Has anyone done a CarPlay retrofit / Headunit replacement for 991.1
#946
Just FYI, I discovered you can connect a BC 1.2 compliant powered hub in the car and you will get 1.5A of charging rather than the 500mA that many kits provide. Made a huge difference for me when I got this:
and
to power it.
Android Auto works great and I assume CarPlay as well, and now my phone doesn't slowly discharge if I use the screen at all.
and
to power it.
#947
Osunick and other Android users,
To connect to the Joyeauto unit, I have to plug my phone into the Joyeauto USB AFTER the car is started, PCM in AUX and push NAVI button. Is there a way to make the connection from the phone to Joyeauto more automatic?
Also...WAZE, Google Maps apps show up on the screen menu. How do I make other apps on my phone show up on the Android Auto launch window on the PCM screen?
Lastly....after Android Auto launches, if I switch to Tuner on the PCM to get radio, it seems like I lose the voice prompts from Android Auto.....and need to switch back to AUX source. Is there a workaround to avoid losing the Android Auto voice prompts?
Thanks in advance.
Thanks in advance.
#948
Thanks in advance.
Thanks in advance.
#949
Thanks in advance.
Thanks in advance.
The PCM doesn't have the ability to mix sources so there isn't an option for you to hear voice prompts and listen to any source other than your phone. There is no way to make the connection automatic, since I don't listen to anything other than my phone the source thing is a non issue for me.
-n.
#950
Can anyone confirm please that the NM Automotive kit will automatically switch to the reverse camera without having to tap any wires in a manual car? Nick says that it will, but Joyeauto support says on manual cars there is no reverse or steering data available - so you have to tap a reverse light wire and there are no guidance lines.
Thanks!
Thanks!
#951
Thanks!
Thanks!
koala (09-09-2020)
#952
I have the version 1 non wireless NMAuto unit and can confirm that I DID NOT need to tap any reverse wires. I believe it listens to the CAN signal wires for reverse and pops up the guidance lines and the camera. I also have a 7MT. I only needed to tap a ground and I ran the power and signal wire from the NMAuto unit to the generic cheap ebay camera (works great BTW).
#954
No, I found the support to be quite responsive to my questions and reviews I’ve seen have been quite positive. The main reason is that my car is MT and the Joyeauto unit will not pick up the reverse signal to turn on a rear view camera unless you tap a reverse light wire. Also, it doesn’t pick up steering signals to add dynamic guidelines to the camera on MT cars. On PDK cars, everything works as expected without having to tap wires.
The NM Automotive unit picks up the signals from CANBUS for MT cars without having to tap anything.
koala (09-23-2020)
#955
So are these units all the same or not? Or perhaps just earlier or later reversions?
My previous understanding is that the Joyeauto, NM Auto, etc where all the same, likely all out of the same factory in China, with the difference essentially being the level of support and documentation you received along with shipping times...
#956
My unit is definitely Korean, not Chinese. Networkwws (Network Worldwide Solutions)
#957
Quick question - my installer is working on the NM Automotive unit install and the first pre-installation step is to check the PCM sub-module status. The last submodule is 'PCM31 FDC' and that is showing as invalid. Any thoughts on what that might be and whether we can proceed?
We have an email into Nick as well but I thought I'd check here too. Thanks!
#958
Nick was pretty responsive.
#959
