PCCB very dusty!
#256
Received 3,455 Likes
#257
#258
#259
Thanks @sgroer nice sleuthing!
So, 991.2 PCCB pads or Pagid Rsc1s - what do those of you with experience recommend???
Anyone with thoughts of 991.2 OEM vs. Pagid RSC1 for PCCB's used on the street, with some track use? My dealer is willing to install prior to me picking up the car. I might just DIY, but don't have my center lock tool setup figured out yet, nor do I have the time right now.
#260
BUMP. Thanks @sgroer !
Zero757 (11-18-2021)
#261
Thanks, 991 OEM is certainly the easiest. Dealer can get those quickly and install before I pick the car up. Did you flush the factory brake fluid when you swapped pads, or does it also hold up pretty well?
#262
unless you are a track hero, you’ll be fine. Always something you can do down the road but it’s very sufficient for the occasional track day and lots of aggressive street driving.
#263
Perhaps what you are describing a "judder" is what I technically call the "crunchies." It's a feeling I get at times before ABS kicks in where the pads seems to loose full grip with the rotors as you apply more pressure, where the pedal feels "crunchy." I typically only get that in my GT4 at very high speeds and apply max brake heading into a hairpin.
Well, this morning, I was doing one of the things I enjoy: late braking into the underpass of a freeway (MoPac) and trail braking into it. Well, guess, what, I got the "crunchies" braking from about 40 mph to about 15. With my GT4, I never experienced this issue unless I was super late and hard on the brakes at a much higher speed.
I ordered my replacement pads yesterday.
No Way I'm tracking this car with these pads.
A brand new Lambo was totaled (I believe) at COTA last month due to brake failure. Can't believe Porsche doesn't have a massive disclaimer on these brakes.
#264
#265
#266
#267
#270
FYI, PFC just informed me that they have (or soon will have) a replacement pad for PCCBs (and I assume for steels).
