996 Forum 1999-2005
Another one bites the dust.
Old 05-24-2022, 09:08 PM
  #556
Porschetech3
Porschetech3's Avatar
Received 4,631 Likes on 2,101 Posts
Originally Posted by De Jeeper
I think im just gonna get a stock shaft for now. Maybe upgrade in the winter. Looking at how the shaft is made there is a huge stress consentration at that point. At 350ft/lbs of tension when the bearing went bad (obviously has been bad for a long time). It must side load the shaft because of misalignment and then a crack forms. At least thats my theory for making myself feel better for not spending money i dont have .
I concur ..lol
I think you are right, the bearing failed first, then caused the axle stub to break due to over-stress.. You will be fine with new same parts ( no boost added..lol)
Old 05-24-2022, 09:23 PM
  #557
zbomb
zbomb's Avatar
Received 4,292 Likes on 1,812 Posts
Originally Posted by theprf
This is how I do it. 3/4" drive socket and extension. Jack stand for support. 3/4" drive torque cube set for 460nm. 3/4" T slide with a 5 foot black iron pipe. Easy.
I'm about to pull the trigger on the parts, may be calling for some help - on a couple fronts for this job
Old 05-24-2022, 09:35 PM
  #558
De Jeeper
De Jeeper's Avatar
Received 3,461 Likes on 1,822 Posts
Thx Skip.
Z, u r lucky to have a Mass Aaron to help u.
Old 05-24-2022, 09:36 PM
  #559
zbomb
zbomb's Avatar
Thx Skip.
You aint kidding !
Old 01-17-2023, 06:39 PM
  #560
Justin76
Justin76's Avatar
need an update @De Jeeper
Old 01-17-2023, 06:55 PM
  #561
zbomb
zbomb's Avatar
Saw that your mezgar sump doesn’t work on its side (90 degrees).
Are you worried that when you’re driving, on the door, that you’ll blow the GT3 engine ?
Old 01-17-2023, 07:07 PM
  #562
De Jeeper
De Jeeper's Avatar
Thx for asking...no i better not ever be 90* over in the car. I have one of these 4 that. I also have a full list of upgarde and maintenence that ill spell out soon.
The following 8 users liked this post by De Jeeper:
EVOMMM (02-24-2023), JohnCA58 (01-17-2023), plpete84 (01-18-2023), Porschetech3 (01-17-2023), TheChunkNorris (01-17-2023), wdb (01-18-2023), yaz996 (01-17-2023), zbomb (01-17-2023) and 3 others liked this post. (Show less...)
Old 01-17-2023, 07:38 PM
  #563
zbomb
zbomb's Avatar
I'm gonna have to frame that pic...
And...what a tease on the upgrades.
Old 01-17-2023, 08:15 PM
  #564
De Jeeper
De Jeeper's Avatar
Mostly the lwfw and lw underdrive pulley along with some trick demonspeed pinch clamp adjustabe tierod links for the front and back. Got a fresh set of NT-01s to wear out too.
Maintenence includes brake pads, brake fluid, front wheel bearings, full aim dash (but u know that) with oil temp and pressure along with steering angle and brake pressure, tpms sensors with temp and pressure capability...im sure im missing something?
The following 2 users liked this post by De Jeeper:
JohnCA58 (01-17-2023), zbomb (01-17-2023)
Old 01-17-2023, 10:54 PM
  #565
Porschetech3
I'll bet that one has been 90* and probably 180* a few times....
Mdelay (02-21-2023)
Old 01-17-2023, 11:16 PM
  #566
De Jeeper
De Jeeper's Avatar
More then a dozen but its slow so there is usually very little damage .
Porschetech3 (01-17-2023), wdb (01-18-2023)
Old 02-21-2023, 12:46 AM
  #567
De Jeeper
De Jeeper's Avatar
So its that time again for maintenance and upgrades. Got a decent list of parts this year with the good friday sales. The major upgrade is a lwfw and evoms underdrive pulley. The gt3 drivetrain benifits well from this upgrade and its stock porsche parts frim the 997 rsr. I also have Zbombs old Aim dash to install along with steering angle, brake pressure, oil pressure and temp sensors. For the suspension i bought Demon Speed rear tow and front tre arms.
For maintanence i have engine and trans oil to replace, front wheel bearings and full brake flush. New pads and caliper studs for all 4 corners. It will also get a full nut and bolt check.
the parts pile
Back of a mezger and the new clutch
So the tape holds the release bearing fork as it has to go behind the bearing. A pivot pin has to be installed after the trans is mated. Its a huge pita with the engine out....i cant wait to try it with it in the car.
The following 4 users liked this post by De Jeeper:
damage98MO (02-21-2023), GC996 (02-21-2023), plpete84 (02-21-2023), zbomb (02-21-2023)
Old 02-21-2023, 10:42 AM
  #568
plpete84
plpete84's Avatar
Received 1,832 Likes on 926 Posts
I'm still amazed you've completed this whole swap on your own in your garage space. Feels good to knock out some maintenance and upgrades at the same time. I'm doing my HPDC March 5th at Summit Point so I should be cleared for HPDE in future and hope to join for one!
Old 02-21-2023, 12:05 PM
  #569
hbdunn
hbdunn's Avatar
I'm always amazed at the number of people involved in the Potomac region. 82 newbies signed up for their clinic, good for them. If you don't go to their Watkins event in May consider Metro at Summit the same weekend. I think Aaron was considering joining me there. All of my metro instructors were very good.
Hope the weather is good for your first clinic.
Old 02-21-2023, 12:21 PM
  #570
De Jeeper
De Jeeper's Avatar
Thx.. and very cool. Another 996 in the pits. I will be doing the Potomac event at Pittrace this year and im on the fence for the metro summit event. I have to figure out how many more events i can afford. If anyone sees a discount for nitto nt-01 tires pop up please lmk. I think i may need 3 sets this year .
Quick Reply: Another one bites the dust.
