Is anyone tuning the 992 yet?
#286
Carlo, I was not aware other states were already doing this.
Living in California, I have grown accustomed everything bad starting here first!
Are you aware of what people are doing for workarounds for ECU tunes?
Do you (or anyone) know whether flashing back to the factory setting using something like Cobb Accessport is successful?
In other words, I and I think many enthusiasts wonder whether if smog testing shows the telltale evidence of flashing, even if there is not a checksum problem, would still cause a fail?
I did read in a Ford forum that the workaround in California is going to be for group of people to share a stock ECU and pass it around to be installed just for the smog test, and then removing it and swapping back in the performance tuned ECU... not that I'm advocating that just to be clear!
#288
The process was simple really. After placing your order M will overnight you a USB cable and a ODB2 dongle. You just download the M-Tuner software. The M-Tuner software will then generate a unique ID of your car which you just need to email to M. Now - in case M has had the ECU ID before, expect the files within a couple of hours. In my case, the ECU ID was unknown to M so they had to build new maps - this took 24h. The map file then you load with M-Tuner to your car - takes a little less than 6 minutes. Then first start - I'm not gonna lie - is scary. My car threw all kinds of codes and the idle was really rough. This is however documented in the "How-To" from M. The codes can be cleared used M-Tuner and then just let the car sit for 5 minutes idling.
The "feel" of the tune is immediate. I'm NOT coming from stock - I had the JB4 (claimed +60hp) - and there's WAY more power. What I like personally, you don't have to work for the extra power - there's a mountain of torque right from low rpms. Revving it just adds to that. There's now hole over the range or anything. No stutter, no shacking and the transmission just goes with the "flow'. The reason why I'm mentioning this is because I had tunes before (not Porsche) that did add nice power - but always had some stutter etc. a certain rpms. This is not the case here ....
I'm not getting paid by M (I wish I was .. lol) but man ... this tune ROCKS!!
The following 4 users liked this post by HashTag:
#290
No other mods - other than BMC high flow air filters.
#291
For those of you that have tuned Porsches in the past (I haven’t) what level of additional stress does this put on the engine, turbos, etc? I talked to a shop that works with M-Engineering regularly and they stated that M-E tunes are “safe” and don’t push the engine “to the limit”, etc.
Essentially, do tuned turbo Porsches (especially with this level of gain) see engine trouble, failed turbos, etc. relatively quick?
#292
Carlo_Carrera (08-30-2021)
#293
More boost with timing and other parameters adjusted for optimization.
#294
If the proper maintenance is followed engine and turbo life can reach normal mileage without failure. Porsche builds these engines to last.
reddsektor (08-30-2021)
#295
Yes, a tune like this will increase wear and tear on the mechanicals. How much so comes down to how hard the car is driven. One things that needs to be adjusted is service intervals. Generally a car with tune will require more frequent spark plug and fluid changes. Usually plugs should be changed in 2/3 of normal un-tuned interval. Fluid change intervals are hard driving dependent. More hard drives, more fluid changes.
#296
Yes, clutch slip and wear can be an issue with higher HP.
#298
Not much different. The tricky part is finding a clutch assembly that handles the power and still fells good to you. With the older generations of 911s folks have worked this stuff out already. Eventually people will find the correct clutch mechanical formula with tuned 992s.
#299
I am not saying that tunes at this level will not be reliable. At the same time if turbo rpm is being pushed higher to make the elevated boost, then more fatigue is going into the rotating elements. You cannot see fatigue building up. It will simply manifest itself as an abrupt failure IF it occurs. I suspect the rest of the engine is very stout for US road usage since it must hold up on the autobahn when run very hard. Low restriction induction and exhaust systems are one way to limit turbo rpm needed for a given power target.
#300
So, the bottom line is, with a manual, I'd want as much power as possible because it won't affect durability any more negatively than PDK and likely would last longer on a manual. Plus, manuals are inherently slower than the DCTs so you'd want as much power as possible to make up that deficit in performance.
3rdpedal (08-30-2021)
