What did you do to your 997 today?
Old 11-19-2015, 08:47 PM
  #3091
Para82
Para82's Avatar
Got an alignment for 60 bucks - and now she drives like a 911 again
Para82 is offline
Old 11-19-2015, 09:33 PM
  #3092
ghostcow
ghostcow's Avatar
Topped off the oil with my new Ikea Raskog cart! Hmm, i see Gulf racing blue and my wife sees Tiffany's Blue, go figure Oh, 12 quarts fits perfectly on the bottom shelf.
ghostcow is offline
Old 11-20-2015, 12:22 AM
  #3093
tomc_mets
Sir Thomas Lord of All Mets Fans
tomc_mets's Avatar
Lol. We have the same cart in the same shade of blue! I think if I loaded it up with Mobil 1, the wife'd strangle me.
T
tomc_mets is offline
Old 11-20-2015, 01:00 AM
  #3094
dblcrwn
dblcrwn's Avatar
working on new Cup wing project
#BigAssWing
dblcrwn is offline
Old 11-21-2015, 10:47 AM
  #3095
shammerman
shammerman's Avatar
Had my steering wheel replaced with a paddle one - PDK with lights for Sport, Sport+, and Launch control in the little "windows". In with the new:
Out with the old:
shammerman is offline
Old 11-21-2015, 11:22 AM
  #3096
rjshar
rjshar's Avatar
Out with the old:
I've been wanting to do this since I got my car back in April. Looks great!!!
rjshar is offline
Old 11-21-2015, 12:54 PM
  #3097
Q 997.2 C4S
Q 997.2 C4S's Avatar
Nice upgrade, Shammerman! If you don't mind me asking, who did the install (dealer or Indy) and how much did it cost? I'm considering this swap too.
Q 997.2 C4S is offline
Old 11-21-2015, 04:14 PM
  #3098
Ten Years
Ten Years's Avatar
Honestly, this is so easy to do, you really should just read up on it here, and learn to do it yourself. I was reluctant to handle the airbag myself when I did the swap on my 997.2 C2S, so I had my dealer do the swap for me. I think they charged me $250-300.
When I swapped out wheels on my GTS, I did it myself. The first time took maybe 20 minutes to do. I've done it a couple of times since, and now that I know how to do it, it really takes like ten minutes, maximum, to make the swap. Very easy, very clean, very safe to do.
Up to you, but IMO, when you've just spent $1,000+ on a new steering wheel, it feels much better to not have to spend a penny more for the install.
Ten Years is offline
Old 11-22-2015, 09:14 AM
  #3099
shammerman
shammerman's Avatar
Did it at the dealer. they matched Suncoast price for the Sport Steering Wheel at $999 and charged $131.52 for the labor. Santa came early...
Old 11-22-2015, 09:17 AM
  #3100
shammerman
shammerman's Avatar
It is my understanding that because this wheel has the lights it requires "programming: as well. I may be incorrect, but I would be reluctant to DYI this due to the airbag being involved in the swap. Not doing that correctly could be a "costly" mistake.
Old 11-22-2015, 11:04 AM
  #3101
it's no e30
it's no e30's Avatar
Joined RL
it's no e30 is offline
Old 11-22-2015, 12:46 PM
  #3102
F308gt4
F308gt4's Avatar
Did an oil change myself (last night).
I had one done when I first got the car about 5000 miles ago, and decided to do another one now and send a sample for oil analysis. I do mostly city driving (daily driver) so I think it would be good to see how the oil is doing after 5000 miles. Decided I'd do it myself rather than bringing it in to a shop.
Easy job:
Jack one one side of the car (don't really have to do this, but I did for easy access).
Unscrew oil plug with 8mm hex wrench.
When the oil flow diminished somewhat, took a sample to send to Blackstone labs for oil analysis.
Lowered the car so that it would be level to finish draining.
Removed oil filter using a 36mm socket.
Let oil drain for about 2 hours while I did other stuff.
Installed oil plug and torqued to 37 ft-lbs
Installed oil filter (and O-ring around housing) and torqued to 19 ft lbs.
Filled with 8 quarts Mobil 1 0-40.
Ran engine and took a short drive around block to warm up.
Checked oil level- was at the bottom line, so added about 1/2 quart more oil.
Checked oil level again- perfect!
F308gt4 is offline
Old 11-22-2015, 03:02 PM
  #3103
david
david's Avatar
Tagged along with four air-cooled beauties, a Cobra and a Bimmer and got some practice in...
david is offline
Old 11-22-2015, 03:53 PM
  #3104
Ten Years
Ten Years's Avatar
Actually, the wheel for my GTS has lights too. No programming whatsoever. No warning lights to reset. I had to swap wheels several times recently when they sent me wheels with mismatched Alcantara. The trick is to disconnect the battery and let it discharge for like twenty minutes before removing the airbag module, etc. ;-)
Old 11-22-2015, 08:18 PM
  #3105
tomc_mets
tomc_mets's Avatar
It was unexpectedly nicer than the weatherman suggested it would be, so I drove around the metroplex looking for leather wipes. Didn't find what I was looking for, but got to spend a couple hours in the Porsche, which is never a bad thing...T
Quick Reply: What did you do to your 997 today?
