ECU Tuning Questions (Detailed)
#91
No mention of the Litchfield tune?
Highly respected outfit, offered on Cobb AP, can remote tune based on logs, and retune as you add mods. Each retune is $350. Can all be done in your driveway and removed at will.
Many articles on the Litchfield Carrera T in professional publications giving the car a 5/5. Also a few YouTube videos out there.
Tuned for everyday drivability and reliability. Used by the owner Ian Litchfield on his personal Carrera T.
Just throwing it out there, as I was considering this myself. I have to confirm with them that they have a 91 octane version of the tune. Disadvantage is that Litchfield is located in U.K., but mitigated by remote tuning capability and that the tune seems to be solid and ever improving (given that it’s his personal car).
No bias here, just reporting my own research so far. The Litchfield car was what convinced me to buy my T, as the articles demonstrate the incredible growth capability of the 991.2 base platform.
Good luck, all.
Good luck, all.
devtec (01-28-2021)
#92
I got a few moments and was able to speak with the tech dept at APR, I just called the normal number went through the prompts and it took about 10 seconds for someone to answer. I was very impressed with the gentleman's answers to my questions as he had no prep time and didn't know what I would be asking. I updated a couple things on the pro/con list for APR, but was able to confirm that a home-based solution is coming (maybe summer 2021, but no promises). At the bottom there is a table of HP & Torque claims from each company, where it says "(calculated)", i increased their percentage gains to the stock numbers with a calculator. The Cobb numbers seemed a little fishy there still but i put what they posted. Ignoring the Cobb, Softronics has the largest power and torque output by ~2% on HP and ~8% Torque to the next closest tuning solution. The chart (at the bottom) didn't copy and past as well as I would have liked it to but i think its still readable. I will continue to call other companies as I get time but here is what I have so far for updates.
FVD:
Pro:
Porsche only company based in Germany
Quality R&D Budget (3 engineers on staff)
Bosch & Siemens trained for Porsche Specific
$1500 is comparable to APR & Softronics
They posted on RL saying 10% disc to Rennlist members (I think its still valid)
30-day Guarantee
Con:
No Warranty
No Full Custom Tune
Unknown:
APR:
Pro:
Powertrain Warranty available
Quality R&D Budget
$1500 is comparable to FVD & Softronics
30-day Guarantee
Porsche’s on site for testing purposes
Customer Service + (Quick call answer and thorough answers to my questions, without prep work)
Con:
No Home Solution (Confirmed its coming Estimate. Summer 2021)
No PDK Option
Any mods for warranty need to have written authorization from APR (I get it but have an approved parts list)
No Full Custom Tune (Claim that for stock its pretty spot on)
Not Porsche Specific
Powertrain Warranty $1500 Extra
Softronics
Pro:
Largest HP & Torque Gains
Home Based Install
Full Custom Tune
Con:
$95 more then APR/FVD
No Warranty
Unknown:
Quality R&D Budget?
Cobb/Linchfield:
Pro:
Quality R&D Budget
Accessport is superior to other devices
Limited PDK Tuning Upgrade Available ($700)
30-day Guarantee
Full Custom Tune Included (SpeedCircuit)
Home Based Install
Linchfield Tune Available (£600.00/$830)
Con:
No Warranty
$1695
No Bosch & Siemens trained for Porsche Specific
Firmware has seemed questionable at times
More work for Custom Tune vs Semi-Custom (Not anyones fault)
Rumored that current FW version has less power than older FW versions
Unknown:
Custom tunes are rumored to be 100% based around the OTS maps, does this really make them more valuable? - What happens after FW update?
VF Engineering/ HEX tune
+50-60HP/+90-100WTQ
Pro:
Quality R&D Budget
Online About us:
VF Engineering has been located in Orange County, CA for nearly 20 years now. Our facility measures some 15,000 sq-ft and includes a Mustang AWD 500 chassis dyno, 4 Hunter lifts, a big photo studio, R&D room with a rapid prototyper, and a clean room for ECU board work. We’ve also got this big-*** red couch. Not sure where it came from but it has a magical effect on cars. They always make a few extra hp when the red couch is there.
Con:
No Warranty
No Full Custom Tune
$2300
Less Gains than APR or FVD
Dealer Only
Unknown:
991.2 C4
Software
Max Power
Max Torque
Stock (Porsche)
272 kW (370 HP) @ 6500rpm
450 Nm (331 lb.-ft.) @ 1700-5000rpm
Stock (APR)
390 HP
330 FT-LBS
FVD Tune
335 kW (455 HP) @ 6500rpm
580 Nm (428 lb.-ft.) @ 3500rpm
APR 91 AKI
454 HP
439 FT-LBS
APR 93 AKI
475 HP
461 FT-LBS
Softronics 93 AKI
485 HP
498 FT-LBS
Cobb OTS Stage 1 91 AKI
469.9 HP (Calculated)
420.37 FT-LBS (Calculated)
Cobb OTS Stage 1 93 AKI
503.2 HP (Calculated)
450.16 FT-LBS (Calculated)
Linchfield Cobb Custom Tune
460 BHP (466 PS)
430 FT-LBS (583 Nm)
SpeedCircuit Custom Tune
456 WHP (Calculated)
413 FT-LBS (Calculated)
HEX Tune
420-430 HP (Calculated)
421-431 FT-LBS (Calculated)
FVD:
Pro:
30-day Guarantee
Con:
No Warranty
No Full Custom Tune
Unknown:
APR:
Pro:
Quality R&D Budget
30-day Guarantee
Con:
No PDK Option
Softronics
Pro:
Home Based Install
Full Custom Tune
Con:
No Warranty
Unknown:
Quality R&D Budget?
Cobb/Linchfield:
Pro:
Quality R&D Budget
30-day Guarantee
Home Based Install
Con:
No Warranty
$1695
Unknown:
+50-60HP/+90-100WTQ
Pro:
Quality R&D Budget
Online About us:
Con:
No Warranty
No Full Custom Tune
$2300
Dealer Only
Unknown:
991.2 C4
Software
Max Power
Max Torque
Stock (Porsche)
Stock (APR)
390 HP
330 FT-LBS
FVD Tune
APR 91 AKI
454 HP
439 FT-LBS
APR 93 AKI
475 HP
461 FT-LBS
Softronics 93 AKI
485 HP
498 FT-LBS
460 BHP (466 PS)
430 FT-LBS (583 Nm)
HEX Tune
That being said, our tune makes ~11whp over the Cobb Stage 1 tune all else being equal. So the numbers you list should reflect that.
#93
I'm not sure where you're getting the power/torque numbers from, but if you're comparing one companies dyno graphs to another, it's apples and oranges. All dynos read differently, so the same car can make 300hp on one dyno and 400hp on another.
#94
Also-these are crank HP figures, or WHP? I think APR distinguishes between both on their site depending on which you chose but not sure on the rest. In the end, you have to look at the % gained over base line as the dyno's read differently.
#95
I'm not sure, I took literally from each's website, I do not believe many of them specified. I will remove the HP & Torque stuff for now since its not a fair comparison.
#96
https://www.speedcircuit.net/product...03be0e0a&_ss=r
I think the best way to do it is to show the percentage of power and torque gained for each solution relative to the factory tune. Also, note that there's a difference between a graph and an illustration / estimate.
#97
I threw Linchfield in the mix, since they are embedded with Cobb I put them in like a subsection under Cobb. Funny you mention it another friend mentioned them the other day and their great reputation. I will try to look a little deeper as I get time. Thanks for the suggestion!
Let us know what you think.
I think Litchfield website numbers are low/outdated. Without mods likely just under 500hp. With exhaust only (Akrapovic slip on) its hitting 520 hp and 470 ft lbs torque. The last video states 610 hp (with more supporting mods, likely headers and cats).
#98
FVD:
Pro:
30-day Guarantee
Con:
No Warranty
No Full Custom Tune
Unknown:
APR:
Pro:
Quality R&D Budget
30-day Guarantee
Con:
No PDK Option
Softronics
Pro:
Home Based Install
Full Custom Tune
Con:
No Warranty
Unknown:
Quality R&D Budget?
Cobb/Linchfield:
Pro:
Quality R&D Budget
30-day Guarantee
Home Based Install
Con:
No Warranty
$1695
Unknown:
+50-60HP/+90-100WTQ
Pro:
Quality R&D Budget
Online About us:
Con:
No Warranty
No Full Custom Tune
$2300
Dealer Only
Unknown:
FVD:
Pro:
30-day Guarantee
Con:
No Warranty
No Full Custom Tune
Unknown:
APR:
Pro:
Quality R&D Budget
30-day Guarantee
Con:
No PDK Option
Softronics
Pro:
Home Based Install
Full Custom Tune
Con:
No Warranty
Unknown:
Quality R&D Budget?
Cobb/Linchfield:
Pro:
Quality R&D Budget
30-day Guarantee
Home Based Install
Con:
No Warranty
$1695
Unknown:
+50-60HP/+90-100WTQ
Pro:
Quality R&D Budget
Online About us:
Con:
No Warranty
No Full Custom Tune
$2300
Dealer Only
Unknown:
I’m still looking around. I’ve about run out of things to do to this car except maybe the brakes. But I have two sets of 19” wheels so that limits my choices a little bit it seems from my initial research.
#99
Can you please do some before and after dyno and or Draggy? One thing I simply dont understand with Scotts train of thought is why he wont post dyno graphs. I dont care if you dont make the most power, I want to see what you can do with power delivery. Due to the fact that he wont display any meaningful data I feel his tune is a simple pump of boost and other tables and minor custom tweaks the customer wants to get them out the door.
Can't wait for spring to get here. But not too quickly as I am not done downhill skiing / touring for this season
Will download the ECU file for Scott and get my tune back and will upload to the MyGenius, but will make sure to do a few Dragy runs on the stock file and then upload the Softronic tune and repeat.
At least I have a few months to find a good stretch of road for testing!
#100
Spent an hour talking with Scott this afternoon and then ordered my Softronic tune for my 991.2 GTS He answered every question I had and then some. Absolutely satisfied all of my questions, and reassured what I already new / suspected / or taught me what I had no idea about. Highly recommend reaching out if you have questions. His insight is impressive.
#101
Hey I'm curious how does Cobb flash vehicles without setting off alarms vs everyone else it seems needs the VIN and somehow puts that into some data base to unlock the CPU (not sure that is right but know I'm not far off). Just kinda interesting as the Cobb is the only unit that holds resale value because of this. Don't get me wrong, I'm not going in with the thought of resale value but also its not something to be ignored either.
#102
We've been tuning with Cobb for over a decade and I'm drawing a blank here.
#103
I'm saying the Cobb AP, at least to my knowledge doesn't need a VIN to tune the ECU, its known that you can make custom tunes based on different factors but every other tuning manufacture needs the VIN to "unlock" the ECU, Cobb does not. This single feature giving the Cobb resale value where other solutions are paperweights for different vehicles beyond the tuned vehicle. I guess at the end of the day my mind wonders if other companies could do the same and add resale value to their solution and choose not to or if Cobb has some secret sauce. If Cobb has figured this out and others haven't then it makes me wonder what else they have unlocked.
#104
Not sure how relevant but it was crossing my mind.
#105
This thread was helpful in pulling various tuning threads into one place. I decided to go with FVD for the following reasons:
1) The at-home tuning solution was a must have for me. I didn’t want my car tied to a dealer network to remove the tune.
2) FVD only does Porsche
3) I was looking for a ‘mild’ tune to compliment the headers, sport cats and air filter - no interest in drag times or maximum horsepower output
The following 5 users liked this post by Sarawnty:
devtec (01-31-2021),
DR911s (04-21-2023),
GT3FZS (01-31-2021),
SFZ GT3 (02-01-2021),
Tier1Terrier (01-30-2021)
