996 Forum 1999-2005
What did you do to your 996 today?
Old 06-17-2020, 05:22 PM
  #3256
Billup
Billup's Avatar
Originally Posted by GH996
You might try something like this. Reasonable price and you can keep your original console. https://www.suncoastparts.com/product/PK9X6PC.html
That's actually perfect, thank you for sharing that! I did a quick google search and for some reason that never popped up, just a bunch of used black consoles that had wear.
I've upgraded the exhaust, radio, and a few other components but kept all the OEM that will of course be sold with the car when / if that time ever comes.
Old 06-17-2020, 05:26 PM
  #3257
SoCal911t
SoCal911t's Avatar
Received 1,458 Likes on 705 Posts
Originally Posted by sgt1372
I've actually gotten conflicting info on whether my 2000 C4 Cab will take the EUR917 or EUR776 up front. Tire Rack says the EUR917 will fit but AMZN and Akebono says only the EUR776 will fit.
When I was researching, I would say about 75% of suppliers list the 917 pads and 25% the 776. I went with the 776 pads because of the reduced unsprung weight.
Old 06-18-2020, 07:11 PM
  #3258
wyovino
wyovino's Avatar
Despite taking all precautions and due diligence with maintenance, I had a catastrophic radio **** failure. Whether you call it **** Leprosy, the Black Gooey Death, or Schwetty *****, it's embarrassing and nasty. I 3D printed some replacements and now my car can run faster and jump higher.
The following 10 users liked this post by wyovino:
Billup (06-19-2020), JohnCA58 (06-18-2020), Mike Murphy (06-19-2020), paddlefoot64 (06-18-2020), rx7dude (06-18-2020), SoundnSpeed (06-18-2020), ssgunny (06-18-2020), strathconaman (06-18-2020), user 8298308 (06-23-2020), Woodman71 (06-19-2020) and 5 others liked this post. (Show less...)
Old 06-18-2020, 07:15 PM
  #3259
FLTWRLD996
FLTWRLD996's Avatar
Had it cut off on me while at a stop light. Light turned green and it suddenly died. I'm not even sure if I had even put it in 1st gear yet maybe just pressed the clutch and then all of the sudden it cut off. Everything looked fine on my dash, battery was reading 14v, Idle was just under 800rpm, coolant temp was right around 180, oil pressure was pegged at 1. Tried to crank it a few times with no luck and then waited 2 maybe 3 minutes and boom started right up. I know its not the battery bc I just put in an AGM interstate battery last night. Could this have anything to do with the ignition switch?
Old 06-18-2020, 07:23 PM
  #3260
wyovino
wyovino's Avatar
Start a new thread with your issue. You'll get more answers. I would start with the last thing you did - the battery. Make sure the connections are tight.
Old 06-18-2020, 09:35 PM
  #3261
strathconaman
strathconaman's Avatar
I had some "EZ Lip" in the garage...and now it is on my car.
The following 4 users liked this post by strathconaman:
Mike Murphy (06-19-2020), Ratchet1025 (06-21-2020), rx7dude (06-18-2020), wyovino (06-19-2020)
Old 06-19-2020, 04:52 PM
  #3262
Woodman71
Woodman71's Avatar
I had gooey *****, too, but no 3D printer. Alcohol bath took care of it.
Old 06-19-2020, 09:42 PM
  #3263
sgt1372
sgt1372's Avatar
Same here, so I just bought OEM replacement ***** (they came in sealed Porsche branded plastic bags) 4 months ago for a ridiculous price ($41.67 including tax &"free" shipping) off of eBay.
Old 06-19-2020, 11:10 PM
  #3264
wyovino
wyovino's Avatar
My **** gooiness came and went in the past, but this time it was terminal. I could literally mold them in my hand.
Old 06-20-2020, 01:53 PM
  #3265
TexSquirrel
TexSquirrel's Avatar
Received 2,411 Likes on 1,279 Posts
I have an aftermarket radio in mine.(installed by the PO)
Can you post the .STL in case someone else needs them?
Old 06-20-2020, 05:42 PM
  #3266
hotchalupa
hotchalupa's Avatar
"..Hi, my name is Eddie, and I too spent stupid money on a pair of OEM replacement *****. Suncoast got my money..."
In retrospect, I should have tried the alcohol bath thing, too... Like Woodman71 did. I've used that method in the past, but had mixed success (and the failures were sometimes catastrophic as the alcohol would deteriorate the plastic finish under the coating.) But, this could have been a good last ditch "Let's find out before spending $17.50/****" effort.
But here we are...
Old 06-20-2020, 05:54 PM
  #3267
wyovino
wyovino's Avatar
Added an old school touch to my console.It had been painted in silver Plastidip but was looking kind of tired. I really like this fabric and may add some more accents. Not sure where.
The following 6 users liked this post by wyovino:
911Syncro (06-21-2020), Billup (06-21-2020), Ratchet1025 (06-21-2020), strathconaman (06-20-2020), TexSquirrel (06-20-2020), user 8298308 (06-23-2020) and 1 others liked this post. (Show less...)
Old 06-20-2020, 06:00 PM
  #3268
sgt1372
sgt1372's Avatar
Just pressure tested the engine in my 2000 C4 Cab w/the new oil cap adapter and manometer that I recently purchased/received from @TexSquirrel and AMZN (respectively) and got a reading of between 4.6-4.7
Desired reading is between 4-7 InH20, So, no need to worry about replacing the AOS w/the UAOS now.
Also just received the last of the parts that I need to do the complete brake job on my car and will be making an appt w/my Indy in a couple of days to get the job done.
Old 06-20-2020, 06:37 PM
  #3269
wyovino
wyovino's Avatar
I just uploaded it. It may take a little while for it to become available.
https://www.thingiverse.com/thing:4487366
Old 06-20-2020, 09:11 PM
  #3270
TexSquirrel
WOW!
paddlefoot64 (06-21-2020)
Quick Reply: What did you do to your 996 today?
