What did you do to your 997 today?
Old 11-30-2015, 07:01 AM
  #3151
Sydneysixer
Sydneysixer's Avatar
I recently repainted the rear wiper arm of my 2005 997.1 which was showing signs of sun ageing. One of those jobs I decided to tackle late on a Sunday afternoon. The hardest part was removing the arm from the tapered shaft … a cheap bicycle crank puller was handy.
I suggest place a beach towel or similar around the work area to protect the rear window - I was fortunately prepared when the puller slipped off on the 1st, 2nd, etc attempts. Man was it wedged on tight!
Once off, it was not necessary to take the arm back to bare metal - instead a light rub-back with some fine wet and dry and several light coats of satin black brought it back to new appearance. Upon re-installation some anti-seize on the splines will hopefully help the next person who removes it.
Sydneysixer is offline
Old 11-30-2015, 07:07 AM
  #3152
HolmaN
HolmaN's Avatar
Originally Posted by RFeltner
Took her out of storage and went for a drive and a quick pic.
Awesome looking car, but you need new rims, badly.
HolmaN is offline
Old 11-30-2015, 08:12 PM
  #3153
JCGMS
JCGMS's Avatar
Originally Posted by Terrytwn
JCGMS,
Great looking car and a nice Brazilian Butt Lift!
:reckon:
Thanks! Will put some better pics when I have some time with a real camera (and better scenery)
JCGMS is offline
Old 11-30-2015, 08:13 PM
  #3154
kellen
kellen's Avatar
Bought a full leather interior for it, excluding the dash. The pillars, front and rear door covers, stereo surround and under dash parts minus glovebox. Got a great deal I feel. Now to just clean, leatherique and install it. Will post some pics of the process.
kellen is offline
Old 11-30-2015, 11:23 PM
  #3155
flying_solo
flying_solo's Avatar
If you ever tire of that cup kit and want to swap back to OEM let me know
flying_solo is offline
Old 12-01-2015, 12:00 AM
  #3156
RFeltner
8th Gear
RFeltner's Avatar
Thanks for the offer but that's an OEM factory installed aerokit on my widebody C4. Not planning on changing out anytime soon.
RFeltner is offline
Old 12-01-2015, 02:44 PM
  #3157
stevepow
stevepow's Avatar
Can't wait for your install notes - I want to do this next as many bits as I can. I've pulled the center console before to change the hand-brake, but the rest I don't know...
stevepow is offline
Old 12-01-2015, 07:03 PM
  #3158
flying_solo
Nuts :P
Old 12-01-2015, 08:54 PM
  #3159
kellen
kellen's Avatar
I was only interested in the stereo and door panel parts. But it was such a good deal i knew I would be kicking myself.
Currently Leatheriquing the interior. May be a little bit as want to touch up a small area of the drivers door.
Any good links for the b and c pillar removal anyone?
kellen is offline
Old 12-02-2015, 04:07 PM
  #3160
Ten Years
Ten Years's Avatar
I haven't taken too many photos of her lately. It's such a nice day today that I decided to snap a quick one. (Please excuse the iPad quality.) Here she is with the various black details I've added recently: black OEM center lock nuts and center caps, OEM black inner PSE exhaust tips, and Rennline intake grilles. I love the blacked out bits that the GTSes come with from the factory, but I also think they could've gone a tiny bit further. For me, it's now nearly perfect.
Ten Years is offline
Old 12-03-2015, 05:50 AM
  #3161
Rikky001
Rikky001's Avatar
Fixed my audio problem in my 997.1 4S. Not that I missed it but I want everything to work as it should.
CD Changer was broken as cartridge was blocked inside. Some moron replaced the internal fuse by a solid wire so no surprise why I found a black pcb inside.
Found a second hand on Ebay, easy replacement but after that nothing worked anymore, all MOST connections lost...
I did learn that you should not pull too much on these MOST connectors as than you compress these internal springs leading to too much attenuation and loss of signal. Also the maximum bending radius to be maximum 25mm.
After surgery on the MOST connectors to make sure the springs are OK, all is working fine again. It definitely helps to have the full Porsche manual I would say.
Rikky001 is offline
Old 12-03-2015, 12:59 PM
  #3162
stevepow
stevepow's Avatar
I think I am getting a new TPMS control module now. This service is turning into quite the "event". Trying to remain positive and I think my warranty company is equally starting to feel the rub.
stevepow is offline
Old 12-04-2015, 03:00 AM
  #3163
997.one
997.one's Avatar
Originally Posted by metric91
After
Can't believe what a transformation the paint made. Love the lip as well. Any additional photos?
997.one is offline
Old 12-04-2015, 04:28 PM
  #3164
Psymon
Psymon's Avatar
Prepping her for the track - Pagid RS-29 break pads!
Sports Cup 2 tire next!
Psymon is offline
Old 12-04-2015, 04:56 PM
  #3165
primm907
primm907's Avatar
Just picked her back up over lunch:
H&R springs
NHP bypass pipes
Function First transmission mounts
Function First engine mounts
Function First shifter ****
Transmission flush
Shifting feel has improved, and the sound when accelerating in 3rd is downright nasty. Only real downside so far is some additional buzzing due to the new, firmer mounts that I'll get to troubleshoot. Oh, and the check engine light as a result of the bypass pipes.
Plan to try the O2 sensor bungs next.
primm907 is offline
Quick Reply: What did you do to your 997 today?
