Has anyone done a CarPlay retrofit / Headunit replacement for 991.1
#3676
#3677
Well on my non Bose it's definitely sending out an amplified signal, so if its not designed to power speakers then I don't know why it's not simply a line level output?
I guess we need someone with Bose to try a few experiments to reduce the guesswork and give us something a bit more concrete to work with
ratt359 (08-12-2024)
#3678
Originally Posted by ZedZed;[url=tel:19590545
19590545]Great thread! His idea is an extension of my post above - he has added an additional amp, but there's no necessity to do that as the HU is easily capable of driving the rear speakers (for most people anyway). I very much like his approach though and for those prepared to buy and install an aftermarket 2ch amp, this is the way to go. Good find Ratt ![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
obviously, I would have to disconnect the rear speakers from the Bose amp and connect the tapped wires from the quad lock directly to the rear speakers with an attenuator to control volume
#3679
I thought Z mentioned that they HU is capable of driving the rear speakers without an additional amp
andy2111 (08-12-2024)
#3680
If you have a Bose amp that is running your system, you should be able to disconnect the rear speaker wires from it. Then connect the rear speaker wires directly to the rear outs from the HU (see jadski's schematic above). As Zed and Andy pointed out, these should be powered, so they will power the rear speakers just fine. If you do this, then there is no reason to add anything to control the volume because they are hooked up to the rear speaker outs, the fader should work to control the volume of the rears if they ae coming directly from the HU and not running thru an amp.
I believe the non-Bose systems are still utilizing and amp in their system, that is why there can be an issue with unwanted noise from tapping into powered speaker wires coming from the HU. So, this method should work for them as well.
Based on what everyone is saying about not having fade control in their systems no matter what setup they have (Bose/Fiber optic or non-Bose/wired), I believe that the PCM is sending a different signal to all speakers for their "surround sound", but the fading is actually controlled by the amp and not the HU. The HU just sends a signal to the amp on what the fade setting are, and the amp controls the volumes to each speaker. The Android HU controls the fade at the speaker outputs and doesn't send a signal to the amp. This would explain why nobody has fade control, no matter their setup. But this should also allow control of the rear speakers if they are connected directly to the HU and bypass the amp as I stated in my first couple paragraphs. At this point, this is a theory, but one that I am fairly confident in. Ratt359's suggestion about using a spare set of speakers to test this would be the easiest.
![](https://cimg1.ibsrv.net/gimg/rennlist.com-vbulletin/1460x2000/rear_speakers_57f08e5e1b69a71741ceff188c3c6d93e6dc5eea.jpg)
#3681
I think anyone that’s not getting rear speaker audio should figure out why before jumping to crazy work around solutions, especially without fully understanding how the system is designed to function. Trying to mix speaker level output to the rear with Bose via MOST for the front probably isn’t going to work well. Those Bose speakers are designed to be driven by a real amp, not the little chip amp built into the headunit. The wiring could be entirely different and the Bose amp may be handling the crossover duties.
#3682
Basic Sponsor
The factory system is only fiber optic on Bose systems, which not everyone has. In my wife's non-Bose Cayman the sound is definitely better since installing the Android HU. Also, the EQ is way better, so there is also the opportunity of fine-tuning the sound, which doesn't exist in the outdated PCM.
In my Panamera, which has Bose, I am not hearing any significant differences in sound TBH. (I am an experienced listener of very high quality audio systems). I am of the view that a DAD additional conversion makes negligible practical differences, even in high-end systems, let alone car systems.
But even if the sound from these units did suffer somewhat, that is more than compensated for by all the up-to-date features these units bring. Even Porsche are of the view that PCM 3.1 is not a satisfactory infotainment solution any more, which is why they have junked it (at last).
Modernize your P-Car w/ Mr12Volt. Apple Carplay and Android Auto with superior audio quality, features, and support. Reach out for specials! Torque.Acs@gmail.com or Roman (267) 317-8229
Our website is now LIVE! please visit us at www.ACSByRoman.com
COUPON CODE "toys" FOR FREE INSTALL KIT!
On site install is available in the Philadelphia PA area as is Global shipping!
CLICK HERE JOIN OUR FACEBOOK GROUP
#3683
I don't think that is correct. I have the base audio system and there are no fibre connectors at all in my car, and you can see that from the picture of my quadlock a few posts above. My original unit is a PCM eg with navigation
#3684
Basic Sponsor
#3685
so, has anyone replaced a PCM4 with one of these? the PCM4 screen is OK but it looks pretty dated when coming back from the Taycan. Faster touch response would also be pretty welcomed. Considering people have coded PCM4s to replace PCM3.1s, I think it should work and may try it out.
#3686
You need to find one that specifically mentions PCM 4 otherwise it won't work as the canbus adapter is different
If you search aliexpress for 'pcm 4 android' you will find some options. They might not be Chstek branded, but if it looks the same it'll be the same underlying unit
https://a.aliexpress.com/_EwRN1X3
Per the installation guide we recommend the 7862 CPU with 8GB memory. Looks like they offer the UIS7870 CPU now on this unit which is newer and should install and setup in a very similar way, but you'd be the first to try it (and the author of the 7870 section of the guide!!)
Keep us updated and good luck!
#3687
But the bottom line is this: an add-on solution using the OEM fiber brings zero benefits to cars that do not have fiber. That is what I (clumsily) was saying. I think most would have understood that, but I apologise is my post was not sufficiently clear.
andy2111 (08-14-2024)
#3688
But Roman's point is moot. In your car, and my wife's Cayman, the optical output is unused. It is connected to nothing. The orange fiber lines do not exist. So no matter what Roman's add-on board does, it will make zero difference to the SQ in your, or my wife's, car. Roman seems to be trying to claim that his solution offers superior SQ to ALL cars because he taps into the optical output. But with nowhere for that digital output to go, there can be no advantage. In Bose/Burmester setups, Roman does have the advantage of maintaining an unbroken digital signal path. Whether an additional DA conversion makes an audible difference to SQ is a much debated issue, and some people beleive it makes an audible difference, and some don't. AFAIK, there have been no blind ABX tests to objectively verify it, so it remains a subjective difference, if at all.
The following 2 users liked this post by ZedZed:
bigkraig (08-14-2024),
skidpalace (08-15-2024)
#3689
I am intrigued by how your add-on board solution uses the optical/fiber connection inside the PCM. In non-Bose/Burmester cars, like my wife's Cayman and Andy's 911, the amplifier has no means of using an optical signal. So your solution would not provide any benefits in SQ for those cars*. Now, in Bose-equipped cars, you would have an advantage (if eliminating an additional analog-digital conversion really is an (audible) advantage) since the Android HU's use the MOST box conversion route and thus utilise an analog signal to a digitally-equipped amp, which is, technically at least, inferior.
* Which is what we were originally discussing prior to your intervention.
#3690
We seem (or I seem, to be more accurate) to be complicating things here. If we take a more familiar example, it may clarify things. Many TVs these days feature both digital and optical outputs. Many soundbars feature digital and optical inputs, Users can choose one or the other (but not both at the same time) depending on their needs. I, for example, have an LG television and a Sonos soundbar that feature both types of connection.
Now if I choose to connect with analog (RCA) leads and have no actual fiber connection at all between the two optical connectors, then clearly I do not gain any advantage at all from my optical connections. The optical connection does not physically exist. No matter what I do inside the TV to utilise or improve its optical circuitry will make any difference whatsoever to the SQ - it cannot because I have no actual optical connection. This is the parallel with Bose (and Burmester) systems and non-Bose systems in our cars. If you are not using the optical connection (by physically not connecting it to the amplifier) then no amount of tinkering inside the TV is going to impact the optical connector's sound quality (SQ). Of course, if I then disconnect my RCA analog connectors and instead used the optical connection on my TV and soundbar, I will benefit from any improvements made to the optical output of my TV.
So if I used an add-on board in my car which tapped directly into the PCM's optical output, then this could be better than using a MOST box. That is a legitimate claim which Roman can make. It is NOT a legitimate claim to say that it will improve ALL cars, meaning non-Bose/Burmester as they do not have that physical optical connection I am talking abut here.
Having said all this, we (me included of course) perhaps need to remember that this thread is dedicated to Android head units, and there is a perfectly good alternative thread dedicated to add-on boards.
