Does your 992 make a clicking noise like this?
Denny Swift (10-19-2022)
#182
I read the thread yesterday . I listened to your videos and heard nothing unusual. So today I got in my car and listened . I heard the clicking but it is so faint and insignificant that I think you are all driving yourselves nuts . I always felt that the title noises are part of the charm . There are way bigger fish to fry than these crickets .
Tupper (08-03-2022)
#183
My crickets (fuel pumps) are super noisy with the windows down. Drive next to a wall and come off the throttle at low revs….. but the head tech says it’s normal…. So if something goes wrong it goes back.
At 3k miles on the clock it was noticeable, at 7k miles it’s slowly getting louder.
#184
I've also purchased a based Carrera 2020 model recently and it does the exact same thing.
I went to the Dealer, and they said at first this is bad and wanted to investigate but 4 hours later they did a 180 and told me, its a 'product-specific sound' we can not fix it and it is not harmful.
They did tell me that the sound goes away when you have it in neutral and switch off the air conditioning. If you then push the brake paddle, the sound reappears again. But they couldn't tell me which part made the noise.
They simply put 2 other brand-new 992's on the lift and they made the same noise.
#185
Dear Aggie, did you eventually find the culprit?
#186
I’ll get it to the Tuner soon, maybe they know something. If I know what it is, I’ll report back.
aggie57 (10-19-2022)
#187
No.
Possibly a faulty fuel injector or the valve timing is off...
There is a rocker arm that helps open & close the valves. Normal setup with camshaft & pushrod that controls it. The valves move at a fast and short distance. If they aren’t precisely adjusted, you can hear a metallic ticking sound similar to what you’re hearing. I’m not a flat-six expert, but the setup is universally used on modern cars.
Say what?? There are no rocker arms. There are no push rods. There are no valve adjustments. There are overhead cams and hydraulic lifters. The cam lobes contact the lifters directly and open and close the valves.
I don't hear anything in the video. Maybe your curlers are rattling
#188
Just wanted to Re bump this thread incase there were new updates. Been hearing it in my 22’4 GTS.
#189
I do notice if I stick a tank of E10 fuel in it’s a little louder, so stick with the quality stuff as much as possible
#190
My car still does it, to be frank as we hadn't seen anyone post about it for a while I wondered if Porsche had found the cause and resolved it. I think yours is the 1st report I've seen of it in latter car.
#191
My neighbor purchased a base 22 911 and his does it too. Which makes me think it really is a characteristic of the car. But my first 2020 911 didn't do it! So I STILL don't know what to think about it. I should have just lived with it. But since my first 992 was a buy back. I wasn't taking any more chances. I look forward to seeing what the 992.2 brings. Other than MUCH higher prices! lol.
aggie57 (04-14-2023)
#192
#193
I just bought a base 2023 911 (made in January'23, delivered late April) and I hear these sounds! Super annoying when just cruising around the city with the top closed. It's clicking/chirping all the time. How is this normal? I took it back to dealership 30 min after I drove it off the lot because I thought something was wrong. Never heard this sound before on 911s I test drove (or Boxsters for that matter). The sales rep acknowledged the sound, wasn't sure what it was, brought the tech to take a look and he said it was normal. All 992s sound like this. I made a note to get a second opinion, at least there wasn't something wrong with the car. I'm surprised there is no fix for this issue and it doesn't seem well known. The car cost $160k but sounds clunky, not what I was expecting for my first big car purchase. I would be happy to pay another 10k just to get this issue fixed. This is crazy. Someone please help! What can we do?
#194
good luck.
PS: my neighbors does it too.
#195
Did they reimburse you the full amount? How difficult was it to get the buy back? Ideally I would like to fix the noise and not return the car. It's crazy there are no techs on this forum that can explain why some cars have the noise and some don't, and what the difference is between them, so people can fix the issue.
