Is anyone tuning the 992 yet?
#436
Platinum Sponsor
This is very simple.
If warranty of your vehicle is a primary concern, tuning may not be for you.
That being said, the uninstall files provided with M-Tuner take you back to a true stock and we have yet to run into any issues with anyone taking their cars into the dealer. If you enjoy modifying your 911, like to party, and like fast(er) cars, M-Tuner may be for you then.
-Charles@M
-Charles@M
#437
Thought so.
Also, as described by the tuner, they are capturing an image of the memory and replacing that image. Any counter saved in that memory would have been restored to the prior value.
#438
Just like hooking up with a crack ***** in Vegas, tuning your car is a personal choice. If you are worried about warranty, don’t do it, but also, don’t try to save us from ourselves. We know what we are doing and the risks involved. I bought the car knowing I would tune it. See ya behind me…..
The following 4 users liked this post by 22CarreraS:
#439
-Charles@M
-Charles@M
#440
M-Engineering:
”If you enjoy modifying your 911, like to party, and like fast(er) cars, M-Tuner may be for you then. ”
Epic response! Just outstanding!
#441
-Charles@M
-Charles@M
Quick question - and not to take anything away from you or your product as in my decades of being on different car enthusiast boards, M Engineering seems to have set the high bar standard for both the quality of their tune and amazing customer service. So now the question: if PNA or the dealer wanted to look for the tune (and no reason why they would if all looks up an up), could they not look at the history of the parameters that the car was running at to determine that the car could not have operated at those levels without a tune? Again, this is just a question for my education and not a challenge to the product as I fully agree that anyone overly concerned about the warranty probably should not be getting a tune.
#442
I’m starting to benchmark my stock (no tune, no down pipe, stock exhaust) 992S, RWD, before I do the tune…, so went out to our local airport (there is a infrequently used access road that runs parallel to one of the runways).
I wanted to measure 0-60, 1/8 mi and 1/4 mile, but unfortunately, at the longer distances, I was on a stretch of the road that had a slight upgrade, which produced: “invalid run”.
Nevertheless, I was able to get two valid runs to 60mph. First was 3.22 sec and the second was at 3.11 sec. Road was dry (but not very smooth/in good condition), with temp at 70F. I’m pretty happy with the runs, and is what I see in most of the reviews, but think on a smoother road, and cooler, etc, I can do better. Quickest time I have seen for this car is 2.9x sec.
With the tune, and 150+ more hp, I would think times approach 2.6-2.7 sec.? Anybody with an M-Tune done any testing?
#443
Platinum Sponsor
-Charles@M
The following 3 users liked this post by M Engineering:
#445
-Charles@M
-Charles@M
Go Bruins (04-14-2022)
#446
presumably your “Premier” dealer is not waiving any right to claim that warranty terms have been violated?
is that correct? and, if so, what does it matter that they “have no issues” with tuned cars, particularly since the dealer can easily prove the tuning modification if they applied the tuning?
#448
it is my opinion that any tune will need an upgrade to the intercooler system because the stock system can’t keep up with the extra heat generated from the increased boost and turbine speed. Any dyno gains will be short lived in real world driving.
#449
While not the same car, I noticed the same thing with my tuned M3. The stock intercooler was remarkably effective in the hot summers here in AZ and tests of aftermarket intercoolers showed them to be less effective or marginally better. I replaced mine with an aftermarket unit only after my stock one started leaking.
The following 2 users liked this post by AlterZgo:
Andy2021 (07-11-2022),
tourenwagen (07-12-2022)
#450
I think it really depends on where you live, whether you track your car, how you drive, etc. I have not run into any issues with heat soak driving my tuned 992S here in hot as ***** AZ even when temps are consistently 100-110+. If you don’t track your car, it is extremely rare you will be driving your car hard enough to cause heat soak. These cars are insanely fast and even more so tuned. If you’re cruising at 40 mph, 3 seconds of foot to the floor acceleration on surface streets will land you in jail. 10 seconds of hard acceleration on the fwy will get you to over 150 mph. Honestly, none of us should be overtaxing the stock intercooler during real world driving, unless your real world driving includes tracking the car and/or driving in autocross events or running 1/4 mi drag runs or high speed mile long events.
