The 133,333 mile engine rebuild thread
#661
I've never had the Hacker-Pschorr, but I love Paulaner Hefe-Wiezen (and Dunkel). Prost!
soren.911 (06-23-2020)
#662
Cam deviation sorted?
Pardon me if I missed in thread.
#664
Just a car guy
Who the hell thought a tamper proof screw should be used to hold the MAF sensor in place? I guess the dealer would be the only one to change a MAF out? Probably the same clown that designed the fuel cooler system. So I ordered a T20 tamper proof torx bit. Might arrive before the MAF sensor does.
Had to get the old one out before ordering a new one. I came across many different Bosch part numbers in my search. Now I know which one to order (and have done so). The one I ordered, initially, from Amazon was coming from Latvia. After no delivery in eight weeks, I told them to F-off.
#665
Fyi my lowes and hd both carry security torx bits uf u need them sooner.
#666
#667
Just a car guy
I ran Speedy for a while, to check some signals. Cam deviation on bank #1 was as high as -4.98 degrees when just started, and slowly went down to about -4.4 degrees. The coolant was a lot higher than I would like, so I shut things off. There was no air being pushed through the radiators, so maybe next time (if I try again) I'll put a big fan in front of the car. The other option will be to pull data while driving. I'm not crazy about that idea, but it's an option. Need to understand why it is getting so hot. I think the fans are working and there shouldn't be much debris collected since the last time I cleaned out the radiators. Need to do some checking. The coolant level is well above where it used to normalize - I don't think that should be a factor. I didn't confirm the 160 degree thermostat functioned as it should, before installation. I suppose that's a possibility as well.
#668
I've been trying to improve cooling on my 2000 c4 since I got it. In std form it's barely adequate, coolant above boiling seams to be 'normal'. This helped a lot but still not enough if you drive hard in warm weather: https://rennlist.com/forums/996-foru...adiator-2.html
#669
I saw in your thread you replaced the rads and put in a low temp thermostat, did you by chance look at your water pump impellers?
#670
Just a car guy
In my experience this can be caused by one of the vent / regeneration valves being bad in the evaporative emissions system, as you suspected. One of the valves is behind the RF tire on top of the carbon canister.
https://www.pelicanparts.com/techart...Vent_Valve.htm
#671
Back to this: Thanks for the tip, Kris. I messed around with it a little today when I heard the beer bottle whistle again. I removed the fuel fill cap and nothing changed. There is a small port at the front of the fuel door opening. Plugging that hole stopped the sound. Seems like a pretty good indicator it's the vent valve.
#672
Received 1,187 Likes
Where did you get your low temp thermostat? I remember Jake giving some advice on those awhile back. Said some of them are total crap and are worse than the original 180 degree stat. They were tested and found to be way out of a normal acceptable range. I think the low temp thermostats from LN Engineering are certified (or at least checked I think). Just guessing....
#673
Just a car guy
https://www.5150motorsport.com/low-t...06-013-61.html
#675
stupid question, but have you checked to make sure your coolant cap or bleeder are not leaking pressure? Do you know if your cooling system is building the proper pressure when hot?
