Cheap Android Head Unit Review!
#436
thats odd, not heard of anyone else having canbus issues like reverse not working.
are you sure you have connected together the 2 pink wires that come out the back of the HU? they need to be pushed into each other to make a circuit. if these are not then the unit won't know that you have put it into reverse.
Hopefully owtosin stands behind their product otherwise I would recommend buying from a different seller.
#437
I hope it isn't "china car audio". I've been talking to them for months about how crap my touchscreen is. Eventually they relented and agreed to send a replacement screen rather than a new unit, so I will have to work out how to take it all apart and fit myself.
they agreed to send over a month ago. Still haven't sent it amd every time I try to ask them they make out that I'm being inpatient ... despite telling them that I need to know at least roughly when it will arrive as I will be moving house in the new year so I need to know if I will give them the new address or not.
They don't seem to understand.
It's a bit of a joke.
#438
I had some email communication with Bob Low early on. 15899797723@163.com
He's also responded to queries on the Facebook, PORSCHE 997 RETROFIT & CUSTOM, Modified Tips n Tricks. https://www.facebook.com/groups/1515570201802930/
Maybe airing your problems will bring a more rapid response.
Good luck.
Good luck.
#439
#440
Good luck.
Good luck.
#441
Also, sorry for the delay, below is how I secured the HU in the dash.
Go to Home Depot or the like and get some fender washers and #4 sheet metal screws... 1" works but is a bit long, I would do 3/4"
![Name: x4UukxU.jpg
Size: 512.1 KB](https://rennlist.com/forums/attachments/997-forum/1341069d1683252404-cheap-android-head-unit-review-x4uukxu.jpg)
Find the little spot weld indentation on both sides of the HU (lower edge) and drill a hole for the #4 screw
![Name: nQpncZC.jpg
Size: 242.5 KB](https://rennlist.com/forums/attachments/997-forum/1341070d1683252404-cheap-android-head-unit-review-nqpnczc.jpg)
When the HU is installed, the holes you drilled will be visible through existing gaps in the dash
![Name: 1Ttv9Yo.jpg
Size: 278.8 KB](https://rennlist.com/forums/attachments/997-forum/1341071d1683252404-cheap-android-head-unit-review-1ttv9yo.jpg)
Tighten the screws on both sides so that the HU is flush and even
![Name: mz53htG.jpg
Size: 310.8 KB](https://rennlist.com/forums/attachments/997-forum/1341072d1683252404-cheap-android-head-unit-review-mz53htg.jpg)
![Name: x4UukxU.jpg
![Name: nQpncZC.jpg
![Name: 1Ttv9Yo.jpg
![Name: mz53htG.jpg
#442
Hi,
First time I've been in my car in a little while, noticed that zlink/carplay (over wireless) wasnt working with the error: "hardware err. Mfi read fail#2". Tried a few things like resetting etc, but with no luck.
My Zlink is version 3.5.57, on the PX6 via China Car Audio. Are there any updates or anything that help? Any ideas?
#443
Love this!
Is 3/4 necessary?
How deep into the deck is the screw getting screwed in?
In the last image where the washer and screw are installed, how deep do you screw it in?
I guess my question is based more around the fact that you probably only need the screw to be screwed around 1/4 inch as it doesn't need to go in very deep because it will not take much to hold the deck. But is the excess screw length to compensate for a gap bw the deck itself and the bracket?
I actually hav not secured mine in any way and it's actually secure in that it doesn't move around when driving. But I could slide the deck out if I try to.
It does stay pretty steady and stay in place, maybe due to having installed the 3d printed bracket/shim (posted a handful of posted earlier in this thread).
Is 3/4 necessary?
![](https://i.imgur.com/x4UukxU.jpg)
![](https://i.imgur.com/nQpncZC.jpg)
![](https://i.imgur.com/1Ttv9Yo.jpg)
![](https://i.imgur.com/mz53htG.jpg)
#444
Love this!
Is 3/4 necessary?
Is 3/4 necessary?
You only need to reuse the original screw to hold the unit and prevent it being pulled out.
No need to drill anything.
myw (07-11-2021)
#445
Newer PCMs (.2 cars) don’t have the factory screw. I actually used the 1” screw to secure my HU since it’s a little easier to begin threading it into the hole I drilled than the 3/4” screw. There is nothing behind the hole that I drilled, it’s totally dead space in the head unit. You could run a 2” screw in there if you wanted.
AitchUK (01-29-2021)
#446
I read a lot of this thread and found it very useful. However, one question that didn’t seemed to get answered which is why I’m posting again.
I have no Bose in my 997.1 and I’m interested in installing the android HU. Since I don’t have Bose do I need to buy the optical fiber decoder ?
Secondly, will the sound quality be just as good as my stock unit if I get the android unit? My main concern is sound quality and I wouldn’t want to sacrifice that to get additional features.
#447
#448
#450
@acr89 : Is your camera/reversing problem solved? I don't have the car with the Android HU anymore, however in your video I noticed two things as potential source of the issue:
a) when you switch on the camera screen which shows "F-Cam" which I believe stands for front camera - if I am not mistaken somewhere in the extended car menu you can configure which cam to enable when reversing. Or you may need to go into the secret setup menu and enable the camera at all (it may be disabled there if you haven't bought the camera with the initial order). There is menu items which say "prohibit reverse" which obviosuly need to be disabled. I believe AVIN also needs to be enabled. Check your wiring to make sure the R-Cam uses the right harness connections.
b) check you CAN bus settings in the secret menu. When I bought the unit the CAN protocol wasn't set to Porsche, but a generic one. Somewhere in the forum here you can also find the string to enter at the password prompt of the secret menu (instead of 126 I believe it is LOGCAN). This will show you the CAN Bus messages. You can check if the CAN bus shows the reverse signal.
