Has anyone done a CarPlay retrofit / Headunit replacement for 991.1
Old 03-12-2024 | 01:31 PM
  #2176
LIT911's Avatar
LIT911
Default Thank u
Wow. Thank u both for the fast response. I was meaning the dash part by the gauges. The one round screen there. When using Bluetooth it displays the song there.
ZedZed (03-12-2024)
Old 03-12-2024 | 01:43 PM
  #2177
ZedZed's Avatar
ZedZed
Here you go, I took a picture for you which makes it easier to explain. This shows a nav app on the left and YT Music on the right. You can control each app in the normal way.
You have to open both the apps you want to use side-by-side, then click the little icon circled in yellow. The drag the first app you want to the side and then repeat for the second app.
Old 03-12-2024 | 01:44 PM
  #2178
ZedZed's Avatar
ZedZed
Ah - no. That info comes from the PCM, which of course will now be in a box in your garage You still get the 'vital' gauges, trip, TPMS if you have it. But not the audio or phone or maps info.
Old 03-12-2024 | 01:46 PM
  #2179
LIT911's Avatar
LIT911
I’m sorry. I’m referring to it displaying the song name here
  #2180
panagath's Avatar
panagath
My GT4 had CDR31... so I didn't have that feature either... not even able to connect my phone with bluetooth for music/navigation, only calls... completely useless... very happy it is in the garage now ...even with bright screens and warning lights on the dash
Old 03-12-2024 | 01:48 PM
  #2181
ZedZed's Avatar
ZedZed
Our replies crossed in the ether. See my reply just above.
Old 03-12-2024 | 01:50 PM
  #2182
ZedZed's Avatar
ZedZed
Haha. I know what you mean. Amazing how these inexpensive Android HUs bring the car up-to-date. Even with their faults!
Old 03-12-2024 | 04:58 PM
  #2183
LIT911's Avatar
LIT911
thanks so much guys!!!! as much as i like that feature i think the waze and all the other benefits of the upgrade is worth it
Old 03-12-2024 | 11:21 PM
  #2184
Rmlovett1's Avatar
Rmlovett1
This has worked very well so far for me. Had it installed a week ago.
Old 03-12-2024 | 11:55 PM
  #2185
bill edwards's Avatar
bill edwards
Default CarPlay added flawlessly
In Atlanta Ga, guy designed and installs his own version. Its flawless and allows OEM PSM to function as original equipment. See FB details. Rules prevent me from advertising his capabilities. He is as no other. Further Porsche North America is aware of his solution and extremely impressed due to his workmanship, Camera selection , overall quality and installation being meticulous. I own and have his solution installed. Be careful whose aftermarket solution you install, especially the cameras.
Old 03-13-2024 | 02:37 AM
  #2186
Haidang's Avatar
Haidang
That is the exact same unit in my wife's Cayman. You are seeing the same SWC screen as she sees, but her car has the 'sport' steering wheel, without buttons. What is the model and year of your car?
Zed and folks,
My SW is working with Erisin HU now.😁
I just follow this
“Choose your car model “
i choose this( it has more Can type, may be different Porsche)
I don’t need to program anything.Its good for now.
Thank you very much Gentleman!
ZedZed (03-13-2024)
Old 03-13-2024 | 07:04 AM
  #2187
panagath's Avatar
panagath
Looks like Erisin are quitting on this. They don't seem willing to do anything else.
Can someone who has the brightness issue send me a video of the very bright screens? I will try to record and edit a youtube video to upload so people know not to buy.
hello,
about this lights, you need to unlock the system in garage, then the problem can be solved.
Nancy
Old 03-13-2024 | 10:14 AM
  #2188
ZedZed's Avatar
ZedZed
What does their reply even mean? Do they mean that it needs coding at Porsche? That is nonsense. The fault lies with their canbus solution. It's very disappointing that they have given up. I can't send you a video as the only thing affected in mine is the huge beam light. I think your suggestion is a good one though and maybe Andy can oblige. Maybe when there is a YT video someone will step up with a solution.
Old 03-13-2024 | 10:20 AM
  #2189
UH2's Avatar
UH2
I feel like this troubleshooting could/should be it's own thread.
It also makes me happy I stuck with the NM automotive unit instead of trying one of these others, even though these newer units offer more features. If I had more time on my hands ... maybe...but I assumed any support would be hit and miss. Mostly miss. Whereas NM's support has been golden.
​​​​​​​I hope you all get some resolution, but the current state wasn't hard to predict.
Old 03-13-2024 | 10:41 AM
  #2190
ZedZed's Avatar
ZedZed
I had the Isudar unit before the two Android units (Isudar is essentially the NM Auto solution where the PCM has to be taken apart and an additional board fitted). That solution definitely has merits, but I wanted to replace the outdated PCM and its low-res screen as much as get AA or CP in the car. The unit in my Panamera is flawless and gives me a 12.3 inch wide screen, much like the later models have as OEM. The Erisin-style unit in the Cayman has this one issue of the panel lights not dimming properly at night, but in my case, it is confined to the high beam light, so not really a problem as I found a workaround for that.
Nick at NM Auto is a pleasure to deal with and I have bought from him before (not a Carplay/Android Auto solution though). The Isudar-style solution is pretty reliable once one has managed to install the ribbon cables properly and although mine was without fault, there have been various problems reported on the dedicated thread.
Essentially, we have two very different solutions here - the retention of the PCM, with its drawbacks, and a tricky installation of the add-on board, and/or the updating of the HU with a more modern display. The latter is an easier installation, but unfortunately, it is plagued with this one issue of the 'bright panel lights'. Other than that, there are no issues that I am aware of that have not been caused by user error. I still think that either of these solutions is an upgrade to the older Porsches so you pays your money and takes your choice as the showman said.
I hope that the guys for whom the panel lights thing is a problem find a resolution. It is a great shame that what seems to be a fairly trivial problem to solve is proving impossible for the sellers of the unit. There are other units, of course, that have a slightly different style, come with different software and firmware, and may be OK. Then again, they may have their own set of issues. I guess this is what happens when people modify their cars. My Porsche Indie loved the wide screen unit in my Panamera but he did make the comment that I was "on my own" if anything went wrong with it or it caused any issues with the car. Fortunately, it hasn't. I kept my PCM, resisting the temptation to sell it for good money, so that I can, if I want to, put the car back to factory, eg when I come to sell it.
Chuck245 (03-16-2024)
Quick Reply: Has anyone done a CarPlay retrofit / Headunit replacement for 991.1
