car today. Here is a Pic of the bumper.
Next will be some wheels and a lowering the car some. Thanks.
The Beast is offline
Old 03-08-2017, 08:25 PM
  #5327
Surfer2001
Surfer2001's Avatar
Default What happened to your car today
Wife lost her mind in parking lot, and crashed her car into fellow employee.
She's grounded !
Surfer2001 is offline
Old 03-08-2017, 09:06 PM
  #5328
platinum997
platinum997's Avatar
What air intake is that and what rear bumper?
platinum997 is offline
Old 03-08-2017, 09:08 PM
  #5329
platinum997
She's grounded !
Ouch.. If it wasn't her car, I would have killed her.
Old 03-08-2017, 09:11 PM
  #5330
Petza914
Petza914's Avatar
Received 6,718 Likes on 4,272 Posts
That's a Champion F77 CF intake - probably the finest aftermarket intake available for these cars. I looked at installing one about a year ago, but it wouldn't fit with the supercharger pulley and active Aero hydraulics. Bumper looks like a GT2, but looks like a NB car so must be a look-a-like. Car looks great, but I think the dual tips with that bumper look a little busy with all the louvers in it. The GT2 uses a single slash cut tip per side. Might want to look at something like that unless you have PSE in which case there aren't really any good options.
Keep up the good work as I'm looking forward to the new wheel choice.
Petza914 is online now
Old 03-08-2017, 09:30 PM
  #5331
96Tiger
96Tiger's Avatar
Finally hard wired my radar detector. Fairly easy using an add a fuse. Sure beats having a power cord dangling down getting in the way.
96Tiger is offline
Old 03-08-2017, 09:31 PM
  #5332
The Beast
The Beast's Avatar
[QUOTE=Petza914;14016068]That's a Champion F77 CF intake and what looks like a GT2 bumper, but looks like a NB car so must be a lookalike. I think the dual tips with that bumper look a little busy with all the louvers in it. The GT2 uses a single slash cut tip per side. Might want to look at something like that unless you have PSE in which case there aren't really any good options.[/QUOT
You are correct it's an OEM GT2 bumper on my NB and yes I hacve the PSE
Old 03-08-2017, 09:41 PM
  #5333
Petza914
Petza914's Avatar
[QUOTE=The Beast;14016109]
Cool, didn't know a widebody bumper would tuck in on the sides with the extra width, or did you remove a bit from the center and put the two halves back together?
Also, it doesn't look like you opened up the other intake slot in the decklid for the passenger side inlet to that airbox, but maybe it's just not clearly visible. If you haven't, you can see the shape of the punch out molded into the bottom side and can buy the corresponding trim for the hole separately.
Looking good though.
Old 03-08-2017, 10:16 PM
  #5334
riggzee2
riggzee2's Avatar
Your car looks fantastic! These are what I found!
riggzee2 is offline
Old 03-08-2017, 11:33 PM
  #5335
gonz911
gonz911's Avatar
Pretty much monthly mods:
15MM Spacers Squared
H&R Springs
Interior/Exterior LEDs
6K Xenons
Rennline 4-pedal set
OEM Aero Bumper
Rennline GT3 Smile
Vinyl Headlight Trim
On Tap
Fabspeed Dual Intake
OEM Third Radiator
Work Meister S1 3P Black Center Wheels - 12-14 week grueling wait
KW V3 Coil Overs
Roll Bar
BTW - NO REAR WING!
gonz911 is offline
Old 03-09-2017, 09:33 AM
  #5336
Ni_Mo
Ni_Mo's Avatar
Love the GT2 rear bumper, any more pics?
I was thinking of fitting it to my C2S but being a NB I thought it would look off, yours looks spot on!
How easy was it to fit?
Ni_Mo is offline
Old 03-09-2017, 10:14 AM
  #5337
platinum997
Put the cluster back in and drove to work. Another 58 degree day
Old 03-09-2017, 10:15 AM
  #5338
The Beast
The Beast's Avatar
[QUOTE=Petza914;14016124]
Thanks for the compliment. No I did not cut the bumper the extra width is on the edges its hard to tell. What's crazy was i used all the original holes I should have taken pics of the install.
As far as wheels I think I decided to go with some concave wheel. I really love your Champion wheels.
Your car looks great with the Ruf pieces.
Thanks, what wheels are those? Are you on stock suspension?
I do have more pics of the bumper. I can tell you that your exhaust tips would need to be modified as this bumper sits lower. I have some "C" type brackets holding the bottom of the bumper which uses the original screws, you can not see the brackets. I used all the original holes so I did not cut or make new holes to the bumper or the body to make it fit.
You can PM for more details but honestly its was real easy job.
Old 03-09-2017, 10:17 AM
  #5339
The Beast
The Beast's Avatar
Wow that look good. I may have to try that myself.
Old 03-09-2017, 11:17 AM
  #5340
riggzee2
riggzee2's Avatar
They are made by Rodderick, sold by Wheel Dynamics they specialize in Porsche Wheels!
No spacers, no after market lug bolts necessary!
Mine are; R-66 RW6 19" (Silver, Brushed Face, Stainless Lip)
They come in Black, or Black/Brushed Face as well.
Ride Ht is standard for 997"S" W/PSM/PSAM Dynamic suspension - Sport Chrono
http://wheeldynamics.com/porsche-cars.html
riggzee2 is offline
Quick Reply: What did you do to your 997 today?
